Risultati da 1 a 10 di 23
Discussione: Effettuata scansione e trovati vari errori
    Audi lover L'avatar di sprido
    Thanked: 13
    Cosenza (CS)
    A3 Sportback S-line 2.0 tdi 170@ 220hp by ECD PERFORMANCE
    Predefinito Effettuata scansione e trovati vari errori
    Address 01: Engine Labels: None
    Part No SW: 03G 906 018 DH HW: 03G 906 018 DH
    Component: R4 2.0l PPD1.2 G 1185
    Coding: 0000072
    Shop #: WSC 00878
    1 Fault Found:
    005685 - Powertrain Data Bus: Missing Message from A/C Controller
    P1635 - 009 - Open or Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00000100
    Fault Priority: 0
    Fault Frequency: 3
    Reset counter: 19
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    0.00 %
    Voltage: 12.09 V
    Bin. Bits: 00000000
    Bin. Bits: 00000000
    Readiness: N/A
    Address 19: CAN Gateway Labels: 1K0-907-530.LBL
    Part No SW: 1K0 907 530 J HW: 1K0 907 951
    Component: J533__Gateway H12 0160
    Coding: 3D3F0B4207002102
    Shop #: WSC 06314
    1 Fault Found:
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 48
    Mileage: 13242 km
    Time Indication: 0
    Date: 2009.01.10
    Time: 20:40:37
    Address 37: Navigation Labels: None
    Part No SW: 8P0 035 192 Q HW: 8P0 035 192 Q
    Component: RNS-E HIGH EU H75 0660
    Coding: 0205117
    Shop #: WSC 06314
    1 Fault Found:
    02454 - Microphone Unit (in Front Roof Module) (R164)
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 48
    Mileage: 13242 km
    Time Indication: 0
    Date: 2009.01.10
    Time: 20:40:37
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN.LBL
    Part No: 8P0 959 802 H
    Component: Tuer-SG 020 0090
    Coding: 0000144
    Shop #: WSC 06314
    1 Fault Found:
    00940 - Mirror Adjust Motor; Passenger Side (V150)
    012 - Electrical Fault in Circuit - Intermittent
    Address 56: Radio Labels: None
    Coding: 0205117
    Shop #: WSC 06314
    1 Fault Found:
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 48
    Mileage: 13242 km
    Time Indication: 0
    Date: 2009.01.10
    Time: 20:40:37
    Chi mi sa dire a cosa sono dovuti? Ho su da qualche mese cruise, volante multifunzione e navi rns-e ma tutto funziona bene, mentre lo specchio lato passeggero effettivamente nn funzionava ma poi si è ripreso da solo ed ora funziona tranquillamente ma vedo che qui risulta ancora errore...
    Ultima modifica di sprido; 11-01-2009 alle 01:51
    A4 8E avant
    Hai provato a cancellarli con il vag?
    comunque quello del navi e della radio è lo stesso ed in pratica è codificato con volante multifunzione e caricatore Cd, quindi vedo che hai anche l'aggiornamento del software alla 660, quindi con SDS. Ma tu non hai il microfono. o sì?
    Quello dello specchietto se ora si è sistemato, cancellandolo dovrebbe sparire.
    Il primo dovrebbe essere un problema di codifica
    Thanked: 13
    Cosenza (CS)
    Citazione Originariamente Scritto da mauro6569 Visualizza Messaggio
    Innanzitutto grazie, allora si ho cancellato ma ogni volta ricompaiono. Nn ho il microfono, chi mi ha messo il navi so che mi ha attivato l'sds, è per questo secondo te? Per lo specchietto nn riesco a capire, funziona perfettamente sopra sotto destra e sinistra ma mi da lo stesso errore anche dopo averli cancellati 3 volte. Boh...
    A4 8E avant
    Citazione Originariamente Scritto da sprido Visualizza Messaggio
    L'errore del navi-radio è sicuramente quello!
    Riguardo allo specchio è strano che cancellandoli e funzionando regolarmente, ritorni l'errore...
    Thanked: 13
    Cosenza (CS)
    Perfetto quindi basta montare il microfono per fare sparire i due errori relativi a navi e radio. Per lo specchio è un mistero, ad andare va normalmente eppure risulta sempre errore... Forse qualche filo che fa poco contatto? Chissà gli altri due errori che saranno...
    Audi lover L'avatar di Schumyle
    Oct 2008
    Cosenza (CS)
    Audi A3@S3 CV ??? by ECD PERFORMANCE
    Innanzitutto ciao a tutti.......allora per gli errori riferiti al navi confermo quello che avete detto nei vostri messaggi controlla bene le varie codifiche tramite vag però quello del microfono se non lo hai montato sul navi ti porta sempre errore almeno cosi mi ha detto un tecnico che monta i navi.....per gli altri errori ho fatto una scansione e li ho cancellati e fortunatamente non mi sono più apparsi almeno fino ad oggi cmq domani combinazione farò una scansione giusto di controllo e ti farò sapere.....ciao quando sei a cosenza fatti sentire che ci becchiamo....a limite chiamiamo anche Paco e ci andiamo a prendere un bel caffè....ciao ancora a tutti..
    Thanked: 13
    Cosenza (CS)
    Citazione Originariamente Scritto da Schumyle Visualizza Messaggio
    Ok grazie
    Thanked: 13
    Cosenza (CS)
    dopo aver resettato ora finalmente niente più errore specchietto nè errore motore, boh meglio così
    Audi lover L'avatar di Gsi16
    Thanked: 19
    Firenze (FI)
    Audi A5 3.0 Tdi - Audi A3 2.0 Tdi
    Ti diverti a smanettare!!
    Thanked: 13
    Cosenza (CS)
    Citazione Originariamente Scritto da Gsi16 Visualizza Messaggio
    Sono già all'opera di brutto Funziona a meraviglia, grazie ancora
