Risultati da 1 a 4 di 4
Discussione: Audi TT Quattro Sport Concept (TTRS?)
    Audi lover L'avatar di LUPIN
    Sep 2008
    Thanked: 167
    Ferrari 488 Spider + Audi RS3 8VA + Smart Brabus Xclusive Cabrio 2017
    Predefinito Audi TT Quattro Sport Concept (TTRS?)
    2.0 TFSI 420cv - 0-100 in 3,7 s
    E' già finito il tempo del 2.5?
    Besides introducing the third-gen TT, Audi is also presenting in Geneva a very powerful TT quattro sport concept.
    The highlight of this concept is represented by an uprated 4-cylinder 2.0-liter TFSI engine outputting an impressive 420 HP (309 kW) at 6,700 rpm and 450 Nm (331 lb-ft) of torque available between 2,400 and 6,300 rpm. The engine weighs only 150 kg (330 lbs) and offers 210 HP / liter of displacement, even more than the 2001 Le Mans-winner R18.
    The Audi quattro sport concept tips the scales at 1,344 kg (2,963 lbs) and sprints to 62 mph (100 km/h) in only 3.7 seconds thanks to a quick S tronic dual-clutch gearbox sending output to the quattro all-wheel drive system.
    In terms of styling, the concept distance itself from the new TT thanks to a new diamond-pattern front grille, matrix LED headlights and massive air intakes. It also comes with different 20-inch alloy wheels and has received a CFRP splitter along with extended wheel arches and a diffuser also made from carbon fiber reinforced plastic. There's also a big rear wing to increase downforce while the two large circular tailpipes show the concept means business.
    The interior cabin has been stripped of extra weight by removing the speakers and armrests, while in the cargo area there is space for two racing helmets. Audi fitted the concept with bucket seats with black four-point seatbelts along with a 12.3-inch TFT fully digital display also found in the revamped TT. The red start/stop button has been positioned on the steering wheel where the driver also has access to the buttons to control the large screen.
    There's no word about a production version but chances are the Audi TT quattro sport concept is a preview for a future track-focused version.
    Fonte: Audi
    Nov 2011
    E class coupè / TTRS
    No, il ttrs esce il prossimo anno.. questa sarà una versione a pezzi limitati del 2.0 tfsi.. non ha niente, tantomeno i sedili post. peserà 1100kg... ottima per i track day..
    Audi lover L'avatar di IlPunitore
    Apr 2009
    Thanked: 185
    S3 8VA FL SPB APR Stage 2 + RS3 8Y SPB Stage 2 + 992 4S Cabrio
    Bella
    SocioRsClub "WunderWagen" e Probiviro L'avatar di R-power
    Thanked: 76
    Como (CO)
    ül fünf & M3e36 "Das Bavarese" & M3e46cs "Never"
    direi:
    - se esce quel coso li con quei dati, credo che viaggio sui 100ke e rotti..... se costa meno di 70ke regalo il funf al primo che scrive in sto topic
    - la ala leggenda è molto piu elegante di quel coso da fabbri fatto con la scatola del meccano dei krukki a 4 anelli
    - macchina da TD buona per 2 giri..... poi ci vuole il ghiacchio secco a tirar giù le temperature dello striminzito 4zyl 2.0 pompato peggio di una starlet siliconata
    se tolgono di produzione il FUNF peccato xche la TTmk3, visto che riciclavo anche il leggenda mi intrippava parecchio
    un 4zyl mega pompato non mi attrae....
    e se in buona sostanza dopo pochi anni lo tolgono di produzione è un ulteriore segno che comandano i ragionieri....
    meglio, resterà un esclusivo polmone di pochi vecchi rimbambiti
    (anche xche le masse di ingegneri aerospaziali di FB osanneranno la validità del 4zyl dopato)
    un pò come per il caso R32 vs golf R...
    per 5 minuti, una bomba !!!
    una sorta di lepre del sesso......
    links: < TTRS "ül fünf" page >__< "ül fünf" Zound-check (by nm2255) >__< R32 & TTs page>
    -- Funny BUT real quotes: (thx to..) --_.:R32:._YOU can count ON !! Everytime !!
    1."Motorsport:first U need lot of money(better NOT yours),then your 2 balls can help to go faster"(R-power)
    2."R-power:faster than Bisio,nicer than Vettel"(Craw)"..& more Macho than Dom.Toretto"(Vin-Gasolio)
    3."YODA:...concreto diretto e QUALCHE VOLTA molto simpatico" (Briccola "Carruggi.Vettel")
