Pagina 6 di 52 PrimaPrima 12345678910111213141516 ... UltimaUltima
Risultati da 51 a 60 di 511
Discussione: ..L'A4 B8 Avant 2.0tdi 143cv Multitronic Ambition di Alex..
  1. #51
    Audi lover L'avatar di plujet
    Jan 2011
    Thanked: 50
    Audi A4 sw 2.0 TDI 8K
    Ciao Ale..ha cambiato il tacho e di conseguenza si è succhiato i km del vecchio proprietario del tacho....
    ---------- Post added at 22.53.04 ---------- Previous post was at 22.51.14 ----------
    Citazione Originariamente Scritto da Alex_Turbo_Quattro Visualizza Messaggio
    intanto ieri sera....
    Thursday,29,August,2013,21:43:51:10074 VCDS Version: Release 10.6.4 Data version: 20110418
    Chassis Type: 8T0 Scan: 01 02 03 05 08 09 0E 10 15 16 17 19 42 46 52 53 55 56 5F 62 72
    VIN: WAUZZZ8K0AAXXXXXX Mileage: 155280km/96486miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    0E-Media Player 1 -- Status: OK 0000
    10-Park/Steer Assist -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    46-Central Conv. -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    53-Parking Brake -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine (J623-CAGA) Labels: 03L-906-022-CAG.clb Part No SW: 03L 906 022 MK HW: 03L 906 022 B Component: R4 2,0L EDC H01 4379 Revision: 11H01--- Coding: 0104002C02072118 Shop #: WSC 06335 000 00000 ASAM Dataset: EV_ECM20TDI03L906022MK A01006 ROD: EV_ECM20TDI03L906022MK.rod VCID: 7AFFF6DB4C4F
    No fault code found. Readiness: 0 0 0 0 0
    Address 02: Auto Trans (J217) Labels: 0AW-927-156.clb Part No SW: 8K0 927 155 AF HW: 0AW 927 156 H Component: 0AW 20TDI RdW H02 0007 Revision: --H02--- Serial number: 0000001839 Coding: 000002 Shop #: WSC 06335 000 00000 ASAM Dataset: EV_TCMVL381 A02006 ROD: EV_TCMVL381_AU48.rod VCID: 77F9EFEF7F5D
    1 Fault Found:
    2225 - RPM Signal from ECU: No Signal P0727 00 [096] - Upper Limit Exceeded Freeze Frame: Fault Status: 01100000 Fault Priority: 0 Fault Frequency: 0 Reset counter: 0 Mileage: 0 km Date: 2000.00.00 Time: 00:00:00
    Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb Part No SW: 8K0 907 379 AM HW: 8K0 907 379 AM Component: ESP8 front H04 0100 Revision: -------- Serial number: -------------- Coding: 174D08 Shop #: WSC 06335 000 00000 VCID: 84030823BE8B
    Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP Component: BCM2 1.1 H02 0321 Revision: 00002001 Coding: 010200 Shop #: WSC 06335 000 00000 VCID: 810D0137A199
    Part No SW: 8T0 959 754 D HW: 8T0 959 754 D Component: FBSAUDIB8 IDG H37 0060
    Part No SW: 8K0 905 852 D HW: 8K0 905 852 D Component: J764 ELV MLB H36 0042
    Address 08: Auto HVAC (J255) Labels: Redir Fail! Part No SW: 8T1 820 043 AN HW: 8T1 820 043 AN Component: KLIMA 1 ZONE H08 0160 Revision: A1000000 Serial number: 01020620091183 Coding: 34100000 Shop #: WSC 06335 000 00000 VCID: 7DF5FDC75D61
    Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb Part No SW: 8K0 907 063 P HW: 8K0 907 063 P Component: BCM1 1.0 H25 0380 Revision: 10025001 Serial number: 00000000273579 Coding: 2600DE954034AF000001000300001D0D0F1C47080001010100 0000 Shop #: WSC 06335 000 00000 VCID: 3C7330C306FB Part No SW: 8K1 955 119 A HW: 8T1 955 119 Component: WWS 280509 H06 0070 Coding: 00FD11
    Part No SW: 8K0 955 559 HW: 8K0 955 559 Component: RLS H04 0003 Coding: 025028
    Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL Component: E1 - LDS H08 0090
    Address 0E: Media Player 1 (R41) Labels: 4E0-910-111.lbl Part No SW: 4E0 910 110 L HW: 4E0 035 110 A Component: CDC-MP3-Pana H48 0050 Revision: 00000014 Shop #: WSC 06335 000 00000 VCID: 214DE1B78159
    Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb Part No SW: 8K0 919 475 H HW: 8K0 919 475 Component: PARKHILFE 4K H06 0050 Revision: 11001001 Serial number: 39940914500897 Coding: 300103 Shop #: WSC 06335 000 00000 VCID: 3E773ACB10E7
    1 Fault Found:
