Chassis Type: 4L (4F0)
Mileage: 74410km/46236miles
Address 01: Engine (J623-CJGA) Labels: 059-907-401-CAS2.clb
Part No SW: 4L1 910 401 H HW: 4L0 907 401 C
Component: 3.0TDI EDC17 H37 0003
Revision: 53H37--- Serial number:
Coding: 2A2A4012A52601020000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM30TDI0114L1910401H 001008
ROD: EV_ECM30TDI0114L1910401H.rod
VCID: 28598EFB5371C95EF3D-807D
1 Fault Found:
5389 - Engine Mount Solenoid Valves (N144/N145)
P1588 00 [109] - Open Circuit
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 73100 km
Date: 2015.05.15
Time: 10:20:14
Readiness: 0 0 0 0 0
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 4L0 035 666 B HW: 4L0 035 666 A
Component: H-BN-EU H49 0107
Revision: -------- Serial number: 473I00A7535942
Coding: 01010006000483ED01000315EF6300030001
VCID: 2C5172EB4F89E57E175-8079
Subsystem 1 - Part No: 8R0 060 884 R
Component: EUR 2010 1107
Subsystem 2 - Part No SW: 8F0 919 604 HW: 8F0 919 604
Component: DU7 High H43 0084
Subsystem 3 - Part No SW: 4L0 910 609 HW: 4L0 919 611 B
Component: E0380 Bedient H05 0060
Subsystem 4 - Part No: 8R0 060 961
Component: CD-Database 1886
1 Fault Found:
03276 - Please Check Software Version Management
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 139
Mileage: 73100 km
Time Indication: 0
Date: 2015.05.15
Time: 10:12:36
Freeze Frame:
Voltage: 12.30 V
Address 62: Door, Rear Left (J388) Labels: 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0361
Revision: Serial number: 0008000025415
Coding: 010804204040230004
VCID: 46852043F1253F2EE11-8013
1 Fault Found:
02110 - Window Regulator Switch
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 180
Mileage: 73906 km
Time Indication: 0
Date: 2015.05.29
Time: 18:17:19
