Ragazzi, il display del CDB mi ha abbandonato, e’spento. MORTO!!!
La piccola e’ A6 3.0 TDI 7/2008.
Ho vaggato e ho errori su 3 centraline;
Saturday,13,October,2012,10:36:54:60804
VCDS Version: Release 10.6.0
Data version: 20100630
Chassis Type: 4L0
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 55
56 61 62 72 76 77
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F9 910 401 B HW: 4F0 907 401 C
Component: 3.0L V6TDI 000AG 0030
Revision: --H05--- Serial number:
Coding: 0011372
Shop #: WSC 02335 785 00200
VCID: 244C69669EB3
2 Faults Found:
005663 - Glowplug for Cylinder 6 (Q15): Open Circuit
P161F - 001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01110001
Fault Priority: 0
Fault Frequency: 1
Mileage: 58203 km
Time Indication: 0
Date: 2012.09.03
Time: 07:49:03
Freeze Frame:
RPM: 882 /min
Torque: 148.2 Nm
Speed: 1.1 km/h
Duty Cycle: 1.0 %
Voltage: 13.07 V
Duty Cycle: 22.9 %
Temperature: 23.4°C
005661 - Glowplug for Cylinder 4 (Q13): Open Circuit
P161D - 001 - Upper Limit Exceeded
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 59566 km
Time Indication: 0
Date: 2012.09.17
Time: 08:09:06
Freeze Frame:
RPM: 882 /min
Torque: 132.6 Nm
Speed: 1.1 km/h
Duty Cycle: 1.0 %
Voltage: 13.30 V
Duty Cycle: 23.7 %
Temperature: 27.9°C
Readiness: 0 0 0 0 0
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 M
Component: MNS ECE H52 1060
Revision: 00000000 Serial number: 364FY087800929
Shop #: WSC 02256 785 00200
VCID: 3B7EB21A030D
1 Fault Found:
02261 - Data Medium
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 7
Fault Frequency: 11
Reset counter: 31
Mileage: 59924 km
Time Indication: 0
Date: 2012.09.22
Time: 12:14:01
Freeze Frame:
Hex Value: 0x506E
Hex Value: 0x9F2E
Hex Value: 0x1100
Hex Value: 0xEE19
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 F HW: 4F0 915 181 B
Component: J0644 BEM H12 0760
Revision: 00000000 Serial number: 00000000116708
Shop #: WSC 00835 264 57288
VCID: 244C69669EB3
Part No: 4F0 915 105 D
Component: von VA0 2806291963
Coding: 344630393135313035442056413032383036323931393633
Shop #: WSC 00000 384 00290
3 Faults Found:
02272 - Quiescent Current Stage 1
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 1
Mileage: 49420 km
Time Indication: 0
Date: 2012.06.19
Time: 10:32:28
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Mileage: 49420 km
Time Indication: 0
Date: 2012.06.19
Time: 10:38:56
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00110001
Fault Priority: 7
Fault Frequency: 1
Reset counter: 43
Mileage: 61976 km
Time Indication: 0
Date: 2012.10.13
Time: 02:49:58
Per le candelette ok, le faccio cambiare.
L’errore del navigatore non mi preoccupa, ma consigli sono accettati.
Per la batteria, ho controllato da menù verde ed e’ 100%, da menù nascosto indica 13,88 volts e mi sembra ok, ma non capisco i 3 errori.
Quello che sicuramente mi preoccupa e’ il display CDB spento visto che deve anche presentare gli errori e sono al buio.
Mi potreste aiutare a capire cosa può essere la causa del malfunzionamento del CDB?
Se dovessi cambiarlo (SGRAT;SGRAT), sapete costi e qual’e’ il codice ricambio?
Grazie per i consigli
