Figooooo....
Cmq anche a mè funzionano tutti e due i siti...3° raccomandato
Figooooo....
[B][SIZE=3]IL MIGLIOR DISPREZZO E' LA NON CURANZA...[/SIZE][/B]
Salve, mi sono iscritto e presentato questa mattina, ho subito fatto la decodifica degli optionals presenti sulla mia A4 2013 di importazione e ho questo:
7D5 = DVD player
E0A = No special edition
4UF = Drivers and front passenger air bag with front passenger air bag deactivation
5SL = Left exterior mirror: aspherical
6TS = Right exterior mirror: aspherical, large viewing field
1KW = Disc brakes, rear
J0B = 520 A (92 Ah) battery
1LT = Disc brakes, front
1AT = Electronic stabilization program (ESP)
1BA = Standard suspension/shock absorption
3FA = Without roof insert (standard roof)
5M1 = Stripes (design 6)
7X4 = Park distance control, front and rear
F0A = No special purpose vehicle, standard equipment
= code not found :-(
9G2 = Alternator 100-150 A
0G1 = Gearshift lever
0YH = Weight range 8 installation control only, no requirement forecast
0JG = Weight category front axle weight range 7
TM4 = 4-cylinder diesel engine 2.0 l unit 03L.M
3NZ = Rear seat bench unsplit, backrest split folding
8BP = Bi-functional headlight with gas discharge lamp
U2A = Instrument insert with km/h speedometer,radio-controlled clock, tachometer and trip odometer
QZ7 = Power steering
2ZQ = Leather trimmed multi-function steering wheel for air bag system
8Q3 = Automatic headlight-range adjustment dynamic (self-adjusting while driving)
9Q8 = Multi-function display/on-board computer
8Z5 = Not hot country
D90 = 4-cyl. turbo dies. eng. 2.0 l/88 kW (4V)TDI common rail Base engine is TH3/TW1/TQ4/TM4
7T6 = Navigation system (MID)
C5Q = Alloy wheels 7.5J x 17
7K6 = Flat tire indicator
4X4 = Side air bag, front and rear with curtain air bag
2K1 = Reinforced bumpers
3L3 = Manual height adjustment for front seats
4KC = Side and rear windows in heat-insulatingglass
3Y0 = Without roll-up sun screen
4K4 = Radio remote controlled central locking
5D7 = Carrier frequency 868 MHz without panic button
1SA = Without additional front underbody guard
7MJ = Emission standard EU5 plus
Q1A = Standard front seats
4GF = Windshield in heat-insulating glass
In particolare mi chiedo cosa significhi: Not Hot Country (infatti viene dalla Germania)
Grazie per l' aiuto
Anche la mia arriva dalla germania ed ha lo stesso codice,che tradotto sarebbe "Paese non a temperature elevate". Ma non ho idea cosa voglia dire...
Giorgio
ah che bello
vedo che funziona ancora i link postati all'epoca
bene bene
utilissimo...
ragazzi per caso sapete qul'è il codice per indicare le sospensioni s-line di serie???
www.erwin.audi.com
è un sito ufficiale audi a pagamento, ti registri con carta di credito e ti mandano la fattura via mail.
Costa 5 euro per 1 ora di consultazione, 20 euro per un giorno intero e poi ci sono altre quote di "abbonamento" più lungo, fino a 1 anno (non mi ricordo tutte le tariffe di preciso, è molto tempo che non uso più quel sito).
Nota importante: la ricerca si fa col numero di telaio.
Quindi i dati e gli schemi sono sicuramente riferiti alla tua macchina, in modo univoco. Mica un modello simile...
Sono precisissimi, sui tedeschi!
5 euro per 1 ora, son spesi bene! Puoi scaricare mille cose (manuali di officina, tabelle di manutenzione, ecc), con 1 ora di tempo, se hai una adsl che funziona bene!
Nella sezione "dati di base" del veicolo, trovi tutti i codici degli accessori (sono molte pagine. Nel libretto service c'è solo un riassunto, cioè pochi codici), poi trovi il codice della vernice della carrozzeria, il codice-colore dei tessuti interni ecc ecc.
Quei pochi euro sono spesi bene, secondo me.
www.erwin.audi.com
I prezzi di listino del sito possono essere cambiati, controllate bene.
Le tariffe sono definite "flatrate".
Il sito ha pure la lingua italiana e ti guida con precisione nei vari passaggi (registrazione, password ecc).
È Impossibile sbagliare.
credo che i veicoli destinati all'asia o all'africa, dove il clima è molto caldo/molta umidità, abbiano radiatori più grandi o olio più resistente alle alte temperature ecc.
Se non ricordo male, in cina, il richiamo sui cambi automatici stronic 7 marce, è stato "ufficialmente giustificato" con il meteo/condiz ambientali: audi sostiene che il caldo e l'umidità abbiano messo in crisi l'olio di quel cambio automatico (che viene definito "a secco", quindi di olio ne ha dentro una piccola quantità, e quindi si surriscalda alla svelta).
Con il richiamo hanno messo un altro tipo di olio.
Sarà vero? Oppure è la solita balla inventata dalle conce per rabbonire o zittire il cliente, e "salvare la faccia" di audi?
ciao da Paolo
7D5 = DVD player
4UE = Air bag for driver and front seat passenger
6XE = Exterior mirrors: electrically foldable and electrically adjustable/heated
5RU = Right exterior mirror: convex (large viewing field)
J0Z = Battery 520 A (110 Ah)
1AS = Electronic stabilization program (ESP)
1BE = Sports suspension/shock absorption
3FU = Big roof system
5TE = Decorative aluminum inserts
8GU = Alternator 140 A
0G7 = Tiptronic
0YJ = Weight range 9 installation control only, no requirement forecast
0JF = Weight category front axle weight range 6
TH3 = 4-cylinder diesel engine 2.0 L unit 03L.B
X2D = National sales program Luxembourg
1N1 = Power steering
1XX = Leather trimmed multi-function sports steering wheel w/ Tiptronic
D92 = 4-cyl. turbo dies. eng. 2.0 l/105 kW 4V TDI common rail Base engine is TH3/TG3/TL4/TM4/TP4
CQ8 = Alloy wheels 7.5J x 17
7K0 = Without tire pressure warning light
VW1 = Side windows tinted green, from B-pillarto rear window gray tinted safety glass
7MG = Emission standard EU5
Q1D = Sports front seats
