Originariamente Scritto da
bn86
A: Speaker Connecter (front passive speakers)
altoparlanti passivi anteriori, ok...
1 - N.C. (NC = Not Connected)
2 - Right Front (+) (ok)
uno a destra
3 - Left Front (+) (ok)
e uno a sinistra... bene...
4 - N.C.
5 - N.C.
6 - Right Front (-) (ok)
7 - Left Front (-) (ok)
C: EXT Control Connector (For Bose or Non-Bose Amp, telephone interface)
questo serve per un ampli... avevo sentito parlare di un ampli per gli altparlanti posteriori, è questo?
1 - **MIC IN (-) (Used for OEM Bluetooth kit when SDS is factory installed)
2 - *RFSL (Analog reverse signal)
3 - Line Out FL (front left audio signal)
segnale audio anteriore sinistro? ma non c'erano gli altoparlanti passivi davanti? dove va sto cavo?
4 - **MIC Out (-) (Used for OEM Bluetooth kit when SDS is factory installed)
5 - Line Out RL (rear left audio signal)
segnale posteriore sinistro
6 - TEL NF IN (-) (Telephone speaker negative input)
7 - **MIC IN (+) (Used for OEM Bluetooth kit when SDS is factory installed)
8 - Line Out GND (audio ground)
9 - Line Out FR (front rear
(forse 'right'?) audio signal)
sarà l'anteriore destro?
10 - **MIC Out (+) (Used for OEM Bluetooth kit when SDS is factory installed)
11 - Line Out RR (rear right audio signal)
segnale posteriore destro, ma poi che razza di segnale sarà mai questo? si può considerare PRE? è a gamma intera o ci sono dei filtri di qualche tipo?
12 TEL NF IN (+) (Telephone speaker positive input)
*Reverse wire: C5 A6, B5 A4/S4 and D2 A8 use an analog signal for reverse. Most harnesses won't have this connection available...so you will need to add a female pin/wire (part#000-979-009) and route it to reverse signal near the drivers' side lower dash area
**SDS (Speach Dialog System) will need to be factory installed (found in B7 A4/S4 for example) in order to take advantage of these mic in/out wires. If no SDS, then you will connect the mic wires directly between your OEM bluetooth kit and the BT mic that you install near your sunroof controls.
D: Power Connector
9 - CAN-H (CANbus High signal)
cacchio è sta robba?
10 - CAN-L (CANbus Low signal)
11 - TEL-Mute (Telephone mute connection)
12 - Kl.31 (Primary ground connection)
13 - U14 ST DSP (Radio On) (Provides a switched ignition-out source to turn on rear amplifier (bose too) or "remote" lead for an
aftermarket amp)
*14 - DWA-GND (Alarm ground)
15 - Kl.30 (Constant 12V power source)
e questa è l'alimentazione...
16 - U14R-1 (N.C.)