    01546 - Sensor for Parking Aid; Rear Mid-Left (G204) 014 - Defective - Intermittent Freeze Frame: Fault Status: 00101110 Fault Priority: 3 Fault Frequency: 2 Reset counter: 127 Mileage: 154699 km Time Indication: 0 Date: 2013.08.15 Time: 01:04:17 Freeze Frame: Temperature: 21.0°C
    Address 15: Airbags (J234) Labels: 8K0-959-655.clb Part No SW: 8K0 959 655 G HW: 8K0 959 655 G Component: AirbagVW-AU10 H37 0520 Serial number: 003EFD02XUJ0 Coding: 30343435363030303030554A304C384B3053 Shop #: WSC 06335 000 00000 ASAM Dataset: EV_AirbaECUVWAUDI010 003010 ROD: EV_AirbaECUVWAUDI010_AU48.rod VCID: 418D41376119
    Driver's Airbag Crash Sensor: Serial number: 6334MSME483056526
    Passenger Side Airbag Crash Sensor: Serial number: 6344MSME483049147
    Driver's Rear Airbag Crash Sensor: Serial number: 6352QSME012B001E6
    Passenger's Rear Airbag Crash Sensor: Serial number: 6362QSME062E4B3CU
    Driver's Front Airbag Crash Sensor: Serial number: 63732SME56295202U
    Passenger's Front Airbag Crash Sensor: Serial number: 63832SME042B5416X
    Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb Part No SW: 8K0 953 568 F HW: 8K0 953 568 F Component: Lenks.Modul H16 0014 Revision: -------- Serial number: 90304IEK000PG Coding: 000017 Shop #: WSC 06335 000 00000 VCID: 3D753DC71DE1 Component: E221 - MFL H02 0003
    Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb Part No SW: 8K0 920 900 K HW: 8K0 920 900 K Component: KOMBIINSTR. H19 0253 Revision: 00100000 Serial number: BWZ23F269 Coding: 0B0F100003000008000000 Shop #: WSC 06335 000 00000 VCID: 326F1EFBD4BF
    Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb Part No SW: 8T0 907 468 T HW: 8T0 907 468 K Component: GW-BEM 4CAN-M H09 0101 Revision: EB700052 Serial number: 5200E0951284E4 Coding: 00C303 Shop #: WSC 06335 000 00000 VCID: 52AF7E7BB47F
    Part No SW: 8K0 915 181 E HW: 8K0 915 181 E Component: J367-BDM H06 0160
    Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb Part No SW: 8K0 959 793 H HW: 8K0 959 793 D Component: TSG FA H11 0306 Revision: Serial number: 0000008869366 Coding: 011C02205100410001 Shop #: WSC 06335 000 00000 VCID: 458555277531
    1 Fault Found:
    02117 - Motor for Mirror Folding 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 3 Fault Frequency: 101 Reset counter: 112 Mileage: 154151 km Time Indication: 0 Date: 2013.08.05 Time: 20:46:44
    Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP Component: BCM2 1.1 H02 0321 Revision: 00002001 Serial number: 0118809837 Coding: 01040620203900800320020000000000 Shop #: WSC 06335 000 00000 VCID: 810D0137A199
    11 Faults Found:
    02616 - Fuel Tank Cap; Unlock 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 2 Fault Frequency: 17 Reset counter: 87 Mileage: 152293 km Time Indication: 0 Date: 2013.06.11 Time: 18:50:12
    02615 - Fuel Tank Cap; Lock 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 2 Fault Frequency: 16 Reset counter: 66 Mileage: 152302 km Time Indication: 0 Date: 2013.06.11 Time: 19:04:48
    01501 - Bulb for Blinkers; Rear Left (M6) 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 2 Fault Frequency: 2 Reset counter: 126 Mileage: 154595 km Time Indication: 0 Date: 2013.08.14 Time: 15:30:21
    01565 - Luggage Compartment Light (W3) 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 113 Mileage: 154183 km Time Indication: 0 Date: 2013.08.06 Time: 16:02:29
    02738 - Bulb for Tail/Brake Light; Left 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 2 Fault Frequency: 3 Reset counter: 137 Mileage: 154595 km Time Indication: 0 Date: 2013.08.14 Time: 15:43:10
    01505 - Bulb for Blinkers; Rear Right (M8) 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 126 Mileage: 154595 km Time Indication: 0 Date: 2013.08.14 Time: 15:50:50
    02739 - Bulb for Tail/Brake Light; Right 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 2 Fault Frequency: 2 Reset counter: 137 Mileage: 154964 km Time Indication: 0 Date: 2013.08.22 Time: 18:29:22
