quindi hai inserito e risolto?
Per quanto riguarda l'allineamento batteria si. C'è un altro problema, anello ottico aperto, che ancora non riesco a risolvere.
anello ottico aperto e a cosa si riferisce
Questi sono i risultati vag dei diversi bypass con jumper
Jumper sulla centralina mmi:
Thursday,08,March,2012,18:26:23:10074
VCDS Version: Release 10.6.5
Data version: 20110930
Chassis Type: 4F0
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 42 46 47 4F 52 53 55 56
61 62 72 76 77
VIN: WAUZZZ4F85N039782
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: Cannot be reached 1100
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Cannot be reached 1100
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Cannot be reached 1100
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F0 910 401 L HW: 4F0 907 401 A
Component: 3.0L V6TDI 0000AG 0020
Revision: --H01--- Serial number:
Coding: 0011772
Shop #: WSC 02334 785 00200
VCID: 2545F5A7957A
8 Faults Found
16785 - EGR System: Insufficient Flow
P0401 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
RPM: 1680 /min
Torque: 105.3 Nm
Speed: 41.4 km/h
Duty Cycle: 61.8 %
Duty Cycle: 20.9 %
Mass Air / Rev.: 446.5 mg/str
Duty Cycle: 38.3 %
Mass Air / Rev.: 282.0 mg/str
18348 - Powertrain Databus: Missing Message from Control Module for Battery Monitoring
P1940 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 167.7 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 12.62 V
(no units): 0.0
Temperature: 85.5°C
18034 - Powertrain Data Bus: Missing Message from TCU
P1626 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 167.7 Nm
Speed: 0.0 km/h
(no units): 24.0
Voltage: 12.62 V
Torque: 581.4 Nm
Temperature: 85.5°C
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 167.7 Nm
Speed: 0.0 km/h
(no units): 24.0
Voltage: 12.62 V
(no units): 0.0
Temperature: 85.5°C
18044 - Powertrain Data Bus: Missing Message from Airbag Controller
P1636 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 167.7 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 12.62 V
Bin. Bits: 11000100
Torque: -191.1 Nm
Temperature: 85.5°C
18036 - Powertrain Data Bus: Missing Message from Steering Angle Sensor
P1628 - 000 - - - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 167.7 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 12.62 V
Bin. Bits: 11000100
Bin. Bits: 00000001
18043 - Powertrain Data Bus: Missing Message from A/C Controller
P1635 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 167.7 Nm
Speed: 1.1 km/h
Duty Cycle: 1.0 %
Voltage: 12.62 V
Bin. Bits: 11000100
Bin. Bits: 01110000
18045 - Powertrain Data Bus: Missing Message from Electric Load Controller
P1637 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 167.7 Nm
Speed: 1.1 km/h
(no units): 3.0
Voltage: 12.62 V
Temperature: -21.6°C
Temperature: 23.4°C
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F0 910 156 H HW: 09L 927 156
Component: AG6 09L 3.0lTDI RdW 0080
Revision: --H01--- Serial number: 0046369
Coding: 0000001
Shop #: WSC 02327 785 00200
VCID: 285BFC93E268
1 Fault Found
18274 - Powertrain Data Bus: Missing Messages
P1866 - 000 - - - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 25.0
Temperature: 80.0°C
T.B. Angle: 60.0°
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 E HW: 4F0 614 517 A
Component: ESP8 quattro H03 0010
Revision: 00000000 Serial number: 00000000000000
Coding: 0004488
VCID: 2647F2ABE87C
No fault code found.
