Buongiorno a tutti,
qualcuno mi può aiutare:
ho questi due problemi:
1)
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F1 910 732 D HW: 4E0 035 729
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 350GM067702940
Coding: 0001006
Shop #: WSC 02335 785 00200
VCID: 2558E67775E1F32A4C164F9-8070
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H02 0060
Subsystem 2 - Serial number: 00000000471259
Subsystem 3 - Serial number: 0113.07.060000000100010766ÿ
Subsystem 4 - Serial number: 010766ÿ
5 Faults Found:
00474 - Control Module for Immobilizer
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 4
Reset counter: 180
Mileage: 229299 km
Time Indication: 0
Date: 2016.07.23
Time: 21:21:24
02095 - Component Protection Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 5
Fault Frequency: 6
Reset counter: 180
Mileage: 229299 km
Time Indication: 0
Date: 2016.07.23
Time: 21:21:24
01327 - Control Module for Parking Aid (J446)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 180
Mileage: 229336 km
Time Indication: 0
Date: 2016.07.24
Time: 17:33:49
00384 - Optical Databus
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 179
Time Indication: 15
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 5
Reset counter: 40
Mileage: 229299 km
Time Indication: 0
Date: 2016.07.23
Time: 21:21:24
Freeze Frame:
Bin. Bits: 10
2)
Monday,25,July,2016,17:02:31:04550
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 15.7.0.2
Data version: 20150820
www.Ross-Tech.com
VIN: License Plate:
Control Module Part Number: 4F0 910 468 A
Component and/or Version: Gateway H11 0070
Optical Bus Diagnostic : Standard
Controller Electrical Optical
19-CAN Gateway ERROR ERROR
07-Control Head ERROR ERROR
0E-Media Player 1 ERROR ERROR
47-Sound System ERROR ERROR
56-Radio ERROR ERROR
37-Navigation ERROR ERROR
E' ovviamente la mmi che si spegne e si accendo 2/3 volte prima di funzionare senza interruzioni.
audi a6 4f bre 2.0 103kw 2006
Grazie mille....
