Risultati da 1 a 5 di 5
Discussione: Prima Vaggata.....Che Figata!!!!!
    Nov 2017
    Latina (LT)
    A8 3.0 quattro
    Predefinito Prima Vaggata.....Che Figata!!!!!
    ieri e' arrivato Il Vag (versione 17.8.0.1) con il suo cavo Rosstech.
    Non ho perso tempo e nella notte, invece di andare a dormire, ho smanettato di qua e di la prendendo spunto dai post sul forum.
    ecco cosa ne e' uscito fuori:
    Chassis Type: 4E (4L0)
    Scan: 01 02 03 05 06 07 08 09 13 15 16 17 18 19 1E 34 36 37 38 42
    46 47 4F 52 53 55 56 57 61 62 72 76 77
    VIN: WAUZZZ4E69N004901 Mileage: 156640km-97331miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    06-Seat Mem. Pass -- Status: OK 0000
    07-Control Head -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    13-Auto Dist. Reg -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    18-Aux. Heat -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    1E-Media Player 2 -- Status: OK 0000
    34-Level Control -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: Malfunction 0010
    37-Navigation -- Status: OK 0000
    38-Roof Electronics -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    57-TV Tuner -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 08: Auto HVAC Labels: None
    Part No SW: 4E0 910 043 B HW: 4E0 820 043 F
    Component: KLIMAAUTOMAT 017 0450
    Revision: 00000032 Serial number: 00000000152607
    Coding: 0002113
    Shop #: WSC 02311 785 00200
    VCID: 1C36ECECDFABC6A676-8048
    1 Fault Found:
    00819 - High Pressure Sensor (G65)
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 3
    Fault Frequency: 7
    Reset counter: 122
    Mileage: 155603 km
    Time Indication: 0
    Date: 2017.11.06
    Time: 17:12:04
    Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
    Part No SW: 4E0 910 279 S HW: 4E0 907 279 S
    Component: ILM Fahrer H16 0240
    Coding: 0143121
    Shop #: WSC 00071 264 63296
    VCID: 387E107C4B538A8672-806C
    Subsystem 1 - Part No: 4E1 910 113 C
    Component: Wischer WWS D3 H60 0420
    Coding: 00000035
    Shop #: WSC 00071
    Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH04 0003
    Coding: 00139548
    Shop #: WSC 00071
    1 Fault Found:
    01494 - Bulb for Parking Lamps; Left (M1)
    010 - Open or Short to Plus
    Freeze Frame:
    Fault Status: 01101010
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 89
    Mileage: 156640 km
    Time Indication: 0
    Date: 2017.11.14
    Time: 20:23:45
    Address 13: Auto Dist. Reg Labels: None
    Part No SW: 4E0 910 561 F HW: 4E0 907 561 F
    Component: ABSTANDSREGELUNGH03 0020
    Coding: 0031168
    Shop #: WSC 02313 785 00200
    VCID: 2540C908ECE1076ED9-8070
    3 Faults Found:
    01317 - Control Module in Instrument Cluster (J285)
    013 - Check DTC Memory - Intermittent - MIL ON
    Freeze Frame:
    Fault Status: 10111101
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 97
    Mileage: 155600 km
    Time Indication: 0
    Date: 2017.11.06
    Time: 16:18:00
    Freeze Frame:
    Temperature: 34.0°C
    Voltage: 9.60 V
    Bin. Bits: 00100000
    00234 - Sensor for Automatic Distance Regulation Misadjusted
    000 - - - Intermittent - MIL ON
    Freeze Frame:
    Fault Status: 10110000
    Fault Priority: 5
    Fault Frequency: 128
    Reset counter: 129
    Mileage: 155600 km
    Time Indication: 0
    Date: 2017.11.06
    Time: 17:00:00
    Freeze Frame:
    Temperature: 38.0°C
    Voltage: 13.70 V
    Bin. Bits: 00100000
    00003 - Control Module
    014 - Defective - Intermittent - MIL ON
    Freeze Frame:
    Fault Status: 10111110
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 100
    Mileage: 155784 km
    Time Indication: 0
    Date: 2017.11.08
    Time: 19:07:00
    Freeze Frame:
    Temperature: 21.0°C
    Voltage: 13.70 V
    Bin. Bits: 00100110
    Address 36: Seat Mem. Drvr Labels: None
    Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
    Component: Sitzmemory FS H02 0010
    Revision: 00000000 Serial number: 5DS 008 795-03
    Coding: 4063330
    VCID: 2446D40CE7DBFE66CE-8070
    2 Faults Found:
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 89
    Mileage: 150624 km
    Time Indication: 0
    Date: 2017.02.27
    Time: 00:04:55
    01446 - Sensor for Driver Seat; Seatback Adjust (G230)
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 89
    Mileage: 0 km
    Time Indication: 0
    Date: 2008.01.01
    Time: 00:00:00
    Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
    Part No SW: 4E1 910 802 B HW: 4E1 959 802 F
    Component: Türsteuer.BF BRM005 0180
    Coding: 0028460
    VCID: 204ED81CF3C3E246AA-8074
    1 Fault Found:
    02115 - Locking Unit for Central Locking
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 111
    Mileage: 155872 km
    Time Indication: 0
    Date: 2017.11.11
    Time: 07:31:36
    Ora , l'aria condizionata ha una perdita nel radiatore
    La portiera di destra Anteriore non sempre mi si apre con il telecomando.
