@kobballo
la trasformazione a gpl ha dei costi massimi standard e variano solo in base al fatto se sei un 4 6 o 8 cilindri.
Per Un 4 cilindri l'impianto costa 1850 collaudato al lordo di incentivi per un 6 cilindri 2200...quindi le richieste dovrebbero stare sotto o pari a queste cifre...
Chi chiede di più è da scartare.
faccio un sommario grazie alla pagina degli errori della rosstech http://wiki.ross-tech.com/index.php/...y:Fault_Codes:
00670 - Throttle Position Sensor (G127): Implausible Signal
Possible Symptoms :
-Idle Speed Control inactive
-Increased Idle Speed
-Air Conditioning not working below 2000 RPM
Possible Causes :
-Throttle Body Adaptation not performed
-Throttle Positioner jammed
-Throttle Body jammed
-Wiring faulty
Possible Solutions :
-Perform Throttle Body Adaptation
-Check/Clean Throttle Body
-Check Wiring
16716/P0332 - Knock Sensor 2 (G66): Signal Too Low
Possible Symptoms :
Irregular rpm
Drivebility problems :
-Loss of power
-Engine damage
-Possible Causes
-Circuit G66 short to Ground
-Circuit G66 open
-G66 loose
-G66 damaged
-Control Module damaged
-Tighten Knock Sensor 2 (G66)
-Check wiring and connections
-Check Knock Sensor 2 (G62) and Knock Control
Special Notes
16885/P0501/001281 - Vehicle Speed Sensor: Implausible Signal
Possible Causes :
-Wiring/Connectors from/to Vehicle Speed Sensor faulty
-Vehicle Speed Sensor faulty
Possible Solutions:
-Check Wiring/Connectors from/to Vehicle Speed Sensor
-Check Vehicle Speed Sensor
16515/P0131/000305 - Oxygen (Lambda) Sensor B1 S1: Signal too Low
Possible Causes :
-Wiring to Oxygen (Lambda) Sensor Bank 1 Sensor 1 faulty
-Oxygen (Lambda) Sensor Bank 1 Sensor 1 faulty
-Check Wiring to Oxygen (Lambda) Sensor Bank 1 Sensor 1
-Check Oxygen (Lambda) Sensor Bank 1 Sensor 1
-Perform Aging Check
00532 - Supply Voltage B+: Signal too Low
Possible Causes :
-Wiring/Connectors from/to Control Module faulty
-Power Supply (Battery/Generator) faulty
-Check/Repair Wiring/Connectors from/to Control Module
-Check Power Supply (Battery/Generator)
Special Notes :
When found in an individual control module, it's most likely a local source (e.g. wiring/connectors).
When found in multiple control modules at the same time, it's most likely a common source (e.g. ground spot, battery, generator).
Intermittent codes are often stored during low outside temperature when the battery capacity goes down and may be ignored.
Common with 16946/P0562/001378 - System Voltage: Too Low stored in other control modules.
This feature search for unusual (spontaneous) combustion. The sensor detects unusual vibrations and based on that it generates a voltage. Is this voltage outside a certain limit a dtc will be set.
16500/P0116/000278 - Engine Coolant Temp. Sensor (G62): Implausible Signal
Possible Symptoms :
-Starting the engine when engine is warmish or warm, idle rpm immediately is 1200 - 3000 rpm.
-Diesel: an indication is extreme long time burning time of the glow indication light.
-With all engine temperatures seldom idle rpm will vary between 900 - 1000 rpm.
-With engine warm (90 °C) the engine temperature suddenly drops (70 °C) and slowly comes back to 90 °C.
Possible Causes :
-Wiring and/or connections faulty
-Engine Coolant Sensor (G62) faulty
-Replace Engine Coolant Sensor (G62)
Special Notes :
In MY 1995-2002 (?) in Europe at VW-cars the G2/G62 had the bad reputation of breaking down often. The default G2/G62 is black and all replacements are green.
Check if the correct Coolant Fan Control Module/Relay is installed (check part number using parts catalogue)!
Questi non ci sono nella lista...?
00635 - Oxygen (Lambda) Sensor Heating: Before CAT
26-00 - Output Open
01249/50/51/52 - Fuel Injector for Cylinder 1-2-3-4 (N32)
26-10 - Output Open - Intermittent
Ultima modifica di Audi18; 26-02-2010 alle 06:13
Oleeee ora si è aggiunto anche questo errore!In compenso ho appurato che sia a gpl che a benza gli errori sono gli stessi.
16705 - Engine Speed Sensor (G28): Implausible Signal
P0321 - 35-10 - - - Intermittent
Possible Symptoms
Engine shuts off
Engine doesn't start
Speedometer inoperative
Glow Plug Indicator Lamp (K29) flashes
Possible Causes :
Engine Speed Sensor (G28) loose
Engine Speed Sensor (G28) faulty
Check Engine Speed Sensor (G28)
Special Notes :
The Engine Speed Sensor (G28) is also used as a reference sensor for the crankshaft position and correlates with the Camshaft Position Sensor Bank 1 (G40) and Camshaft Position Sensor Bank 2 (G163).
When found in a VW Golf/Jetta (1J/9M) or Audi A3 (8L) with 1.9l TDI-PD (AXR), check TPI 2007067 which explains issues with electro mechanical interference. A modification to the wiring will fix this problem, extensive details can be found in the named TPI. Even though this TPI was originally released for VW Golf/Jetta (1J/9M), a customer of ours came across the same issue on an Audi A3 (8L).
When found in a 2004 VW Golf, Jetta, or New Beetle with 1.9l TDI-PD (BEW), check for TSB number 97-05-03 or 97-05-04 calling for a flash update to the ECU and a secondary ground installation. This applies if ECU software version is below 6328; current software version should be 7000 or higher.
UDITE UDITE: sbagliavo a fare il reset!
andando ad eliminare gli errori direttamente dai blocchi quello che è rimasto a motore sia pspento che acceso a benzina o gpl è questo:
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 8D0 907 557
Component: 1,8l R4/5VT MOTR HS D05
Coding: 04001
Shop #: WSC 00000
1 Fault Found:
26-00 - Output Open
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 4D0 907 379 D
Component: ABS BOSCH 5 7402
Coding: 0265108005
Shop #: BB 37402
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8D ö 8D0 8
Component: 8D0820ö8D
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 919 033 D
Component: B5_KOMBIINSTRUMENT D04
Coding: 00142
Shop #: WSC 31491
Address 25 -------------------------------------------------------
Controller: 4A0 953 234
Component: IMMO AUZ9Z0S8494413 D76
Coding: 00000
Shop #: WSC 00795
End -------------------------------------------------------
Sembrerebbe quindi un problema di sonda lambda...+i gli errori sul climatronic(sono secondo me riconducibili al fatto che uso la usb e non la seriale http://www.ross-tech.com/vag-com/faq_1.html#1.5 )
tra l altro è proprio l'errore che non c'è sulla lista della ross-tech
