Prime vaggate
Salve
Sono alle prime armi col VAG ,mi da un errore , riuscite ad aiutarmi?
Chassis Type: 4L (4F0)
Scan: 01 02 03 05 08 09 15 16 17 19 42 46 4F 52 55 56 5F 62 6F 72
76
VIN: WAUZZZ4L3AD010406 Mileage: 75160km/46702miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
6F-Centr. Conv. II -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine (CCM) Labels: Redir Fail!
Part No SW: 4L0 910 401 P HW: 4L0 907 401 B
Component: 3.0TDI EDC17G000AG 0070
Revision: 31H02--- Serial number:
Coding: 0121002D190F0168
Shop #: WSC 83734 416 403048
VCID: 2F6B65E7BE9F9E66327-807A
1 Fault Found:
005405 - Start Interruption due to Insufficient Engine Speed
P151D - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 255
Mileage: 75040 km
Time Indication: 0
Date: 2015.04.15
Time: 19:58:44
Freeze Frame:
RPM: 567 /min
Speed: 0.0 km/h
Voltage: 11.78 V
Bin. Bits: 00000010
Bin. Bits: 0
Temperature: 92.7°C
Bin. Bits: 00000001
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No SW: 09D 927 750 JE HW: 09D 927 750 JE
Component: AL 750 6A 1643
Revision: 00H78000 Serial number:
Coding: 0000504
Shop #: WSC 31414 790 00001
VCID: 7AFD84B3355D8BCED59-802F
No fault code found.
Address 03: ABS Brakes Labels: 4L0-910-517.clb
Part No SW: 4L0 910 517 K HW: 4L0 614 517 K
Component: ESP ALLRAD MK25E1 0020
Revision: 00H30001
Coding: 0099473
VCID: 326D6C93ADADB38E5D9-8067
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 D
Component: FBSAUDIC6 ELV H05 0100
Revision: 00H05000 Serial number: 10602601472111
Coding: 0000131
VCID: 254787CFEC63D436C8B-8070
Subsystem 1 - Part No: 4F0 910 132 E
Component: FBSAUDIC6 EZS H03 0020
Subsystem 2 - Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H01 0054
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 4L0 910 043 C HW: 4L0 820 043 AA
Component: KLIMA 4 ZONEN H12 0030
Revision: 00---017 Serial number: 00000030137707
Coding: 002016
VCID: 24419ACB27592D3EDF5-8071
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 R HW: 4F0 907 279
Component: ILM Fahrer H26 0340
Revision: 00000000 Serial number: 4F0907279
Coding: 0023121
VCID: 38795EBB4BD159DE63D-806D
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H17 0100
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00150059
Shop #: WSC 31414
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 D HW: 4L0 959 655 C
Component: 71 AIRBAG AUDI8RH43 0230
Revision: 04H43000 Serial number: 00399D06CSRL
Coding: 0014129
VCID: 2E5578E3B995976E391-807B
Subsystem 1 - Serial number: 6332QSME1E47543CP
Subsystem 2 - Serial number: 6342QSME19484D30I
Subsystem 3 - Serial number: 6352QSME1E4701105
Subsystem 4 - Serial number: 6362QSME37475732G
Subsystem 5 - Serial number: 63734SME0D410238W
Subsystem 6 - Serial number: 63834SME12424624R
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0530
Revision: 00H05000 Serial number: 90026093490113
Coding: 0002142
Shop #: WSC 00870 264 97363
VCID: 275B8DC7966FC626FA7-8072
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0030
Address 17: Instruments (J285) Labels: 4L0-920-xxx-17.clb
Part No SW: 4L0 920 900 N HW: 4L0 920 900 N
Component: KOMBIINSTR. H08 0147
Revision: 00000000 Serial number: DK905FGD9
Coding: 0356640400000008040100
VCID: 326D6C936DADB38E5D9-8067
Address 19: CAN Gateway (J533) Labels: 4F0-907-468.clb
Part No SW: 4F0 907 468 M HW: 4F0 907 468 F
Component: GW-BEM 4CAN-M H06 0035
Revision: LB100029 Serial number: 2900L09C110240
Coding: 000303
VCID: 397F5BBFB0DB40D69C3-806C
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Address 42: Door Elect, Driver (J386) Labels: 4F0-959-793.clb
Part No SW: 4F0 959 793 R HW: 8K0 959 793 D
Component: TSG FA H11 0250
Revision: Serial number: 0000102495071
Coding: 011C06205040440004
VCID: 46852043F1253F2EE11-8013
Address 46: Central Conv. Labels: 4L0-910-289.lbl
Part No SW: 4L0 910 289 G HW: 4L0 907 289 G
Component: Komfortgeraet H09 0100
Revision: 0100 --- Serial number: 01203808880000
Coding: 0131205
VCID: 34616A8B57B9BDBE4F5-8061
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280
Component: ILM Beifahrer H13 0100
Revision: Serial number: 00000000504397
Coding: 0011001
VCID: DEB5682309B5C7EE491-808B
Address 52: Door Elect, Pass. (J387) Labels: 4F0-959-792.clb
Part No SW: 4F0 959 792 R HW: 8K0 959 792 D
Component: TSG BF H11 0250
Revision: Serial number: 0000102544616
VCID: 4587274FCC233436E8B-8010
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 H
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000007
VCID: 3F8B35A76EFF6EE6A27-806A
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4F0 035 053 B HW: 4F0 035 053
Component: Radio U Basic H45 0020
Revision: AB001007 Serial number: 341LC097689795
Coding: 010003020100000000
VCID: 1C31A22B1F2915FE675-8049
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 4L0 035 642 HW: 4L0 035 642
Component: B-ER H46 0041
Revision: -------- Serial number: 311LN097506031
Coding: 01000006010483ED01000705C72300000300
VCID: E4C15ACBE7D9ED3E9F5-80B1
Subsystem 1 - Part No SW: 4L0 919 604 HW: 4L0 919 604
Component: DU6 Basic H43 0306
Subsystem 2 - Part No SW: 4L0 910 609 HW: 4L0 919 611
Component: E0380 Bedient H05 0060
2 Faults Found:
03276 - Please Check Software Version Management
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 204
Mileage: 67940 km
Time Indication: 0
Date: 2014.10.30
Time: 14:06:43
Freeze Frame:
Voltage: 12.70 V
02612 - Audio Wire Adapter Set
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 171
Mileage: 73924 km
Time Indication: 0
Date: 2015.04.06
Time: 09:23:37
Freeze Frame:
Voltage: 12.30 V
Address 62: Door, Rear Left (J388) Labels: 4F0-959-795.clb
Part No SW: 4F0 959 795 M HW: 8K0 959 795 B
Component: TSG HL H10 0251
Revision: Serial number: 0000102504083
Coding: 010804204040230004
VCID: 43833957C2170A06C6F-8016
Address 6F: Centr. Conv. II Labels: 4L0-910-290.lbl
Part No SW: 4L0 910 290 HW: 4L0 907 290
Component: ILM HINTEN 2 H05 0060
Revision: AAH05061 Serial number: 003889525-----
Coding: 0000005
VCID: E5C747CF2CE3943688B-80B0
Address 72: Door, Rear Right (J389) Labels: 4F0-959-795.clb
Component: TSG HR H10 0251
Revision: Serial number: 0000102504080
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4L0 910 283 C HW: 4L0 919 283 C
Component: Parkhilfe 8-Kan H02 0500
Revision: 00H02000 Serial number: 12620935001392
Coding: 0201166
VCID: 2A5D74F3857DFB4EE59-807F
End ---------------------------------------------