    il Radar come detto nel precedente post sara' starato
    Il sedile del conducente non rispetta la posizione memorizzata ,da una ricerca forse la causa e' il sensore dello schienale.
    In tutto questo no capisco una cosa.
    Mi dice che la lampadina M1 e' rotta, ma realmente a me funziona tutto!1
    quale dovrebbe essere questa M1??
    Questa macchina e questa diagnosi sono una figata, nulla da invidiare alla mia precedente S320cdi
    grazie mille
    Aug 2017
    Thanked: 11
    varie
    Bè, la tecnologia va avanti! Se prendi una MErcedes S nuova hai diagnosi anche più evolute!
    Comunque..
    1 Fault Found:
    La parking lamp se non erro è la freccia laterale.
    Open or Short to Plus --> Questo indica un corto o un filo aperto sul positivo dell'alimentazione. Dai un occhio al connettore che sia tutto a posto. Potrebbe essere un contatto che avviene ogni tanto, quindi la lampadina funziona ma il SW rileva quel DTC.
    Qui la RossTech Wiki:
    http://wiki.ross-tech.com/wiki/index.php/01494
    Dice che potrebbe essere una lampadina "sbagliata" o magari non la sua originale che da dei problemi.
    Ma non è che hai delle lampadine a LED aftermarket?
    Thanked: 764
    per la lampadina , ci sara un falso contatto, intermittente e casuale, magari si 'e formato un po' di ossido nel portalampade.
    oppure la lampada e' allentata, innestata male (vibrazioni del motore, buche stradali, ecc, la fanno "ballare" nella sua sede, e perde il contatto).
    cancella l'errore (con il comando clear dtc), e vedi se si ripresenta.
    in teoria si dovrebbe accendere anche una spia nel cruscotto, e un messaggio nel fis indica di preciso quale lampada e' bruciata.
    magar il tuo errore e' vecchio, gia' risolto, lampadina gia cambiata, ma non e' stata cancellata la memoria guasti.
    se hai messo lampade a led, l'errore non scomparira' perche il computer di bordo non sente il giusto assorbimento (il led consuma pochissimo rispetto alle lampade alogene, e il cdb pensa che la lampada sia bruciata).
    ci vuole una resistenza, per ingannare il check/computer di bordo.
    P.S. secondo me la M1 e' una luce di posizione, la freccia viene indicata in diagnosi come "turn signal", mi pare.
    Nov 2017
    Latina (LT)
    A8 3.0 quattro
    ok grazie ragazzi le controllero' tutte e due.
    niente led ,lampade originali.
    l'errore ho provato a cancellarlo ma si ripropone ogni volta che accento la macchina essento i fari in auto.
    ricerchero' un falso contatto oppure ossido
    grazie di nuovo a tutti
    Aug 2017
    Thanked: 11
    varie
    ho pensato anche io alla luce di posizione come "parking light", ma su rosstech sembrava indicare la freccia.
    Possible Symptoms
    • M1 light does not illuminate
    Possible Causes
    • Blown fuse
    • Failed or incorrect turn signal bulb installed
    • Wiring harness issue
    Possible Solutions
    • Verify fuses are good
    • Verify correct light bulbs are installed
    • Test wiring harness, see factory repair manual