Address 05: Acc/Start Auth. Labels: None
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H30 0220
Revision: 31050601 Serial number: 10600300054937
Coding: 0000003
Shop #: WSC 00071 264 64773
VCID: E3C12BBF5BCE
Part No: 4F0 910 131 E
Component: FBSAUDIC6 EZS H43 0070
Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H35 0040
Address 07: Control Head
Cannot be reached
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F
Component: KLIMABETAETIGUNGH11 0110
Revision: 00000023 Serial number: 00000000046607
Coding: 0008342
VCID: DBB1135F63BE
Jumper prima su ampli e poi su radio (stessi risultati) in questi casi non da malfunction su gateway; il malfunctiomn abs è uscito perchè ho ricaricato la batteria e poi ricollegata, adesso è sparito:
Friday,09,March,2012,16:11:00:10074
Chassis Type: 4F0
61 62 72 76 77
03-ABS Brakes -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
Coding: 0011772
VCID: 2545F5A7957A
8 Faults Found
Freeze Frame:
RPM: 1680 /min
Torque: 105.3 Nm
Speed: 41.4 km/h
Duty Cycle: 61.8 %
Duty Cycle: 20.9 %
Duty Cycle: 38.3 %
18348 - Unlicensed Version. Not all DTCs
P1940 - 001 - will be decoded. - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 167.7 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 12.62 V
(no units): 0.0
Temperature: 85.5°C
18034 - Unlicensed Version. Not all DTCs
P1626 - 002 - will be decoded. - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 167.7 Nm
Speed: 0.0 km/h
(no units): 24.0
Voltage: 12.62 V
Torque: 581.4 Nm
Temperature: 85.5°C
Freeze Frame:
RPM: 0 /min
Torque: 167.7 Nm
Speed: 0.0 km/h
(no units): 24.0
Voltage: 12.62 V
(no units): 0.0
Temperature: 85.5°C
18044 - Unlicensed Version. Not all DTCs
P1636 - 001 - will be decoded. - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 167.7 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 12.62 V
Bin. Bits: 00000000
Raw, Form. N/A: 000 000 000
18036 - Unlicensed Version. Not all DTCs
P1628 - 000 - will be decoded. - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 167.7 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 12.62 V
Bin. Bits: 11000100
Bin. Bits: 00000001
Freeze Frame:
RPM: 0 /min
Torque: 167.7 Nm
Speed: 1.1 km/h
Duty Cycle: 1.0 %
Voltage: 12.62 V
Bin. Bits: 11000100
Bin. Bits: 01110000
18045 - Unlicensed Version. Not all DTCs
P1637 - 002 - will be decoded. - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 167.7 Nm
Speed: 1.1 km/h
(no units): 3.0
Voltage: 12.62 V
Temperature: 23.4°C
Readiness: N/A
Revision: --H01-- Serial number: 0046369
Coding: 0000001
VCID: 285BFC93E268
1 Fault Found
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 25.0
Temperature: 80.0°C
T.B. Angle: 60.0°
Coding: 0004488
VCID: 2647F2ABE87C
1 Fault Found
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 31
Mileage: 171274 km
Time Indication: 0
Date: 2005.02.01
Time: 12:54:00
Freeze Frame:
Hex Value: 0x0280
Hex Value: 0x00A2
Hex Value: 0x0000
Hex Value: 0x0099
Hex Value: 0x00FF
Ciao
Maurizio
ciao donegall
quindi che bisogna mettere per configurare la batteria?
Se è una batteria con 100 ah ed 830 di spunto:
4F0915105C
2502160104
Varta
Ciao
Ciao a tutti.
Nella mia 4F del 2007 2.0 TDI, ho una batteria Vattelappeschen.
Dovendola sostituire, chi sa dirmi i valori di corrente e spunto originali?
AUDI A6 2.0 TDI AVANT 140 CV
Carissimo, il mio consiglio è di montare una Varta, le trovi anche sulla baia a prezzi accessibilissimi, che è compatibilissima con la codifica della centralina.
Ora ti cerco le caratteristiche
Max
Postami il codice della batteria che trovi su una qualsiasi vaggata alla centralina 61 "Battery" per vedere se monti il tipo con indicatore stato di carica.
Questa funzione l'hai mai attivata via VAG?
c'è una discussione nella sezione obd-diagnosi-vagcom.
È in evidenza in alto, quelle con fondo azzurro.
Nella discussione viene spiegato cosa devi fare, nella centralina 61.
I codici sono semplicemente il costruttore (il vag ti propone una lista con varie marche) e il numero di matricola della batteria (che è stampato sull'etichetta).
È più facile fare il lavoro che descriverlo a parole.
ciao da Paolo
