Risultati da 1 a 3 di 3
Discussione: Errori vag
    Aug 2014
    Ferrara (FE)
    a4 avant 2.0tdi fap b8
    Predefinito Errori vag
    Buonasera a tutti...ho fatto una vaggata alla mia belva e mi ha dato alcuni errori, qualcuno ferrato in materia mi puo' dire qualcosa al riguardo? Grazie a tutti
    VIN: WAUZZZ Mileage: 128020km-79547miles
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    13-Auto Dist. Reg -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: OK 0000
    5C-Lane Maintain. -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine (J623-CJCA) Labels: 03L-906-018-CGL.clb
    Part No SW: 03L 906 018 AC HW: 03L 906 018 JL
    Component: R4 2.0l TDI H25 9978
    Revision: 45H25---
    Coding: 12194012234401080000
    Shop #: WSC 53288 001 1048576
    ASAM Dataset: EV_ECM2T0DI01103L906018AC 003007
    ROD: N/A
    VCID: 6BD21CEE821EB0192C-803E
    No ASAM data for: "EV_ECM2T0DI01103L906018AC" (AU48)
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
    Part No SW: 8K0 907 379 CH HW: 8K0 907 379 CH
    Component: ESP8 front H09 0100
    Revision: -------- Serial number: --------------
    Coding: 161D4C
    Shop #: WSC 06335 000 00000
    VCID: 010E5E4698924A49E6-8054
    1 Fault Found:
    02214 - Tire Pressure Warning
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 157
    Mileage: 124588 km
    Time Indication: 0
    Date: 2017.06.08
    Time: 09:10:23
    Freeze Frame:
    Hex Value: 0x3D00
    Hex Value: 0x4006
    Hex Value: 0x1221
    Hex Value: 0x1BB6
    Hex Value: 0x0000
    Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
    Part No SW: 8K0 907 064 GD HW: 8K0 907 064 FD
    Component: BCM2 2.0 H12 0633
    Revision: 00002001
    Coding: 03A24000000000000000
    VCID: 78F833A2CB480B81D1-802C
    Subsystem 1 - Part No SW: 8K0 959 754 H HW: 8K0 959 754 H
    Component: FBSAUDIB8 IDG H71 0083
    Serial number: 0812000195381012
    Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
    Component: J764 ELV MLB H40 0046
    Serial number: 2312000280502014
    Address 08: Auto HVAC (J255) Labels: Redir Fail!
    Part No SW: 8K1 820 043 AJ HW: 8K1 820 043 AJ
    Component: KLIMA 3 ZONEN H04 0123
    Revision: C1000000 Serial number: 01141220120326
    Coding: 342002E000
    VCID: 70E80B82A33853C119-8024
    Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
    Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
    Component: BCM1 1.0 H16 0103
    Revision: 08016001 Serial number: 00000533282702
    Coding: 260000108034AFC00081400300001D0D0F1C07082609020100 0008000400020100000024000000
    Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
    Component: WWS 020113 H07 0080
    Serial number: SWF13010025314
    Coding: 00FD11
    Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
    Component: G397_RLFS H06 0002
    Serial number: 20834478
    Coding: 02005D
    Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
    Component: E1 - LDS H03 0031
    Serial number: 00000000001112120791
    Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
    Component: AQ_Hum_Sensor H03 0003
    Serial number: 3C080F56000000000001
    Address 13: Auto Dist. Reg (J428) Labels: None
    Part No SW: 8K0 907 561 B HW: 8K0 907 561 B
    Component: ACC3 H11 0100
    Serial number: 00000000000000
    Coding: 00A4B8
    VCID: 316ECE8668B21AC956-8064
    Address 15: Airbags (J234) Labels: 8K0-959-655.clb
    Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
    Component: AirbagVW-AU10 H45 0610
    Serial number: 003KFD97BC26
    Coding: 30514435363030303030554A304C384B3053
    Shop #: WSC 53012 001 1048576
    ASAM Dataset: EV_AirbeACUVWAUDI010 003010
    ROD: N/A
    VCID: 48988362F328BB0161-801C
