Risultati da 1 a 10 di 13
Discussione: AUDI A4 B5/8D 1.8T 150cv errori dal VAG COM che ha?
    Audi lover L'avatar di Audi18
    Feb 2009
    Firenze (FI)
    Audi a4 1.8T
    Icon9 AUDI A4 B5/8D 1.8T 150cv errori dal VAG COM che ha?
    Salve
    presento la macchina a4 1.8t del '95 con 212413 km ha impianto a gas brc da quando aveva circa 60000km ovvero 9 anni fa...ho già fatto il reset degli errori e mi rimane questo:
    VAG-COM Version: Release 311.2-N
    Chassis Type: 8D - Audi A4 B5
    Scan: 01,02,03,08,15,17,25,35,45,55,56
    Address 01 -------------------------------------------------------
    Controller: 8D0 907 557
    Component: 1,8l R4/5VT MOTR HS D05
    Coding: 04001
    Shop #: WSC 00000
    12 Faults Found:
    00635 - Oxygen (Lambda) Sensor Heating: Before CAT
    26-00 - Output Open
    16716 - Knock Sensor 2 (G66): Signal too Low
    P0332 - 35-10 - - - Intermittent
    16885 - Vehicle Speed Sensor: Implausible Signal
    P0501 - 35-10 - - - Intermittent
    01249 - Fuel Injector for Cylinder 1 (N30)
    26-10 - Output Open - Intermittent
    16515 - Oxygen (Lambda) Sensor B1 S1: Signal too Low
    P0131 - 35-00 - -
    00532 - Supply Voltage B+
    07-10 - Signal to Low - Intermittent
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 35-10 - - - Intermittent
    16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
    P0116 - 35-00 - -
    01252 - Fuel Injector for Cylinder 4 (N33)
    01251 - Fuel Injector for Cylinder 3 (N32)
    00670 - Throttle Position Sensor (G127)
    27-10 - Implausible Signal - Intermittent
    01250 - Fuel Injector for Cylinder 2 (N31)
    Readiness: N/A
    Address 03 -------------------------------------------------------
    Controller: 4D0 907 379 D
    Component: ABS BOSCH 5 7402
    Coding: 0265108005
    Shop #: BB 37402
    No fault code found.
    Address 08 -------------------------------------------------------
    Controller:  ö ö8 D08
    Note: Excessive Comm Errors
    Skipping Address 15-Airbags
    Address 17 -------------------------------------------------------
    Controller: 8D0 919 033 D
    Component: B5_KOMBIINSTRUMENT D04
    Coding: 00142
    Shop #: WSC 31491
    Address 25 -------------------------------------------------------
    Controller: 4A0 953 234
    Component: IMMO AUZ9Z0S8494413 D76
    Coding: 00000
    Shop #: WSC 00795
    End -------------------------------------------------------
    che ha?
    nello storico dei lavori fatti ha già cambiato turbina ,frizione,catalizzatore(usato da ebay.de),pompa benzina(da ebay.de),motorino avviamento,cilindretto della chiave e macroscopicamente si accende ecc..solo un po con fatica a freddo negli ultimi tempi.
    che sono tutti quelle voci?
    Sembra che abbia problemi a tutti gli iniettori,al climatizzatore(canale8),alla sonda lambda,al sensore della velocità e della temperatura del liquido,alla batteria(è nuova però..),al sensore della posizione dell'accelelratore e al knock sensor che dovrebbe essere il sensore della detonazione.
    Riguardo all'immobilizer dato che ho sostituito il cilindretto il probl è sicuramente derivante da quello.
    Mi affido a voi e alla vostra esperienza;)
    Utente L'avatar di eprom23
    Mar 2009
    a4 2000 TFSI quattro
    ciao il fatto che hai l'impianto gpl puo' comportare una serie di errori,in sintesi i due impianti non possono funzionare contemporaneamente,infatti la centralina dell'impianto gpl esclude il sistema benzina .prova a far funzionare la macchina a benzina fai la scansione errori,fai il reset errori e vede che errori ti visualizza,almeno errori inerenti iniettori dovrebbe cancellarli,che tipo motore monta ? e che tipo centralina motore
    Ultima modifica di eprom23; 10-01-2010 alle 09:07
    Audi lover L'avatar di b1k3
    Nov 2008
    Thanked: 5
    Benevento (BN)
    a3 sportback 2.0 tdi 140
    per tutti questi errori per capire cosa sono vai qui
    http://wiki.ross-tech.com/index.php/Main_Page
    nel search scrivi il numero di ogni errore e ti dà la risposta
    My A3 Sportback --- b1k3 ---
    audi club grigio delfino socio N°07
    MODIFICHE TRAMITE VAG-COM
    Mastaro Fans Club socio N°138
    Mar 2009
    dimenticavo per quanto riguarda il clima pure io nella audi a3 del 97 mi dava troppi errori ma era dovuto dal fatto che avevo aperto la centralina per adattarla alle modifiche nell'installazione del 2din e avevo invertito il flat,ma funzionava regolarmente.
    Feb 2009
    Firenze (FI)
    Audi a4 1.8T
    Predefinito quindi=ì?che devo fare?sulla pagina della ross tech non da grandi indicazioni
    MOTORE AEB...non so come si trova la versione della centralina
    ragazzi...questa vaggata è già resettata...che c'è da fare?
    Cambiare la:
    -Sonda lambda pre cat. (da errore su due sensori...ma sono nella stassa sonda?)
    -Knock sensor g66(connettore blu)
    -Sensore temperatura liquido (G62)
    -Sensore velocità???
    Pulire:
    -il corpo farfallato e Effettuare il riallinamento con il Vag(TBA)
    -Pulire...o addirittura sostituire tutti gli iniettori?
    Bisogna fare questo???
    Nov 2008
    Thanked: 5
    Benevento (BN)
    Citazione Originariamente Scritto da Audi18 Visualizza Messaggio
    Cambiare la:
    Pulire:
    cancellati gli errori quali si ripresentano??
    Feb 2009
    Firenze (FI)
    Audi a4 1.8T
    La stessa...l'ho scritto che questa vaggata è già resettata...questi sono gli errori che si ripresentano dopo la cancellazione...
    Feb 2009
    Firenze (FI)
    Audi a4 1.8T
    ehy???nessuno?
    Ultima modifica di Audi18; 14-02-2010 alle 17:10
    Feb 2009
    Firenze (FI)
    Audi a4 1.8T
    bella rigà:)attendo vostri lumi eheh
    Sep 2008
    A4 Turbo Quattro
    Ciao, ho anche io una B5 Turbo Quattro ma 150 cv, non ti posso aiutare non ho l'impianto GPL, ma levami una curiosità:
    Ricordi mica quanto hai pagato la trasformazione GPL ? tempo fa avevo provato ad informarmi ma mi avevano chiesto una tombola...
    Grazie ciao
