vaggata piena di errori
chi mi sa spiegare questi errori
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 1010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: Malfunction 1010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Sporadic communication error 1000
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: Sporadic communication error 1000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Sporadic communication error 1000
canccela tutto e fai una vagata di nuovo
e devi postare tutto , dove si vedi anche i codici d"errori
l'ho fatta ma la 07 e 0E rimangono gli errori
---------- Post added at 15.11.34 ---------- Previous post was at 15.07.58 ----------
Address 01: Engine Labels: 03G-906-016-BLB.clb
Part No SW: 03G 906 016 BF HW: 03G 906 016 BF
Component: R4 2,0L EDC G000SG 9553
Revision: 12345678 Serial number:
Coding: 0000072
Shop #: WSC 02131 264 91152
VCID: 68D5C9045B68C4E
7 Faults Found:
18049 - Please check DTC Memory of A/C Controller
P1641 - 000 -
Freeze Frame:
RPM: 0 /min
Torque: 98.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.86 V
Bin. Bits: 00101000
Temperature: 48.6°C
(no units): 144.0
17055 - Cylinder 1 Glow Plug Circuit (Q10)
P0671 - 000 - Electrical Fault - Intermittent
Freeze Frame:
RPM: 1092 /min
Torque: 24.0 Nm
Speed: 26.0 km/h
Load: 0.0 %
Voltage: 13.53 V
Bin. Bits: 00101100
Temperature: 13.5°C
Bin. Bits: 10110000
17056 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 - 000 - Electrical Fault - Intermittent
Freeze Frame:
RPM: 1092 /min
Torque: 24.0 Nm
Speed: 26.0 km/h
Load: 0.0 %
Voltage: 13.53 V
Bin. Bits: 00101100
Temperature: 13.5°C
Bin. Bits: 10110000
17057 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 - 000 - Electrical Fault - Intermittent
Freeze Frame:
RPM: 1092 /min
Torque: 24.0 Nm
Speed: 26.0 km/h
Load: 0.0 %
Voltage: 13.53 V
Bin. Bits: 00101100
Temperature: 13.5°C
Bin. Bits: 10110000
17058 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 - 000 - Electrical Fault - Intermittent
Freeze Frame:
RPM: 1092 /min
Torque: 24.0 Nm
Speed: 26.0 km/h
Load: 0.0 %
Voltage: 13.53 V
Bin. Bits: 00101100
Temperature: 13.5°C
Bin. Bits: 10110000
19794 - Control Circuit for Glow Plug Controller 1
P3338 - 000 - Electrical Malfunction
Freeze Frame:
RPM: 1134 /min
Torque: 18.0 Nm
Speed: 17.0 km/h
Load: 2.4 %
Voltage: 13.91 V
Bin. Bits: 00101000
Temperature: 74.7°C
Bin. Bits: 11111111
17068 - Glow Plug Control Module (J179)
P0684 - 000 - Implausible Signal
Freeze Frame:
RPM: 966 /min
Torque: 42.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.06 V
Bin. Bits: 00101100
Temperature: 9.0°C
Bin. Bits: 10110000
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 D HW: 4F0 614 517
Component: ESP8 front H03 0010
Revision: 00000000 Serial number: 00000000000000
Coding: 0020855
Shop #: WSC 02327 785 00200
VCID: 254B8030ECFA196
No fault code found.
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H30 0220
Revision: 31050601 Serial number: 10600300090686
Coding: 0000001
Shop #: WSC 30450 264 89201
VCID: E3CF5E28224E276
Part No: 4F0 910 131 D
Component: FBSAUDIC6 EZS H43 0070
Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H36 0040
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F1 910 732 D HW: 4E0 035 729
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 350KJ047551321
Coding: 0000001
Part No: 4F0 910 609
Component: Bedienteil MMIC6H07 0870
3 Faults Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 5
Fault Frequency: 1
Reset counter: 94
Mileage: 174536 km
Time Indication: 0
Date: 2013.03.11
Time: 14:51:59
00384 - Optical Databus
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 9
Reset counter: 97
Mileage: 171736 km
Time Indication: 0
Date: 2010.09.01
Time: 15:54:23
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 26
Reset counter: 39
Mileage: 149920 km
Time Indication: 0
Date: 2011.03.04
Time: 17:40:25
Freeze Frame:
Bin. Bits: 10
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F2 820 043 C
Component: KLIMABETAETIGUNGH11 0060
Revision: 00000021 Serial number: 00000000017284
Coding: 0001046
Shop #: WSC 02335 785 00200
VCID: DBBF66C81A3E1F6
8 Faults Found:
00256 - A/C Pressure/Temperature Sensor (G395)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 134
Mileage: 155167 km
Time Indication: 0
Date: 2011.11.27
Time: 18:01:06
00739 - Coolant Circulation Pump (V50)
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 3
Fault Frequency: 5
Reset counter: 97
Mileage: 155167 km
Time Indication: 0
Date: 2011.11.27
Time: 18:01:21
Freeze Frame:
Temperature: 44.0°C
02071 - Local Databus
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00111100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 97
Mileage: 155167 km
Time Indication: 0
Date: 2005.02.01
Time: 12:01:29
02785 - Right Front Upper Body Outlet Position Sensor (G388)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 94
