Salve
presento la macchina a4 1.8t del '95 con 212413 km ha impianto a gas brc da quando aveva circa 60000km ovvero 9 anni fa...ho già fatto il reset degli errori e mi rimane questo:
VAG-COM Version: Release 311.2-N
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 8D0 907 557
Component: 1,8l R4/5VT MOTR HS D05
Coding: 04001
Shop #: WSC 00000
12 Faults Found:
00635 - Oxygen (Lambda) Sensor Heating: Before CAT
26-00 - Output Open
16716 - Knock Sensor 2 (G66): Signal too Low
P0332 - 35-10 - - - Intermittent
16885 - Vehicle Speed Sensor: Implausible Signal
P0501 - 35-10 - - - Intermittent
01249 - Fuel Injector for Cylinder 1 (N30)
26-10 - Output Open - Intermittent
16515 - Oxygen (Lambda) Sensor B1 S1: Signal too Low
P0131 - 35-00 - -
00532 - Supply Voltage B+
07-10 - Signal to Low - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
P0116 - 35-00 - -
01252 - Fuel Injector for Cylinder 4 (N33)
01251 - Fuel Injector for Cylinder 3 (N32)
00670 - Throttle Position Sensor (G127)
27-10 - Implausible Signal - Intermittent
01250 - Fuel Injector for Cylinder 2 (N31)
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 4D0 907 379 D
Component: ABS BOSCH 5 7402
Coding: 0265108005
Shop #: BB 37402
No fault code found.
Address 08 -------------------------------------------------------
Controller: ö ö8 D08
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 919 033 D
Component: B5_KOMBIINSTRUMENT D04
Coding: 00142
Shop #: WSC 31491
Address 25 -------------------------------------------------------
Controller: 4A0 953 234
Component: IMMO AUZ9Z0S8494413 D76
Coding: 00000
Shop #: WSC 00795
End -------------------------------------------------------
che ha?
nello storico dei lavori fatti ha già cambiato turbina ,frizione,catalizzatore(usato da ebay.de),pompa benzina(da ebay.de),motorino avviamento,cilindretto della chiave e macroscopicamente si accende ecc..solo un po con fatica a freddo negli ultimi tempi.
che sono tutti quelle voci?
Sembra che abbia problemi a tutti gli iniettori,al climatizzatore(canale8),alla sonda lambda,al sensore della velocità e della temperatura del liquido,alla batteria(è nuova però..),al sensore della posizione dell'accelelratore e al knock sensor che dovrebbe essere il sensore della detonazione.
Riguardo all'immobilizer dato che ho sostituito il cilindretto il probl è sicuramente derivante da quello.
Mi affido a voi e alla vostra esperienza;)