    Subsystem 1 - Serial number: 6334MSME7435300D8
    Subsystem 2 - Serial number: 6344MSME75435363A
    Subsystem 3 - Serial number: 6352QSME58253858L
    Subsystem 4 - Serial number: 6362QSME2F260B62M
    Subsystem 5 - Serial number: 63732SME4126525AY
    Subsystem 6 - Serial number: 63832SME7B261B724
    No ASAM data for: "EV_AirbeACUVWAUDI010" (AU48)
    Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
    Part No SW: 8K0 953 568 M HW: 8K0 953 568 M
    Component: Lenks.Modul H03 0005
    Revision: -------- Serial number: 90372MA3001KN
    Coding: 0000DF
    VCID: 44809752C7009F618D-8010
    Component: E221 - MFL H03 0004
    Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
    Part No SW: 8K0 920 931 M HW: 8K0 920 931 M
    Component: KOMBIINSTR. H35 0556
    Revision: 00200000 Serial number: UVY51VHDD
    Coding: 13E4100047010008000000
    VCID: 3878F3A28BC8CB8111-806C
    Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
    Part No SW: 8R0 907 468 P HW: 8R0 907 468 D
    Component: GW-BEM 5CAN-M H11 0055
    Revision: 1Z100027 Serial number: 2741Z12C06026A
    Coding: 80CF07FF00
    VCID: 4C90BF72EF50572145-8018
    Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
    Component: J367-BDMHella H03 8041
    Serial number: 1493408801
    Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
    Component: J532_DCDCStab H17 0042
    Serial number: 12353001296011200181
    1 Fault Found:
    00384 - Optical Databus
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 167
    Mileage: 125783 km
    Time Indication: 0
    Date: 2017.10.27
    Time: 11:25:28
    Freeze Frame:
    Bin. Bits: 10000
    Voltage: 12.30 V
    Count: 11
    Bin. Bits: 00000
    Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
    Part No SW: 8K0 959 793 R HW: 8K0 959 793 P
    Component: TSG FA H02 0506
    Revision: Serial number: 0000047447563
    Coding: 011C02205C00410001
    VCID: 4FAAA87E1E466C3920-801A
    Address 44: Steering Assist (J500) Labels: 8K0-909-144.clb
    Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
    Component: RCEPS H36 0507
    Revision: 00001000 Serial number: 0019593206
    Coding: 100001000001
    Shop #: WSC 06334 000 00000
    ASAM Dataset: EV_RCPESAU48X 008014
    ROD: N/A
    VCID: 3460C7929FA02FE13D-8060
    No ASAM data for: "EV_RCPESAU48X" (AU48)
    1 Fault Found:
    2305 - ROD - Unknown Error Code
    - 00 [008]
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 186
    Mileage: 127609 km
    Date: 2017.12.20
    Time: 18:42:02
    Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
    Revision: 00002001 Serial number: 0300027857
    Coding: 0100062020B900C08120023680000000
    2 Faults Found:
    02616 - Fuel Tank Cap; Unlock
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 2
    Fault Frequency: 29
    Reset counter: 127
    Mileage: 122563 km
    Time Indication: 0
    Date: 2017.02.10
    Time: 17:52:09
    02615 - Fuel Tank Cap; Lock
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 29
    Reset counter: 127
    Mileage: 122563 km
    Time Indication: 0
    Date: 2017.02.10
    Time: 17:52:09
    Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
    Part No SW: 8K0 959 792 R HW: 8K0 959 792 P
    Component: TSG BF H02 0506
    Revision: Serial number: 0000047161548
    Coding: 011C02205E00410001
    VCID: 4E94B57A194C65312B-801A
    Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
    Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
    Component: EPB-4 H01 0003
    Revision: -------- Serial number: 20000000205987
    ASAM Dataset: EV_ParkiBrake 001027
    ROD: EV_ParkiBrake_VW51.rod
    VCID: 3878F3A283C8CB8111-806C
    Address 56: Radio (R) Labels: Redir Fail!
