FAQ Audi Rs4 b5 - Tutte le migliori modifiche a portata di click
FAQ AUDI RS4 b5 2000/2001 2,7 V6 biturbo
Motore:
Kit turbo
Tial Kit:
-5800$ turbine+hardware
-2300$ candele/iniettori 630cc/mappa/X1intake/85mm MAF housing/Rs4 accordion hose
-Bosh 044 pompa benzina (400$)
Links:
http://www.tialsport.com/prod_tk_Audi.htm
http://forums.audiworld.com/s4/msgs/2824633.phtml
http://www.avivascience.com/g1/main.php?g2_itemId=1742
GenJDM:
-7900$ turbine+hardware+collettori tubolari+wastegates(Tial V44)+downpipes
GT2554 27lb turbo 270hp all GT25ss - 53mm turbine wheel
GT2560 33lb turbo 330hp
GT2854 27lb turbo 270hp all the GT28ss - 53.8 turbine wheel
GT2860-7 31lb turbo 310hp
GT2860-5 36lb turbo 360hp
GT2860rs disco potato 36lb turbo the S stands for special=larger compressor cover
Links:
http://www.audizine.com/forum/showth...ghlight=genjdm
http://www.audizine.com/forum/showth...=progress+pics
JHM RS6 Bolt-on Kit:
-3450$ Turbine RS6 modificate+flange per i downpipes
Links:
http://shop.jhmotorsports.com/produc...&productId=135
Rigenerazione K04 originali:
-Coppia di giranti da sostituire alle originali una volta usurate. Si mantiene la chiocciola vecchia. 600€ circa e le turbine tornano nuove.
Links:
http://cgi.ebay.com/ebaymotors/RS4-k...spagenameZWD1V
Iniettori
034 Motorsport, 630cc/ora. 72$ l'uno
-http://www.034motorsport.com/product_info.php?products_id=213&osCsid=iomgg9k6kpfurum6ot57r4gru0
Pompa Benzina
034 Motorsport, Pompa Bosh 044. 425$
-http://www.034motorsport.com/product_info.php?products_id=456
Bielle
Rosten:
http://rosten-performance.com/
* 2 piece forged from 40CrNiMo steel
* Shoot peened and heat treated
* Comes with ARP 2000 bolts and assembly instructions
* Weight is 560 gram with a tolerance of +-1 gram
* Price complete set 650 EURO
Pauter:
http://www.pauter.com/4340_rods.htm
Supporti
Snub Mount:
-034 Motorsport, Snub Mount+gabbia 65$
http://www.034motorsport.com/product...roducts_id=560
-APR Snub Mount 39$
http://www.goapr.com/Audi/products/engine_mount.html
Supporti Motore:
-034 Motorsport, 95$ l'uno
http://www.034motorsport.com/product...roducts_id=772
Scarico cat-back
Quattro GMBH – terminale originale/centrale cilindrico inox/terminali neri
Supersprint/Milltek – scarichi in inox, preferibile il doppio tubo da downpipes a terminale
Downpipes
“Piggies” - Eliminazione dei pre-cat sui DownPipes originali, con riposizionamento della seconda lambda.
- http://www.audiworld.com/tech/eng75.shtml
Nella guida sono illustrati i DownPipes di una S4, ma il processo è identico.
Intercoolers
DUH FMIC kit:
-Intercooler+radiatori olio/sterzo+ventola supplementare+tubazioni+hardware
http://www.duhengineering.com/fmic/rs4_09.html
(non è piu in produzione, si trova solo usato)
Ebay FMIC kit:
- Intercooler+tubazioni+hardware 399$
http://cgi.ebay.com/ebaymotors/_Car-...3756.m14.l1318
(ventola supplementare by VAST:http://vastperformance.com/shop/prod...products_id=52)
Evolution Racewerks:
-2 SMIC's+convogliatori aria 1350$+200$ Hanno bisogno di alcune modifiche alle tubazioni per un montaggio corretto. Non sono insomma un diretto bolt-on.