Mileage: 174536 km
Time Indication: 0
Date: 2013.03.11
Time: 15:06:18
Freeze Frame:
Voltage: 13.60 V
(no units): 37.0
(no units): 255.0
00732 - Potentiometer in Positioning Motor for Right-Hand Footwell Flap (G140)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 94
Mileage: 174536 km
Time Indication: 0
Date: 2013.03.11
Time: 15:06:18
Freeze Frame:
Voltage: 13.60 V
(no units): 38.0
(no units): 255.0
02763 - Potentiometer for Indirect Ventilation Flap Motor (G330)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 94
Mileage: 174536 km
Time Indication: 0
Date: 2013.03.11
Time: 15:06:18
Freeze Frame:
Voltage: 13.60 V
(no units): 35.0
(no units): 255.0
02095 - Component Protection Active
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 94
Mileage: 174536 km
Time Indication: 0
Date: 2013.03.11
Time: 15:06:18
Freeze Frame:
Bin. Bits: 00001111
01592 - Air Quality Sensor (G238)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 94
Mileage: 174536 km
Time Indication: 0
Date: 2013.03.11
Time: 15:06:18
Freeze Frame:
Temperature: 32.0°C
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H17 0240
Revision: 00000000 Serial number: 4F0907279
Coding: 0000101
Shop #: WSC 02131 264 53943
VCID: 31636460A832456
Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02131
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00141886
Shop #: WSC 02131
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBD6034902
Shop #: WSC 00000 000 00000
VCID: 1C3DA5D4DFB0D8E
2 Faults Found:
02244 - Button in Control Head is Stuck
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 7
Fault Frequency: 1
Reset counter: 106
Mileage: 172636 km
Time Indication: 0
Date: 2012.09.29
Time: 00:41:51
Freeze Frame:
Bin. Bits: 00001000
02261 - Data Medium
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 7
Fault Frequency: 1
Reset counter: 124
Mileage: 161706 km
Time Indication: 0
Date: 2012.02.22
Time: 09:30:36
Freeze Frame:
Text: 00000000
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 D HW: 4F0 959 655 B
Component: 32 AIRBAG AUDI8RH29 0250
Revision: 05H29000 Serial number: 0037LD04NGTU
Coding: 0013106
Shop #: WSC 00885 264 02811
VCID: 285589049BE804E
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90055043110199
Coding: 0002041
Shop #: WSC 02323 785 00200
VCID: E6C9473CD17C52E
Part No: XXXXXXXXXXX
Component: Lenkradmodul H06 0080
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 900 A HW: 4F0 920 900 N
Component: KOMBIINSTR. M73 H09 0630
Revision: 00400000 Serial number: 4L-10TAC4
Coding: 0004043
Shop #: WSC 00001 001 00001
VCID: 1E39AFDCC9ACCAE
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 B
Component: Gateway H09 0030
Revision: 09 Serial number: 0800804B0903F2
Coding: 6CEE53C41B3104
Shop #: WSC 02325 785 00200
VCID: 27578A3896F60B6
7 Faults Found:
01303 - Telephone Transceiver (R36)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 134
Mileage: 173812 km
Time Indication: 0
Date: 2012.10.10
Time: 12:52:41
01304 - Radio
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 134
Mileage: 174536 km
Time Indication: 0
Date: 2013.03.11
Time: 13:36:13
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 97
Mileage: 171736 km
Time Indication: 0
Date: 2010.09.01
Time: 15:13:10
00463 - Control Module for Digital Sound Package (J525)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 134
Mileage: 174536 km
Time Indication: 0
Date: 2013.03.11
Time: 13:42:45
02076 - Media Player Position 1 (R118)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 134
Mileage: 174536 km
Time Indication: 0
Date: 2013.03.11
Time: 13:46:44
01320 - Control Module for Climatronic (J255)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 134
Mileage: 174536 km
Time Indication: 0
Date: 2013.03.11
Time: 15:04:54
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 94
Mileage: 174536 km
Time Indication: 0
Date: 2013.03.11
Time: 15:06:00
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 E HW: 4E0 919 887 M
Component: MNS ECE H51 1050
Revision: 00000000 Serial number: 364AV087752385
VCID: 30656164A3384CE
1 Fault Found:
00862 - Antenna for GPS Navigation (R50/R52)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 97
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 793 B
Component: TSG FA H11 0040
Revision: 00000000 Serial number: QF
Coding: 0000555
Shop #: WSC 00885 264 56957
VCID: 29538C0080E23D6
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 134
Mileage: 174536 km
Time Indication: 0
Date: 2013.03.11
Time: 15:04:55
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 D HW: 4F0 907 289 D
Component: Komfortgeraet H14 0090
Revision: 00900014 Serial number: 01001580830000
Coding: 0000133
VCID: 2B5F76088A1E2F6
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 134
Mileage: 174536 km
