aiuto vaggata e procedura regolazione motoposizionatori clima
Sunday,30,March,2014,12:38:40:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 4F0
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 55
56 61 62 72 76 77
VIN: WAUZZZ4F
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F0 910 402 H HW: 4F0 907 401 B
Component: 3.0L V6TDI G000AG 0040
Revision: --H01--- Serial number:
Coding: 0011372
Shop #: WSC 02334 785 00200
VCID: 2241F451FDD4D09
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F1 910 156 B HW: 09L 927 156 A
Component: AG6 09L 3.0lTDI RdW 0040
Revision: --H01--- Serial number: 4087159
Coding: 0000001
Shop #: WSC 02327 785 00200
VCID: 234FF155E2CED91
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
Component: ESP 8.0 quattro H04 0090
Revision: 00000000 Serial number: 00000000000000
Coding: 0020872
VCID: 2D5B176DB40A1F1
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10600600256997
Coding: 0000131
Shop #: WSC 00940 264 85393
VCID: E3CF3155224E191
Part No: 4F0 910 131 E
Component: FBSAUDIC6 EZS H45 0070
Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H39 0040
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F1 910 732 D HW: 4E0 035 729
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 350I 057599842
Coding: 0001001
Shop #: WSC 30723 264 95054
VCID: 254BEF4DECFA271
Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H08 0050
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F1 820 043 S
Component: KLIMABETAETIGUNGH12 0160
Revision: 00000027 Serial number: 00000000183791
Coding: 0000278
VCID: DBBF09B51A3E211
1 Fault Found:
01592 - Air Quality Sensor (G238)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 251
Mileage: 183962 km
Time Indication: 0
Date: 2014.03.30
Time: 12:33:52
Freeze Frame:
Temperature: 16.0°C
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 D HW: 4F0 907 279
Component: ILM Fahrer H15 0190
Revision: 00000000 Serial number: 4F0907279
Coding: 0002121
Shop #: WSC 02335 785 00200
VCID: 2A511C7185E4089
Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00141886
Shop #: WSC 02335
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBE7152119
Shop #: WSC 00000 000 00000
VCID: 1C3DCAA9DFB0E69
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 42 AIRBAG AUDI8RH29 0260
Revision: 07H29000 Serial number: 0037LD0A0X12
Coding: 0013362
VCID: 2953E37D80E2031
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90026052500566
Coding: 0002142
Shop #: WSC 02323 785 00200
VCID: E6C92841D17C6C9
Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0080
Address 17: Instruments Labels: None
VCID: 55AB9F8DBC1A771
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H11 0070
Revision: 11 Serial number: 13008059178093
Coding: ECFE73C41B3104
VCID: 2757E54596F6351
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 C
Component: MNS ECE H45 1060
Revision: 00000000 Serial number: 305IQ057635065
VCID: 3B7F29357A7E811
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 F HW: 4F0 959 793 F
Component: TSG FA H21 0050
Coding: 0001546
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H19 0140
Revision: 01400019 Serial number: 01007228340000
Coding: 0393861
VCID: 2E591061B90C649
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 A HW: 4F0 035 223 A
Component: DSP-High C6 H09 0140
Revision: PROD_01 Serial number: 00000000702786
Coding: 0000112
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000136376
Coding: 0001013
VCID: DEB900A1092C349
Address 52: Door Elect, Pass.
Cannot be reached
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0000321
VCID: DDBB07AD042A2F1
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 C
Component: Dynamische LWR H01 0010
Coding: 0000003
VCID: 3A712C317544B89
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541 B
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 394IT057615530
Coding: 0000001
VCID: 31630B1DA8327B1
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000114485
Shop #: WSC 80093 222 69422
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 2509071296
Coding: 344630393135313035442056413032353039303731323936
Shop #: WSC 00000 384 00290
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 F HW: 4F0 959 795 F
Component: TSG HL H21 0050
Coding: 0001026
VCID: 2F670D65BE066D1
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 F HW: 4F0 959 794 F
Component: TSG HR H21 0050
Coding: 0001026
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 C HW: 4F0 919 283 C
Component: Parkhilfe 8-Kan H12 0030
Revision: 00H12000 Serial number: 11820525500280
Coding: 0201016
VCID: 244DF249E7C0DE9
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 C HW: 4E0 862 335
Component: Handyvorb2 H10 0120
Revision: 00000000 Serial number: 00000007580360
Coding: 0010900
End ---------------------------------------------------------------------
---------- Post added at 13.57.19 ---------- Previous post was at 12.50.42 ----------
Per la procedura motoposizionatori ringrazio endy87 !!! GRAZIE ANDREA !!
Ultima modifica di Matpat3; 30-03-2014 alle 12:54
Per quanto riguarda gli errori vaggata ho provato a cancellarli ma dopo alcuni km si ripresentano , specie air quality sensor :-)g238 ,,,,,,,,,per casoé quello sopra specchio retrovisore centrale ? Puo dare noie ?? Sento un rumore di tipo tac tac ogni 5 secondi ,,,ora proverô a fare adattamento motoposizionatori sperando di risolvere ,, volevo rigraziare pure Sbymotta per la sua disponibilità !!!!!
Oggi non sono riuscito a fare nessun adattamento a questi motoposizionatori non capisco il motivo ,,,ho anche chiesto aiuto ad endy87(persona impagabile ) perché pensavo di aver sbagliato qualche passaggio ma nulla il procedimento era quello giusto ,,, forse dovrò andare in audi e perdere 1 giornata di lavoro oltre che presumo denaro !!!!!!!!!!!!!!! qualcuno può darmi una mano ??? magari nella vaggata che ho fatto c'è la causa di tutto questo ,,,,,
Allora
il 01592 - Air Quality Sensor (G238) open or short to plus
potrebbe essere che il sensore della qualità dell'aria sia staccato o non più funzionante
dovresti controllarlo o eventualmente sostituirlo
guardando la vaggata non si direbbe che il prblema sia imputabile ai motoposizionatori, ma bensì ad un sensore che non risponde, quindi a prescindere dal fatto che non sei riuscito a fare l'adattamento,l'errore se fosse sporadico facendo un clear dtc dovrebbe sparire , se torna o non si cancella c'è sicuramente qualcosa da verificare quali, cablaggi o sensore stesso.
Grazie ,, per l'aiuto ,,cmq sapete dove si trova questo sensore ????? lo strano è che il clima funziona regolarmente a parte questo TAc TOC proveniente dal cruscotto ,,,,,ora che ci penso però questo errore è da prima che acquistassi vag che è in memoria ( 1 anno) e mai mi ha dato fastidio o meglio mai nessun rumore strano ,,,, oggi per la prima volta non è riapparso il rumore ,,,sembra come se fosse un relè tanto per farvi capire ,,attacca e stacca ogni 5/7 secondi !!!!!!!!!!!
Ultima modifica di F.audi6; 01-04-2014 alle 22:14
quel sensore se non erro dovrebbe essere sulle bocchette centrali, vado a memoria quindi potrei sbagliarmi.
Comunque anche il mio clima ogni tanto quando sposta le bocchette fa qualche ticchettio, ma non certo ogni 6 7 secondi.
uhmm
io lo staccherei e rigirandolo vedrei se per caso non balla qualcosa che si è staccato staccato!
Magari il sensore stesso!!
ho capito ,,,,potreste controllarmi se hai modo esattamente dove si trova ??? magari se possiedete tavola pdf ???? buona giornata !!!!!!!! grazie ancora !!!!!!!!!!!!