http://www.evolutionracewerks.com/product.php?prodid=36
Wagner Tuning:
-2 SMIC's+convogliatori aria 1990€
http://wagner-tuning.de/produkte/llkRS4.php
Tubazioni Siliconiche per IC originali:
-Set di 4 tubazioni siliconiche per RS4 SMICs. 240$
http://www.034motorsport.com/product...roducts_id=388
Retine laterali paraurti anteriore senza fendinebbia (+7cv)
- www.bhv-handel.de
Filtro aria
K&N a Pannello:
cod 33-2125 prezzo 79€
Pop-off
Forge:
-007P x2
http://www.forgemotorsport.com/conte...oduct=FMCL007P
-kit di regolazione x2
http://www.forgemotorsport.com/conte...roduct=FMDVTUN
OEM Audi TT 225hp 710N x2
Audi part no. 06A 145 710N
After-Run pump mod
http://www.audiworld.com/tech/eng59.shtml
021 919 369 - Thermo-switch
N 903 168 02 – O-ring
Viene sostituito il sensore della pompa secondaria del circuito di raffreddamento, che si accenderà così ogni qual volta verrà spenta l'auto a caldo, facendo circolare in senso contrario il liquido refrigerante per 10minuti.
Manometro Turbo
Podi.ca – Manometro sul piantone dello sterzo
http://podi.ca/Packages.aspx
AWE Tuning (o DIY-DoItYourself)
http://www.awe-tuning.com/pages/shar...CenterGaugePod
Trasmissione:
Frizione
Frizione ceramica/organica VASTPERFORMANCE.COM
http://vastperformance.com/shop/prod...products_id=62
Volano
Volano Monomassa VASTPERFORMANCE.COM
http://vastperformance.com/shop/prod...products_id=61
Kit di Rigenerazione della trasmissione
JHMotorsport, 1200$
http://shop.jhmotorsports.com/product.sc?productId=74
Supporti
Supporti trasmissione:
-034 Motorsport, 60$ l'uno
http://www.034motorsport.com/product...roducts_id=773
Supporti differenziale posteriore:
-034 Motorsport, 249$ Due durezze: Strada/Pista
http://www.034motorsport.com/product...oducts_id=1214
-034 Motorsport, 54,50$
http://www.034motorsport.com/product...ducts_id=14054
Drivetrain Stabilizer Bar:
-Autospeed Performance, 250$
http://www.autospeed.us/store.php?cr...on=show_detail
-Supporto della DTS rinforzato by Energy Suspension, costo $25.17+$40.00 (U.S. Priority Mail) = $65.17
Per ordinarlo, codice prodotto Energy Suspension 3-1108G / email: [email protected]
Cambio
Short Shifter:
-JHMotorsport, 250$ + opzioni (asta accorciata, molle retromarcia piu dure)
http://www.jhmotorsports.com/shop/ca...&products_id=3
Solid Linkage Upgrade:
-JHMotorsport, 190$ - sostituisce l'originale “snodo” in plastica, con un uniball.
http://www.jhmotorsports.com/shop/ca...&products_id=8
Delrin Stabilizer Bushing:
-JHMotorsport, 30$ - riduce il gioco della bielletta di supporto dello shifter sulla trasmissione
http://www.jhmotorsports.com/shop/ca...&products_id=7
Shifter Centering Spring:
-JHMotorsport, 80$ - indurisce il movimento dx/sx in folle del cambio, aiutando la cambiata 2°/3°.
http://www.jhmotorsports.com/shop/ca...products_id=12
Weighted Delrin Knob (Pomello cambio):
-JHMotorsport, 65$ - pesa 2,5 volte l'originale, facilitando l'innesto delle marce.
