Aiuto su codici errori
Ciao a tutti!
Sono un utente che scrive poco ma legge tutto!
Ho fatto una diagnosi e si sono evidenziati degli errori che vorrei, con il vostro aiuto, comprendere un po' meglio.
Qui di seguito riporto il log...
Thursday,02,August,2012,13:08:14:10074
VCDS Version: Release 10.6.4
Data version: 20110418
****************Address 01: Engine****** Labels: Redir Fail!
Control Module Part Number: 4F0 910 402 E****HW: 4F0 907 401 C
**Component and/or Version: 3.0L V6TDI**G000AG**0030
********** Software Coding: 0011372
************Work Shop Code: WSC 02334 785 00200
**********************VCID: 1F49E74FB72D
5 Faults Found:
001025 - EGR System: Insufficient Flow
************** P0401 - 002 - Lower Limit Exceeded - Intermittent
************ Freeze Frame:
********************Fault Status: 00110010
********************Fault Priority: 0
********************Fault Frequency: 2
********************Mileage: 137534 km
********************Time Indication: 0
********************Date: 2012.07.31
********************Time: 16:46:06
********************RPM: 1848 /min
********************Torque: 167.7 Nm
********************Speed: 104.2 km/h
********************Duty Cycle: 59.8 %
********************Duty Cycle: 20.9 %
********************(no units): 253.8
********************Duty Cycle: 18.1 %
005658 - Glowplug for Cylinder 1 (Q10): Open Circuit
************** P161A - 001 - Upper Limit Exceeded
********************Fault Status: 01110001
********************Fault Frequency: 1
********************Mileage: 137551 km
********************Date: 2012.08.02
********************Time: 06:36:00
********************RPM: 882 /min
********************Torque: 78.0 Nm
********************Speed: 0.0 km/h
********************Duty Cycle: 1.0 %
********************Voltage: 13.60 V
********************Duty Cycle: 24.9 %
********************Temperature: 26.1°C
005659 - Glowplug for Cylinder 2 (Q11): Open Circuit
************** P161B - 001 - Upper Limit Exceeded
005660 - Glowplug for Cylinder 3 (Q12): Open Circuit
************** P161C - 001 - Upper Limit Exceeded
005661 - Glowplug for Cylinder 4 (Q13): Open Circuit
************** P161D - 001 - Upper Limit Exceeded
Readiness: 0 0 0 0 0
So per certo che gli ultimi 4 riguardano le candelette (erano bruciate e le ho già cambiate). Per il primo errore non so proprio dire...
Aspetto vostri commenti.
Grazie!
Gianluca
Ciao per il primo hai l'egr sporca se hai un buon meccanico la pulisce per bene e la lubrifica( lavoro fatto sul mio ducato) o te la cambia!
egr con errore ma se lo resetti probabile che non si presentera' per un po
Il consigloi che si vuole dare è che, prima di postare o analizzare una vaggata, devi cancelllare tutti gli errori e vedere quali rimangono al momento dell'ultima vaggata!
