Diagnosi vag a3 2.0 tdi 140 cv
Ciao a tutti ragazzi.. mi aiutate perfavore a capire bene a cosa sono dovuti questi errori???
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72 7D
VIN: WAUZZZ8P56A066675 Mileage: 262440km/163072miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 FF HW: 028 101 190 5
Component: R4 2,0L EDC 0000SG 7364
Revision: 12345678 Serial number: AUX7Z0E8FN706C
Coding: 0000072
Shop #: WSC 06314 000 00000
VCID: 6CDDDCF04F75367E58B-8039
4 Faults Found:
19558 - Motor for Intake Manifold Flap (V157)
P3102 - 000 - No Signal
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.46 V
Bin. Bits: 00000100
Torque: 0.0 Nm
Torque: 354.0 Nm
19557 - Motor for Intake Manifold Flap (V157)
P3101 - 000 - Open or Short to Ground
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.46 V
Bin. Bits: 00000100
Torque: 0.0 Nm
Torque: 354.0 Nm
17075 - Fan 1 Control Circuit
P0691 - 000 - Short to GND
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.46 V
Bin. Bits: 00000100
Temperature: 71.1°C
Duty Cycle: 9.6 %
16785 - EGR System
P0401 - 000 - Insufficient Flow
Freeze Frame:
RPM: 1848 /min
Torque: 60.0 Nm
Speed: 64.0 km/h
Load: 20.0 %
Duty Cycle: 14.7 %
Bin. Bits: 11000000
Mass Air / Rev.: 285.0 mg/str
Mass Air / Rev.: 695.0 mg/str
Readiness: 1 3 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 Q HW: 1K0 907 379 Q
Component: ESP FRONT MK60 0102
Revision: 00T12001
Coding: 0023170
VCID: 40855840137D021ED43-8015
1 Fault Found:
00285 - ABS Wheel Speed Sensor; Front Right (G45)
003 - Mechanical Failure - Intermittent
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 H HW: 8P0 820 043 H
Component: KlimavollautomatH17 0200
Revision: 236710 Serial number: 8P0820043H
VCID: 31630D84A8D79B962BD-8064
No fault code found.
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
Component: Bordnetz-SG H36 1201
Revision: 00H36000 Serial number: 00000002180251
Coding: 01884F009214100000160000160000000008FE175C0100
Shop #: WSC 06314 000 08192
Subsystem 1 - Part No: 8P1 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
1 Fault Found:
02395 - Parking Light Front Right (M3)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 199
Mileage: 256143 km
Time Indication: 0
Date: 2014.01.13
Time: 23:10:00
Freeze Frame:
ON
Voltage: 13.80 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 C HW: 8P0 959 655 C
Component: Airbag 9.41 H12 3760
Revision: 91H12376 Serial number: 00362004BKLO
Coding: 0073622
VCID: 428152481D71100EC27-8017
Subsystem 1 - Serial number: 6332DRB40206091DE
Subsystem 2 - Serial number: 6342DRB4020605265
Subsystem 3 - Serial number: 63528RB400A9B319N
Subsystem 4 - Serial number: 63628RB400A9A769W
Subsystem 5 - Serial number: 63729RB400A4102EE
Subsystem 6 - Serial number: 63829RB400A410166
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AF HW: 1K0 953 549 AF
Component: Lenksäulenmodul 034 0070
Coding: 0000012
VCID: 76E9FE980139FCAEBEF-8023
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 930 R HW: 8P0 920 930 R
Component: KOMBIINSTR. VDO H80 0410
Revision: D03 Serial number: 2248ED03030677
Coding: 0004143
Shop #: WSC 00011 888 96745
VCID: 41835D4418770B16DBD-8014
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 280010583186A5
Coding: 3D3F0B42072102
VCID: 2A511AE88501E84EEA7-807F
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D03 Serial number: AUX7Z0E8FN706C
Shop #: WSC 00000 000 00000
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
Part No: 8P0 959 801 H
Component: Tuer-SG 020 0070
Coding: 0000144
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
VCID: 32610288ADD1A08E527-8067
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 E
Component: KSG H04 0050
Coding: 188000186D088505488F016300
VCID: 3E7926B8698974EEA6F-806B
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 HW: 8P4 035 382
Component: AB2 SUBWOOFERBOXH04 0180
Revision: 00003 Serial number: 30674526052679
VCID: F1E34D84E8575B96EBD-80A4
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
Part No: 8P0 959 802 H
Coding: 0000144
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 186 C HW: 8P0 035 186 C
Component: concert II EU H52 0100
Revision: 02S Serial number: AUZ2Z3E2864474
Coding: 0001001
Shop #: WSC 06435 000 00000
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No: 8P4 959 801 D
Component: Tuer-SG 020 0060
Coding: 0000144
Coding: 0000144
Coding: 0001001
Coding: 0000144
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No: 8P4 959 802 D
Coding: 0000144
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D5B11F4B4EFFF760F5-8078
End ---------------------------------------------------------------------
Tuesday,08,April,2014,15:03:30:65217
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WAUZZZ8P56A066675 License Plate:
Mileage: 262440km-163072mi Repair Order:
Control Module Part Number: 03G 906 016 FF HW: 028 101 190 5
Component and/or Version: R4 2,0L EDC 0000SG 7364
Software Coding: 0000072
Work Shop Code: WSC 06314 000 00000
4 Faults Found:
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.46 V
Bin. Bits: 00000100
Torque: 0.0 Nm
Torque: 354.0 Nm
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.46 V
Bin. Bits: 00000100
Torque: 0.0 Nm
Torque: 354.0 Nm
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.46 V
Bin. Bits: 00000100
Temperature: 71.1°C
Duty Cycle: 9.6 %
16785 - EGR System
Freeze Frame:
RPM: 1848 /min
Torque: 60.0 Nm
Speed: 64.0 km/h
Load: 20.0 %
Duty Cycle: 14.7 %
Bin. Bits: 11000000
Control Module Part Number: 1K0 907 379 Q HW: 1K0 907 379 Q
Component and/or Version: ESP FRONT MK60 0102
Software Coding: 0023170
1 Fault Found:
Inviato dal mio SM-N9005 utilizzando Tapatalk
Non mi aiuta nessuno???
Ciao, hai provato a cancellarli? Comunque questa non è la sezione corretta per domande di questo genere...
Sì ho provato a cancellare ma nn vanno via.. dove dovrei postare allora..???
Qui!
http://forum.audirsclub.it/forumdisp...agnosi-Vag-Com
Per gli errrori aspetta qualcuno che se ne intenda.
Hai da cambiare il corpo farfallato e l'egr....e lava i collettori visto che ci sei...
---------- Post added at 08:08 ---------- Previous post was at 08:07 ----------
E il sensore abs anteriore destro...
Pulito corpo farfallato e valvola egr.. cambiato fusibile (f24 se non ricordo male) spia motore sparita
