ciao leon9t, scritto n. di cell .. se necessiti .. ben volentieri .. ciao ciao
ciao leon9t, ricevere i ringraziamenti, (ogni tanto), hihhihih, fa molto piacere, anche perchè ad alcuni invece sembra tutto dovuto ...
GRAZIE A TE ....LEO !!! ciao ciao e buonaserata !!
ciao...fatta ieri scansione...chi mi aiuta per gli errori ??? grazie a tutti in anticipo
Saturday,26,January,2013,13:42:16:55062
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 4F0
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 42 46 47 4F 52 53 56 61
62 72 76
VIN: audi A6 Mileage: 85510km/53133miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F0 910 402 E HW: 4F0 907 401 C
Component: 3.0L V6TDI G000AG 0030
Revision: --H04--- Serial number:
Coding: 0011372
Shop #: WSC 02334 785 00200
VCID: 1F465416CEA6FD1
1 Fault Found
005663 - Glowplug for Cylinder 6 (Q15)
P161F - 001 - Open Circuit
Freeze Frame:
Fault Status: 01110001
Fault Priority: 0
Fault Frequency: 1
Mileage: 80820 km
Time Indication: 0
Date: 2006.11.24
Time: 05:27:08
Freeze Frame:
RPM: 882 /min
Torque: 101.4 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.30 V
Duty Cycle: 24.9 %
Temperature: 19.8°C
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F2 910 156 F HW: 09L 927 156 C
Component: AG6 09L 3,0 TDI RdW 0030
Revision: --H01--- Serial number: 4290780
Coding: 0000001
Shop #: WSC 02325 785 00200
VCID: 28544FCA9BE83A9
No fault code found.
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 AD HW: 4F0 614 517 AA
Component: ESP8 quattro H01 0070
Revision: 00000000 Serial number: 00000000000000
Coding: 0020876
Shop #: WSC 00120 264 89382
VCID: 66C801F2517CEC9
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10601100690573
Coding: 0000131
Shop #: WSC 02323 785 00200
VCID: E3CE98E6224E191
Part No: 4F0 910 131 E
Component: FBSAUDIC6 EZS H45 0080
Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H01 0040
1 Fault Found
00955 - Key 1
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00110010
Fault Priority: 3
Fault Frequency: 3
Reset counter: 133
Time Indication: 0
Address 07: Control Head Labels: Redir Fail!
Part No SW: 4F0 910 769 G HW: 4F0 035 769 A
Component: MMI Cockpit H35 0410
Revision: C61060DE Serial number: AUZ6Z3G2AD0023
Coding: 0544125
Shop #: WSC 02335 785 00200
VCID: 3162A2AEA8327B1
Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H02 0060
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 A HW: 4F1 820 043 AF
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000052 Serial number: 00000030210841
Coding: 0000278
VCID: 1C3C631ADFB0E69
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H17 0240
Revision: 00000000 Serial number: 4F0907279
Coding: 0010101
Subsystem 1 - Part No: 4F1 910 113 C
Component: Wischer AudiC6 H05 0210
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 A
Component: REGENLICHTSENSORH13 0090
Coding: 00146221
Shop #: WSC 02335
1 Fault Found
00979 - Lamp for Low Beam; Right (M31)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00111010
Fault Priority: 2
Fault Frequency: 2
Reset counter: 117
Mileage: 83980 km
Time Indication: 0
Date: 2012.12.28
Time: 17:53:00
Address 0E: Media Player 1 Labels: Redir Fail!
Coding: 0544125
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 42 AIRBAG AUDI8RH30 0280
Revision: 09H30000 Serial number: 0037LD0MP7T+
Coding: 0013362
Shop #: WSC 00120 264 66823
VCID: 29524ACE80E2031
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H08 0230
Revision: 00H08000 Serial number: 90055070250071
Coding: 0002142
VCID: E6C881F2D17C6C9
Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 900 C HW: 4F0 920 901 C
Component: KOMBIINSTR. M73 H13 0170
Revision: 00000000 Serial number: 58U728827
Coding: 2049148
Shop #: WSC 76873 873 66865
VCID: 204457EAF3D8C29
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H11 0070
Revision: 11 Serial number: 13008072108046
Coding: ECFE53C41B0104
VCID: 27564CF696F6351
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0120
Revision: 00000000 Serial number: 2F
Coding: 0001642
Shop #: WSC 02327 785 00200
VCID: 2C5CB3DA8F10169
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01034677220000
Coding: 0008837
VCID: 2E58B9D2B90C649
Address 47: Sound System (J525) Labels: None
Part No SW: 4F0 910 223 H HW: 4F0 035 223 K
Component: Amp.-ASK-RD H07 0130
Revision: 08S00000
Coding: 020001
Shop #: WSC 02399 823 56573
VCID: 234E58E622CED91
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000226625
Coding: 0001003
VCID: DEB8A912092C349
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0120
Revision: 00000000 Serial number: I"I
Coding: 0001642
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04---
Coding: 0000321
Shop #: WSC 02324 785 00200
Address 56: Radio Labels: Redir Fail!
Coding: 0544125
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000017722
Shop #: WSC 01474 264 64353
VCID: 234E58E6E2CED91
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 2702120249
Coding: 344630393135313035442056413032373032313230323439
Shop #: WSC 00000 384 00290
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0001066
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0001066
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 F HW: 4F0 919 283 F
Component: Parkhilfe 4-Kan H09 0060
Revision: 00H09000 Serial number: 06230705110034
Coding: 0001116
Shop #: WSC 131071 1023 2097151
No fault code found
Il primo è una candeletta ma l'errore risale al 2006. Dovresti, salvandoti questa scansione, cancellare tutti gli errori e rifarla tra qualche giorno. Potrebbero essere falsi contatti.
Ok grazie....ho preso il,cavo solo venerdì .....grazieeeee
---------- Post added at 19.28.37 ---------- Previous post was at 19.27.19 ----------
Adesso che mi ci fai pensare....strano la macchina e immatricolata marzo 2007 :-))) mistero
L'errore è del 24/11/2006. Probabilmente importata in Italia. Immatricolata in Italia marzo 2007 ma prima immatricolazione forse è antecedente. Io andrei in Audi col telaio per avere più info.
Grazie....domani ci vado subito, perché non mi torna questa immatricolazione 2006
effettivamente meglio verificare
Sicuramente .....domani passo in audi e vi faccio sapere !!!
