Risultati da 1 a 3 di 3
Discussione: Errori rilevati con VAG
    Jun 2013
    Perugia (PG)
    audi a3
    Predefinito Errori rilevati con VAG
    Qualcuno saprebbe aiutarmi a risolvere questi problemi che mi da l'auto?
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 57 76 77 7D
    VIN: WAUZZZ8PXXXXXXXXX Mileage: 394920km/245391miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: Malfunction 0010
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    57-TV Tuner -- Status: OK 0000
    76-Park Assist -- Status: Malfunction 0010
    77-Telephone -- Status: Malfunction 1010
    7D-Aux. Heat -- Status: Malfunction 0010
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 016 FF HW: 028 101 190 5
    Component: R4 2,0L EDC G000SG 6337
    Revision: 12345678 Serial number: AUX7Z0D5FNB035
    Coding: 0000072
    Shop #: WSC 06435 000 00000
    VCID: 6CDC73DA4F5CE17E43D
    No fault code found.
    Readiness: 0 0 1 1 1
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No: 1K0 907 379 K
    Component: ESP FRONT MK60 0103
    Coding: 0023174
    VCID: 3A70858275888FCE811
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 F HW: 8P0 820 043 F
    Component: KlimavollautomatH12 0150
    Revision: 007849 Serial number: 8P0820043F
    Shop #: WSC 00000 000 00000
    VCID: 2F66A4D6BECA5A6626F
    1 Fault Found
    00483 - Control Module for Auxiliary Air Heater
    013 - Check DTC Memory
    Freeze Frame:
    Fault Status: 01101101
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 4
    Mileage: 394922 km
    Time Indication: 0
    Freeze Frame:
    ON
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 C HW: 8P0 907 279 C
    Component: Bordnetz-SG H31 0202
    Revision: 00H31000 Serial number: 00000000828796
    Coding: E7885F068214100000000000000000000002FE0F5C
    Shop #: WSC 01913 264 93080
    VCID: 3D7A8E9E64A6B8F6A43
    Subsystem 1 - Part No: 8P1 955 119 B Labels: 1KX-955-119.CLB
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 01913
    Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH10 0040
    Coding: 00150573
    Shop #: WSC 01913
    Address 15: Airbags Labels: 8P0-959-655-84.lbl
    Part No SW: 8P0 959 655 D HW: 8P0 959 655 D
    Component: Airbag 8.4ED H00 0140
    Coding: 0010602
    VCID: 438EF8660242CE06D27
    Address 16: Steering wheel Labels: 8P0-953-549.lbl
    Part No SW: 8P0 953 549 HW: 8P0 953 549
    Component: Lenksäulenmodul H11 0020
    Coding: 0000042
    VCID: FBFEC086BA32F6C65A7
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 930 K HW: 8P0 920 930 K
    Component: KOMBIINSTR. VDO H71 0200
    Revision: D01 Serial number: 2245DD01002845
    Coding: 0004108
    Shop #: WSC 80093 222 69422
    1 Fault Found
    16346 - Control Module - ROM Error
    014 - Defective
    Freeze Frame:
    Fault Status: 00000011
    Fault Priority: 1
    Fault Frequency: 1
    Mileage: 356247 km
    Time Indication: 0
    Date: 2016.08.12
    Time: 13:44:08
    Address 19: CAN Gateway Labels: Redir Fail!