    00988 - Lamp for Brake Light; Right (M10) 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 2 Fault Frequency: 2 Reset counter: 137 Mileage: 154964 km Time Indication: 0 Date: 2013.08.22 Time: 18:29:24
    01518 - Bulb for Back-Up Lights; Left (M16) 012 - Electrical Fault in Circuit - MIL ON Freeze Frame: Fault Status: 11101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 97 Mileage: 154964 km Time Indication: 0 Date: 2013.08.22 Time: 18:29:25
    01519 - Bulb for Back-Up Lights; Right (M17) 012 - Electrical Fault in Circuit - MIL ON Freeze Frame: Fault Status: 11101100 Fault Priority: 2 Fault Frequency: 2 Reset counter: 97 Mileage: 154964 km Time Indication: 0 Date: 2013.08.22 Time: 18:29:25
    00987 - Lamp for Brake Light; Left (M9) 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 137 Mileage: 154964 km Time Indication: 0 Date: 2013.08.22 Time: 18:31:16
    Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb Part No SW: 8K0 959 792 H HW: 8K0 959 792 D Component: TSG BF H11 0306 Revision: Serial number: 0000008875841 Coding: 011C02205100410001 Shop #: WSC 06335 000 00000 VCID: 448348237E0B
    1 Fault Found:
    02117 - Motor for Mirror Folding 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 3 Fault Frequency: 103 Reset counter: 112 Mileage: 154151 km Time Indication: 0 Date: 2013.08.05 Time: 20:46:44
    Address 53: Parking Brake (J540) Labels: 8K0-907-801.clb Part No SW: 8K0 907 801 H HW: 8K0 907 801 H Component: EPB Audi B8 H09 0090 Revision: 00000003 Serial number: 10000000246702 Shop #: WSC 00000 000 00000 VCID: 346318E32EAB
    Address 55: Xenon Range Labels: 8K0-907-357.clb Part No: 8K5 907 357 Component: Dynamische LWR H01 0010 Revision: 00000001 Serial number: Coding: 0000004 Shop #: WSC 06334 000 00000 VCID: F7F96FEFFF5D
    Address 56: Radio (R) Labels: Redir Fail! Part No SW: 4F0 035 056 B HW: 4F0 035 056 Component: Radio U STD H45 0020 Revision: AB001007 Serial number: 342Z+09B000443 Coding: 010003020100000001 Shop #: WSC 00363 264 92766 VCID: 1F49E74FB72D
    Address 5F: Information Electr. (J794) Labels: Redir Fail! Part No SW: 8T1 035 652 D HW: 8T1 035 652 D Component: B-BN-EU H52 0048 Revision: -------- Serial number: 323E 097508876 Coding: 010100010006E1FD05000F0E000000030001 Shop #: WSC 06335 000 00000 VCID: 366722EB38D7
    Part No SW: 4L0 919 604 HW: 4L0 919 604 Component: DU6 Basic H43 0306
    Part No SW: 8T0 919 609 HW: 8T0 919 609 Component: E0380 Bedient H08 0100
    3 Faults Found:
    03157 - Functionality limited due to Communications Disruption 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 6 Fault Frequency: 2 Reset counter: 71 Mileage: 154151 km Time Indication: 0 Date: 2013.08.05 Time: 20:59:05 Freeze Frame: Bin. Bits: 00000001 00000000 Bin. Bits: 00000000 10000000 Bin. Bits: 00000000 00000000 Bin. Bits: 00000000 00000000
    02168 - Left Front Microphone (R140) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 113 Mileage: 154183 km Time Indication: 0 Date: 2013.08.06 Time: 16:22:36 Freeze Frame: Voltage: 12.80 V
    02169 - Right Front Microphone (R141) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 113 Mileage: 154183 km Time Indication: 0 Date: 2013.08.06 Time: 16:22:36 Freeze Frame: Voltage: 12.80 V
    Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb Part No SW: 8K0 959 795 C HW: 8K0 959 795 C Component: TSG HL H10 0306 Revision: Serial number: 0000101193394 Coding: 010C02204000210001 Shop #: WSC 06335 000 00000 VCID: 428F4E3B641F
    Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb Part No SW: 8K0 959 795 C HW: 8K0 959 795 C Component: TSG HR H10 0306 Revision: Serial number: 0000101193402 Coding: 010C02204000210001 Shop #: WSC 06335 000 00000 VCID: 428F4E3B641F
    End ---------------------------------------------------------------------
    comunque ci stavo facendo caso solo ora: ne hai mica male di errori, come mai??