Time Indication: 0
Date: 2013.03.11
Time: 15:04:59
Address 47: Sound System Labels: 4F0-910-223-AS.lbl
Part No SW: 4F0 910 223 G HW: 4F0 035 223
Component: Amp.-ASK H09 0350
Revision: 16S00001 Serial number: 00211040043614
Coding: 0000008
VCID: 22419B2CFDD4EEE
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280
Component: ILM Beifahrer H09 0050
Revision: Serial number: 00000000031122
Coding: 0001004
VCID: DEB96FDC092C0AE
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 134
Mileage: 174536 km
Time Indication: 0
Date: 2013.03.11
Time: 15:04:00
Freeze Frame:
Voltage: 11.900 V
Temperature: 20.0°C
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 792 B
Component: TSG BF H11 0040
Revision: 00000000 Serial number: ‰‰g
Coding: 0000555
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 134
Mileage: 174536 km
Time Indication: 0
Date: 2013.03.11
Time: 15:04:55
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04---
Coding: 0000111
VCID: 20459124F3D8FCE
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541
Component: TUNER EU/US/RDW H41 0630
Revision: 00000000 Serial number: 352K$047577826
Coding: 0000001
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H11 0490
Revision: 00000000 Serial number: 00000000031621
VCID: 234F9E28E2CEE76
Subsystem 1 - Part No: 4F0 915 105 C
Component: von VA0 4411220211
Coding: 344630393135313035432056413034343131323230323131
Shop #: WSC 00000 384 00290
5 Faults Found:
02273 - Quiescent Current Stage 2
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 10
Mileage: 122942 km
Time Indication: 0
Date: 2009.09.16
Time: 14:32:19
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 134
Mileage: 174536 km
Time Indication: 0
Date: 2013.03.11
Time: 15:04:53
02479 - Partial Consumer Shut-Off Active
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Mileage: 137033 km
Time Indication: 0
Date: 2010.04.22
Time: 16:48:39
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Mileage: 137039 km
Time Indication: 0
Date: 2010.04.29
Time: 13:11:32
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Mileage: 137039 km
Time Indication: 0
Date: 2010.04.29
Time: 18:04:55
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 A HW: 4F0 959 795 A
Component: TSG HL H09 0010
Coding: 0000002
VCID: 2A51730C85E436E
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 A HW: 4F0 959 794 A
Component: TSG HR H09 0010
Coding: 0000002
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 M HW: 4E0 862 335
Component: Handyvorb2 H10 1130
Revision: 00000000 Serial number: 00000007531163
Coding: 0010900
VCID: 2C5D75148F1028E
End ---------------------------------------------------------------------
per il ENGINE se vedi che tutte le candelete e la centralina de candelete hanno dei problemi, secondo me la centralina ha qualcosa e per questo da errori anche per le candele.
anche il climatronic ti da tanti errori, per il CD changer qualche buttone e rotto.
qua trovi delle risposti per tutti l"errori --- http://wiki.ross-tech.com/wiki/index...ry:Fault_Codes
prova de entrare nell modulo dove hai dei errori e prova canccelare di la.
auras mi dai una spiegazione dove si vede l'errore.... cioe' il numero da trovare nell' link che mi hai dato te
de esempio questo
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 134
Mileage: 174536 km
Time Indication: 0
Date: 2013.03.11
Time: 15:04:55
01320 -- questo e il codice dell errore, nell link trovi un elenco con tutti i codici d"errori, lo trovi e schiacci su questo numero e ti da la risposta, cappita che a volte non trovi nell elenco il codice del tuo errore, pero ce il GOOGLE.
Ultima modifica di auras80; 24-03-2013 alle 15:53
ok grazie ora controllo un pokino
Ciao Buell,
ma hai sostituito qualche centralina di recente? perchè hai 2 errori di: 02095 - Component Protection Active nella GW quindi nelle mamme delle centraline e nel clima,
per levare component protection devi per forza andare in Audi
Questa protezione blocca diverse funzionani e lascia solo quelle indispensabili e visto che tutte le altre centraline passano dalla GW sicuramente è questo il problema
se non hai aggiunto o sostituito centraline per caso hai staccato o si è scaricata totalmente la batteria della macchina?
si crisxx avevo cambiato la centralina clima dato che la mia e quella bruttina con le 4 manovelle l'ho cambiata con quella elettronica, avevo fatto una prova...poi ho rimesso quella originale...
sicuramene uno dei problemi del HVAC è stato la sostituzione, scommetto che quando l'hai inserito ha funzionato per 2 secondi e poi si è bloccato, è quello il problema del Blocco di sicurezza. Ma una volta ripristinato e cancellato l'errore doveva tornare tutto apposto.
ti consiglio di fare nuovamente uno scan completo con successiva cancellazione errori e poi fare nuovamente la scansione
fammi sapere
