Risultati da 1 a 8 di 8
Discussione: Help Errore VAG su 5F
    New Entry L'avatar di kiddo
    Nov 2010
    Audi A4 2.0 Tdi 143 Cv.
    Icon13 Help Errore VAG su 5F
    Salve, dopo una vaggata di routine trovo:
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Per la precisione:
    Address 5F: Information Electr. (J794) Labels: Redir Fail!
    Part No SW: 8T1 035 652 D HW: 8T1 035 652 D
    Component: B-BN-EU H56 0048
    Revision: -------- Serial number: 323CT0A7566270
    Coding: 010100010006C1FD23000F0E000000030001
    Shop #: WSC 06325 000 00000
    VCID: 366722EB38D7
    Part No SW: 4L0 919 604 HW: 4L0 919 604
    Component: DU6 Basic H43 0306
    Part No SW: 8T0 919 609 HW: 8T0 919 609
    Component: E0380 Bedient H08 0100
    1 Fault Found:
    03157 - Functionality limited due to Communications Disruption
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 36
    Mileage: 84209 km
    Time Indication: 0
    Date: 2014.02.11
    Time: 17:43:27
    Freeze Frame:
    Bin. Bits: 00000000 00000000
    Bin. Bits: 00001000 00000000
    Provato ad azzerare i DTC, ma l'errore rimane.
    Qualcuno sa dirmi di cosa si tratta?
    Ho provato a googlare ovunque ma ...
    AIUTO!!
    Apr 2009
    Forlì-Cesena (FC)
    A4 Avant B8 2.0 TDI
    Scusa ma hai fatto delle codifiche?
    Audi lover L'avatar di Luki
    Jul 2010
    Audi A4 Avant Advanced 2.0 Tdi B8
    Hai aggiornato le mappe NON in Audi?!??!?!
    utente (cancellato) 4
    Ospite
    Citazione Originariamente Scritto da kiddo Visualizza Messaggio
    Per la precisione:
    VCID: 366722EB38D7
    1 Fault Found:
    000 - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 36
    Mileage: 84209 km
    Time Indication: 0
    Date: 2014.02.11
    Time: 17:43:27
    Freeze Frame:
    AIUTO!!
    Sembra ci sia qualcosadi scollegato...
    Ma la cancellazione dell'errore lo hai fattadirettamente dentro la 5F?? Se la fai solo da vaggata completa non funziona.
    Non è che hai staccato il clima o la tastiera, e poi l'hai riattaccata???
    Direttivo Audi RS Club
    Mar 2010
    Thanked: 128
    Sposto in sezione VAG
    Nov 2010
    Citazione Originariamente Scritto da Giggio Visualizza Messaggio
    SI A TUTTO.
    Cioè:
    Recentemente ho staccato e riattaccato alcuni connettori avendo fatto un piccolo (!) Up.
    Il mio dubbio è che , mentre tutti i vari errori temporanei di collegamento-scollegamento connettori si sono azzerati, questo persiste.
    Ho provato ad azzerarlo, sia in modo consueto, sia entrando solo nella 5F , ma nulla, il problema persiste.
    Recentemente ho provato ad abilitare il sistema ADS tramite MMI, come spiegato nel thread apposito, ma non mi soddisfaceva, soprattutto perchè non ho i tasti sul cruscotto, e poi potevo abilitare solo il Motore-Cambio, avendo il Multitronic senza tutto il resto.
    E' probabile che nella procedura di ripristino mi sia dimenticato di ripristinare qualche bit?
    Sono seriamente preoccupato....
    Nov 2010
    TROVATO!! Nel menu' nascosto avevo inspiegabilmente attivato il BRAKING ASSIST sul CAR-CARDEVICELIST. Eliminata la spunta, eliminato l'errore!! Hi HI Hi....;-))
    Sep 2009
    Thanked: 43
    io non penso di aver sentano nulla per sbaglio nel menu verse ma ho l'errore 03157 pure io....proverò a vedere se davvero ho dei parametri sbagliati
    inoltre mi compare l'errore 03276, che cos'è?