http://www.jhmotorsports.com/shop/ca...products_id=75
Sospensioni:
Assetto
KW V3:
-Molle progressive,olio bassa pressione,regolabile in precarico/compressione/estensione
http://www.balancemotorsport.co.uk/p...ecnumber=59146 1500 Euro circa
Bilstein PSS9:
-Molle progressive,olio alta pressione,regolabile in precarico e in compressione-estensione in 9 posizioni
Barre anti-rollio
Hotchkis Performance:
-35mm anteriore fissa/22mm posteriore regolabile in 2 posizioni+supporti di rinforzo + silent blocks
http://www.hotchkis.net/p-731-extrem...y-bar-set.aspx
(Per ordinare, codice Hotchkis 22801 email: [email protected] 425 $ + sped in Italia)
Leveraggi della barra anti-rollio posteriore:
-Originali in plastica, questi in metallo. Sono pezzi di ricambio OEM Audi RS2. 78€ l'uno.
8A0 505 465 D (sx) / 8A0 505 466 D (dx)
Silent-Blocks POWERFLEX:
http://www.powerflex.co.uk/products....=11&submit1=GO
Kit completo meno i silent blocks delle barre antirollio 330€ - chiedere di James
- [email protected]
Impianto Frenante:
Anteriore
Kit completo OEM Audi Rs4 b7
-Dischi 365x34mm forati scomponibili, pinze 8 pistoni, pasticche OEM e tubazioni
www.bhv-handel.de
Ebay.de
-Dischi 365x34mm forati scomponibili (Rs4 b7), qualsiasi pinza a 4/6/8 pistoni purchè radiale+supporti(260€) artigianali da farsi fare su misura
Copridischi+Convogliatori aria per i dischi anteriori – Provengono da VW Phaeton 6.0 W12
-Copridischi 3D0 615 311 C / 3D0 615 312 C
-Convogliatori 3D0 615 447 D / 3D0 615 448 D
-Viteria N 102 849 02 (8x) / N 908 429 03 (8x)
Posteriore
-Dischi forati Quattro GMBH+pasticche sportive
-Kit completo StopTech 328x28mm + pinza 4 pistoni + pinze freno a mano separate
-Kit completo Mov'it 322x24 + pinza 4 pistoni + pinze freno a mano separate
-Kit su misura con dischi a piacimento + pinze 4 pistoni + pinze freno a mano separate (Audi R8 per es.)
......................TO BE CONTINUED
Lo so ragazzi, sono completamente suonato.
Stasera non avevo voglia di uscire, e viste le numerose telefonate ricevute ultimamente per richieste di informazioni, ho tirato su un FAQ sul quale chiunque possa trovare almeno una parte delle risposte che cerca.
Verrà aggiornato costantemente (anche grazie a vostre segnalazioni), e spero sia gradito a tutti.
E ORA, buonanotte!
PS. Te lo avevo promesso, Ste..
Ultima modifica di andream88; 17-09-2008 alle 20:04
Motivo: Unione automatica messaggi multipli
Utente
Grande andrea!!! non puoi farlo anche per la b7??????? ehehe daiiiiii
Grandissimo Andrea , lo metto in rilievo !!!
Eheheh Charlix mi dispiace, ma della B7 so poco o nulla.
E sinceramente credo ci sia anche poco da sapere a causa di:
- modificabilità a livello di motore vicina allo 0
- livello dell'autotelaio MOLTO alto (rispetto alla B5) e fondamentalmente privo di difetti
ERGO, goditela e tu che puoi, non metterci le mani!!!
E grazie ste per averla messa in rilievo
Ultima modifica di andream88; 16-07-2008 alle 21:32
Utente
eheh.. ma secondo te andre per lo scarico della b7 dove andresti?? senza spendere i 4800 per i milltek o simili?? io mi trovo in difficolta.. alcuni mi hanno detto di andare all audi sport italia ma secondo me ti spennano anche li..
Sentirei prima di tutto i ragazzi di ATK.
Fanno scarichi meravigliosi, su misura, e a prezzi umani.
In caso fosse ancora troppo, mi farei consigliare da loro il COME farlo e lo farei fare da un "marmittarolo" della mia città. Alla fine sono 2 tubi di acciaio inox.......
Supersprint, con tutto il rispetto, ha dei prezzi ALLUCINANTI.