    microfoni del 5F, luci bagagliaio (forse hai messo quelle a led senza resistenza) , chiusura tappo gasolio, sensori di parcheggio, etc....
    ma li hai tolti o li hai ancora???
    Audi lover L'avatar di Ale-S3
    Thanked: 15
    Massa-Carrara (MS)
    AUDI A4 AVANT 2.0 TDI 194 cv .
    Ah ecco .
    WORK IN PROGRESS
  4. #53
    Audi lover L'avatar di Alex_Turbo_Quattro
    Mar 2006
    A5 8T Coupè 3.0Tdi S-tronic -BMW F900XR '20 + Ducati Monster 620ie Dark '03
    Gli errori li ho perché ho gia codificato x specchietti ripiegabili sensori ant senza ancora averli suppongo..e ho cambiato luci con il quadro acceso per appunto vedere se segnalava l errore nel tacho...piu che altro mi preoccupano i microfoni..che dici? Cosa mi dici???...per i km in un centro audi specializzato cosa intendi??? Io vorrei rimettere i miei giusti...
  5. #54
    Jan 2011
    Thanked: 50
    No, in audi non te lo fanno...devi andare in un centro Bosch...
    ---------- Post added at 23.28.04 ---------- Previous post was at 23.26.52 ----------
    1 Fault Found:
    non solo davanti...anche il sensore parcheggio dietro in mezzo a sinistra.....
    ---------- Post added at 23.28.51 ---------- Previous post was at 23.28.04 ----------
    è come se i microfoni nella plafoniera fossero staccati dal connettore 6 poli azzurro....
    ---------- Post added at 23.29.54 ---------- Previous post was at 23.28.51 ----------
    sportellino gasolio che non si apre-chiude bene
    ---------- Post added at 23.30.23 ---------- Previous post was at 23.29.54 ----------
    poi hai un sacco di errori sulle lampadine dietro della retro, stop..etc... (bulb)
    ---------- Post added at 23.30.55 ---------- Previous post was at 23.30.23 ----------
    dagli una bella pulita con il vag....entra in ogni centralina che da errore, vai in FAULT CODE e clicca su clear....
  6. #55
    Mar 2006
    Capito, puo essere che gli errori dei microfoni li abbia presi quando ho staccato la plafoniera ant per mettere i led? Ho staccato anche un connettore blu mi pare...per i sensori parcheggio che mi consigli?
  7. #56
    Jan 2011
    Thanked: 50
    Ciao...ti consiglio di buttare via la macchina!!....scherzo!!!
    Per i microfoni rismonta la plafoniera e controlla se il connettore è agganciato o meno mentre x i sensori prova a cancellare gli errori altrimenti c'e la probabilità che qualche sensore non vada....anche se al momento non ne ho visto uno non andare. ..
  8. #57
    utente (cancellato) 4
    Ospite
    Assolutamente si....
    Si è aperto il circuito e ha segnalato l'errore...
  9. #58
    Mar 2006
    ..Coming Soon!!!...
  10. #59
    Direttivo Audi RS Club
    Mar 2010
    Thanked: 128
    bello lo scatolo Bauli
    Mar 2006
    Perché...i porta clicquot e moet dietro invece non ti piacciono??