    Part No SW: 1K0 907 530 D HW: 1K0 907 951
    Component: Gateway H08 0100
    Revision: 08 Serial number: 2500104521058E
    Coding: 3D0F0FD8073100
    Shop #: WSC 01913 264 63888
    VCID: 28544FCA9B240D5EE75
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D01 Serial number: AUX7Z0D5FNB035
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8P0 035 192 HW: 8P0 035 192
    Component: RNS-E HIGH EU H44 0650
    Revision: 03S Serial number: AUZBZ7D0003387
    Coding: 0209712
    VCID: ECDCF3DACF5C617EC3D
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX1.lbl
    Part No: 8P0 959 801 D
    Component: Tuersteuerger. H10 0030
    Coding: 0000120
    VCID: 3C7C839A7FBCB1FE93D
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K1 909 144 G
    Component: EPS_ZFLS Kl.10 1401
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 B
    Component: KSG H02 0040
    Coding: 008000186D288505488A016000
    VCID: 3B7E80867AB2B6C69A7
    Subsystem 1 - Component: Sounder n.mounted
    Subsystem 2 - Component: NGS n.mounted
    Subsystem 3 - Component: IRUE n.mounted
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MAX1.lbl
    Part No: 8P0 959 802 D
    Coding: 0000120
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0209712
    Address 57: TV Tuner Labels: 4D0-919-146.clb
    Part No SW: 4D0 919 146 C HW: 4D0 919 146 C
    Component: TV Tuner H02 0430
    Revision: 01H02001 Serial number: 00000000005019
    Coding: 0002010
    VCID: 29524ACE802E3456F8B
    Address 76: Park Assist Labels: 8P0-919-283.lbl
    Part No SW: 8P0 919 283 HW: 8P0 919 283
    Component: Parkhilfe 4-Kan H06 0030
    Coding: 0000003
    VCID: F8F4DF8A8B04DDDE375
    1 Fault Found
    01543 - Parking Aid Warning Chime (H15)
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 4
    Mileage: 394922 km
    Time Indication: 0
    Date: 2018.01.21
    Time: 13:49:19
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8P0 862 335 F HW: 8P0 862 335 F
    Component: FSE_255x BT H21 0190
    Revision: 00000001 Serial number: 00000000350219
    Coding: 0010444
    VCID: 39729A8E708E84D688B
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 D HW: 1K0 963 235 D
    Component: PTC-Element 0404
    Revision: 00700000 Serial number:
    VCID: 2C5CB3DA8FDC217E03D
    1 Fault Found
    00361 - Heater Element for Auxiliary Heater (Z35)
    014 - Defective
    End ---------------------------------------------------------------------
    Thanked: 765
    ammazza!!!! sei arrivato a 394.900 km?? che motore, il bkd!! spero che duri altrettanto il mio bmm...
    per gli errori nell'address 08 e 7D, si tratta della serpentina elettrica che riscalda l'abitacolo (quella serpentina parte in automatico a motore freddo e temperatura esterna molto bassa). in teoria, si sara' bruciata la serpentina (la diagnosi dice defective). la serpentina e' montata a destra del pedale acceleratore, dentro i condotti del clima, non e' facile raggiungerla (bisogna smontare tunnel, mille pezzi sotto al cruscotto, ecc)
    l'errore nell'address 17 e' vecchio di 1 anno e 5 mesi e si e' presentato una sola volta (12 agosto 2016). forse quel giorno hai fatto dei lavori a bordo, magari hai staccato dei connettori elettrici e poi li hai ri-collegati. quell'errore lo puoi cancellare, e secondo non torna piu.
    nell'address 76, direi che si e' bruciato il cicalino dei sensori di parcheggio (di solito e' montato nel fianchetto di destra del bagagliaio).
    oppure anche lì hai staccato un connettore elettrico, per arrivare a smontare altri pezzi, e magari hai dimenticato di ri-collegare quello spinotto.
    prova cancellare gli errori con "clear all dtc", poi ripeti la scansione.
    gli errori risolti (cioe guasti gia' riparati, o fittizi) non tornano piu, mentre i guasti ancora presenti generano immediatamente un identico errore in diagnosi. e ti concentri solo su quelli
    Jun 2013
    Perugia (PG)
    audi a3
    Grazie mille Gian8p avevo gia’ tentato clear all dtc ma si sono ripresentati lo stesso....
    Quello che invece vedo a cruscotto e’ il simbolo delle candelette che durante la marcia e’ lampeggiante.... i sensori parcheggio non funzionano...la spia abs passeggero accesa sul rosso sempre sul cruscotto...inoltre non funziona lo sbrinamento sul lunotto posteriore
    Grazie ancora...
    Il motore incrocio le dita e’ una bomba...non l’ho mai toccato...mai pompato, lasciato originale come e’....l,unica cosa che vorrei fare e’ tappare lo scambiatore della valvola egr per evitare che mi consumi acqua del radiatore.
    Ultima modifica di icecom; 24-01-2018 alle 19:56 Motivo: Aggiunte
