Ecco la vaggata che ho effettuato...ne avevo fatta un'altra qualche ora prima e poi cancellato gli errori....l'ho rifatta e sono venuti fuori questi. che ne pensate?
Chassis Type: 4B - Audi A6 C5
Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56
Address 01 -------------------------------------------------------
Controller: 4B0 907 401 AA
Component: 2.5l/4VTEDC G400SG D66
Coding: 01012
Shop #: WSC 02325
1 Fault Found:
01375 - Valves for Engine Mounting: Stage 1
38-10 - Output won't Switch or Short to B+ - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 AH
Component: ABS/ASR 5.3 FRONT D10
Coding: 00012
Shop #: WSC 02325
1 Fault Found:
01203 - Electrical Connection between ABS and Instrument Cluster
03-10 - No Signal - Intermittent
Address 08 -------------------------------------------------------
Controller: 4B0 820 043 K
Component: A6-Klimavollautomat D64
Coding: 00063
Shop #: WSC 02325
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 4B0 920 900 C
Component: C5-KOMBIINSTR. VDO D11
Coding: 00060
Shop #: WSC 00000
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ AUZ7Z0Y1346610
No fault code found.
Address 35 -------------------------------------------------------
Controller: 4B0 962 258 D
Component: Zentralverriegelung D33
Coding: 04673
Shop #: WSC 02325
2 Faults Found:
01561 - Left Rear Door
59-00 - Can't Unlock
61-00 - Won't De-Safe
End ------------------------------------------------
