Si tratta di cambiare un bit in un byte , tutto qui , tralascia la parte del security access che non serve a niente e poi una volta cambiato sto benedetto bit nella centralina 10 al byte 0 bit 4 mettendoci xxx1xxxx le x sono i numeri che hai ora ,farai un reset al MMI .
[URL=https://matchnow.life]Verified Females[/URL]
Ciao Ragazzi, ho trovato questo:
First series:
4F0 910 283 A - 4 sensors, no graphical support
4F0 910 283 B - ? sensors, no graphical support
4F0 910 283 C - 8 sensors, graphical support
4F0 910 283 D - 4 sensors, graphical support
4F0 910 283 E - 8 sensors, graphical support, rear view camera support
4F0 910 283 F - 4 sensors, graphical support, rear view camera support
4F0 910 283 G - 8 sensors, graphical support, rear view camera support
4F0 910 283 H - 8 sensors, graphical support, rear view camera support
Second (current) series:
8K0 919 475 A - 8 sensors, graphical support
8K0 919 475 B - 4 sensors, no graphical support
8K0 919 475 C - 8 sensors, graphical support, rear view camera support
8K0 919 475 D - 4 sensors, no graphical support
8K0 919 475 E - 8 sensors, graphical support, rear view camera support
8K0 919 475 F - 4 sensors, no graphical support
8K0 919 475 G - 8 sensors, graphical support, rear view camera support
8K0 919 475 H - 4 sensors, rear view camera support
8K0 919 475 J - 8 sensors, graphical support, rear view camera support
8K0 919 475 P - 8 sensors, graphical support, rear view camera support
8K0 919 475 Q - 4 sensors, no graphical support
8K0 919 475 R - 8 sensors, graphical support, rear view camera support
8K0 919 475 S - 4 sensors, no graphical support
8K0 919 475 T - 4 sensors, rear view camera support
8K0 919 475 AA - 8 sensors, graphical support, rear view camera support
Product codes (again as LoCal points out) are as follows:
PR-7X0 = ? sensors, no graphical support
PR-7X1 = 4 sensors, no graphical support
PR-7X4 = 8 sensors, graphical support
PR-7X7 = 4 sensors, graphical support, rear view camera support
PR-7X8 = 8 sensors, graphical support, rear view camera support
The absolute latest module is "8K0 919 475 AA" - which was released with the RS5
pressso questo indirizzo http://www.a5oc.com/forums/audi-a5-s...ar-camera.html ditemi un pò
saluti
Sbbarra
ciao, mi spieghi che cos'e' tutta sta roba???
ciao a tutti , la lista delle centraline non penso sia molto affidabile..............
Nel mio caso specifico ho una
ma al contrario ho attivato la grafica e in piu ho montato la retrocamera......
Quindi l unica cosa da fare è provare col vag per avere la certezza.
Ciao, tutto quello che hai letto io l'ho trovato in rete, comunque la mia finisce con D e non si attiva provato con vag, ne ho un'altra che finisce con H chissà se si attiva, dato che quello che avevo riportato da un'altro post non e attendibbile. ma dimmi puoi postare il file log della tua Q5, sai l'ho vorrei confrontare con il mio, puoi farlo?, grazie.
saluti
Sbbarra
http://forum.audirsclub.it/showthrea...-parcheggio-Q3
Guarda hai fatto questa procedura ?
Buongiorno a tutti e in particolare a Bizzio, per il fatto che FUNZIONAAAAAAAA grafica attivata.
saluti
Sbbarra