    Part No SW: 4G1 035 053 J HW: 4G1 035 053
    Component: Radio U Basic H41 0133
    Revision: AB001007 Serial number: 227L20C7675270
    Coding: 010003020100000001
    VCID: 26442DDA517C4D71B3-8072
    Address 5C: Lane Maintain. Labels: None
    Part No SW: 8T0 907 217 A HW: 4E0 907 217 C
    Component: J759 HC 0040
    Revision: 00H08006 Serial number: 600212C0500337
    Coding: 0002001
    VCID: 377AF09E46D6C4F918-8062
    Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
    Part No SW: 8R1 035 666 L HW: 8R1 035 666 C
    Component: H-BN-EU H45 1036
    Revision: -------- Serial number: 205L20C7562378
    Coding: 0F0100010006A9ED2980CB5E00000403E40100020000000000
    VCID: 418E9E46D8128A49A6-8014
    Subsystem 1 - Part No: 8R0 060 884 EM
    Component: EUR 2017/2018 2503
    Subsystem 2 - Part No SW: 8R0 919 604 HW: 8R0 919 604
    Component: DU7 High H41 0104
    Serial number: A130LV0C2608542
    Subsystem 3 - Part No SW: 8T0 919 611 K HW: 8T0 919 611 B
    Component: E0380 Bedient H02 0030
    Serial number: 00000001365652
    Subsystem 4 - Part No: 8R0 060 961 E
    Component: CD-Database 4949
    2 Faults Found:
    03276 - Please Check Software Version Management
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 135
    Mileage: 126258 km
    Time Indication: 0
    Date: 2017.11.18
    Time: 16:36:24
    Freeze Frame:
    Text: DUA130,Front,M,0,0,6
    03623 - Invalid Secruity/Release Code
    000 - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 135
    Mileage: 126258 km
    Time Indication: 0
    Date: 2017.11.18
    Time: 16:36:24
    Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
    Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
    Component: TSG HL H01 0506
    Revision: Serial number: 0000047253866
    Coding: 010C02204000210001
    VCID: 46848D5AF13CAD7193-8012
    Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
    Component: TSG HR H01 0506
    Revision: Serial number: 0000047253912
    End-------------------------(Elapsed Time: 03:53)--------------------------
    File Allegati File Allegati
    gli errori nella scansione hanno tutti una data piuttosto vecchia. E sono tutti problemi di poco conto.
    molto probabilmente sono gia' stati risolti, ma non e' stata cancellata la memoria guasti.
    cancellali tu, col vag, clicca il comando "clear all dtc", poi rifai una nuova scansione. E vedi cosa esce.
    credo che molti errori spariranno, cioe' non si presentano piu' nella nuova scansione (es. sparisce di sicuro l'errore x le gomme sgonfie, nella centralina abs, con data giugno 2017, e credo che anche gli errori dell'optical databus, nella 19-gateway, e altri errori di comunicazione nella 16-steering wheel spariranno: probabilmente sono errori nati perche' hai distaccato qualche connettore elettrico per montare accessori o fare lavori a bordo).
    Altr ierrori rimarranno anche dopo la cancellazione, e su quelli bisogna indagare e risolvere.
    per capire il significato di ogni errore, vai a vedere il sito ross-tech (segnati il link, che ti verra' sicuramente utile in futuro).
    http://wiki.ross-tech.com/wiki/index...ry:Fault_Codes
    cerca con calma i tuoi codici errore nella lista del sito (i codici li trovi nella tua scansione, all'inizio di ogni riga, dove viene descritto l'errore).
    nelle pagine ross-tech troverai una descrizione estesa del guasto, le possibili cause, possibili soluzioni, ecc.. Quando ai un po' di dati e informazioni, ci ragioni con calma.
    ad esempio, nella centalina 5f, quell'errore mi fa pensare a un aggiornamento delle mappe navi per vie "non ufficiali" (il tuo dvd delle mappe e' una copia pirata??), quindi quell'errore non sparira' (ma non provoca nessun problema).
    il fuel tank cap lock vuol dire lo sportello del carburante: probabilmente hai il motorino della chiusura centralizzata (per lo sportellino) guasto. magari risolvi solo pulendo per bene e lubrificando. anche quell'errore ritornera' quasi di sicuro, nella nuova scansione, fino a quando non cambi il pezzo rotto.
    Ultima modifica di gian8p; 05-01-2018 alle 13:21
    Aug 2014
    Ferrara (FE)
    Ti ringrazio per le risposte esaurienti...
