Ciao a tutti,
ho finalmente completato l'up dei sensori parcheggio da solo dietro a dietro e davanti (centralina, sensori, cicalino, tasto originali e cavi kufatec). Dalle prime prove il sistema sembra funzionare bene, il problema è che a lavoro ultimato ho fatto x scrupolo un auto scan e mi sono saltati fuori un sacco di errori
Eccoli:
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 BH HW: 8K0 907 379 BH
Component: ESP8 front H04 0060
Revision: -------- Serial number: --------------
Coding: 170D08
Shop #: WSC 06334 000 00000
VCID: 800FE68B13F6581E143-80D5
1 Fault Found:
01771 - Control Module for Headlight Range (J431)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 4
Fault Frequency: 8
Reset counter: 36
Mileage: 48544 km
Time Indication: 0
Date: 2014.05.11
Time: 20:45:40
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x40A2
Hex Value: 0x0035
Hex Value: 0x4091
Hex Value: 0x00FF
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 N HW: 8K0 907 063 N
Component: BCM1 1.0 H30 0392
Revision: 09030001 Serial number: 00000001263997
Coding: 260050914034AF210701000000001D0D4F9C47080201014100 0000
Shop #: WSC 06335 123 12345
VCID: 3A7BD463B5AA42CE9A7-806F
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 201011 H07 0070
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 34
Mileage: 48544 km
Time Indication: 0
Date: 2014.05.11
Time: 20:45:00
03207 - Charisma Switch Module
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 3
Mileage: 47246 km
Time Indication: 0
Date: 2014.04.25
Time: 18:36:00
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 AJ HW: 8T0 907 468 L
Component: GW-BEM 5CAN-M H10 0120
Revision: FC201059 Serial number: 5900F11A100360
Coding: 00C303
Shop #: WSC 06335 000 00000
VCID: 8919FBAF20CC195643D-80DC
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H07 0170
2 Faults Found:
00384 - Optical Databus
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 74
Mileage: 48544 km
Time Indication: 0
Date: 2014.05.11
Time: 16:02:34
Freeze Frame:
Bin. Bits: 10000
Voltage: 12.20 V
Count: 7
Bin. Bits: 00000
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 34
Mileage: 48544 km
Time Indication: 0
Date: 2014.05.11
Time: 20:45:39
Freeze Frame:
Bin. Bits: 01011
Voltage: 11.60 V
Count: 6
Bin. Bits: 00010
Time: 0.40 s
Address 55: Xenon Range
Cannot be reached
Address 56: Radio Labels: None
VCID: 55A167DFBCF48DB6975-8000
No Faults Found
or DTCs not supported by controller
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8T1 035 652 G HW: 8T1 035 652 D
Component: B-BN-EU H61 0147
Revision: -------- Serial number: 323J 0B7683730
Coding: 010100010006E1ED1D000F0E000000030000
VCID: 3979CB6FB0AC49D693D-806C
Subsystem 1 - Part No SW: 8T0 919 604 HW: 8T0 919 604
Component: DU6 Basic H42 0084
Subsystem 2 - Part No SW: 8T0 919 609 HW: 8T0 919 609
Component: E0380 Bedient H08 0100
3 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 74
Mileage: 48544 km
Time Indication: 0
Date: 2014.05.11
Time: 16:00:32
Freeze Frame:
Voltage: 12.40 V
02244 - Button in Control Head is Stuck
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 36
Mileage: 48586 km
Time Indication: 0
Date: 2014.05.12
Time: 22:01:07
Freeze Frame:
Voltage: 12.30 V
Bin. Bits: 10000000 00000000
Bin. Bits: 00000000 00000000
03157 - Functionality limited due to Communications Disruption
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 43
Mileage: 47246 km
Time Indication: 0
Date: 2014.04.25
Time: 20:43:22
Freeze Frame:
Bin. Bits: 00000001 00000000
Due di questi, uno sul 5F ed uno sulla centr09 erano comparsi in seguito all'attivazione dal menu car dell'audi drive select (tra l'altro io non sento differenze nel passare nelle varie modalità) ma tutti gli altri sembrano conseguenza dell'installazione sensori anteriori....non mi sarò mica dimenticato di ricollegare qlcs???.. Molto strano anche che non veda i fari allo xenon che invece funzionano regolarmante..
Chiedo disperatamente aiuto!!!!!!!!!!!!!!!!!
