Risultati da 1 a 10 di 10
Discussione: La vaggata di Nico
    Apr 2015
    Audi A6 Avant 3.0 TDI Quattro tip.
    Predefinito La vaggata di Nico
    Ciao a tutti,
    finalmente dotato di cavo ho potuto resettare la centralina 55 e i bixeno hanno ricominciato a funzionare.
    Dalla mia prima vaggata però ho trovato un sacco di errori...
    Ve la posto, qualcuno sa dirmi se devo intervenire?
    grazie mille
    Mileage: 165850km-103054mi Repair Order:
    Chassis Type: 4F (4L0)
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 55
    56 61 62 6C 72 76 77
    VIN: WAUZZZ4F48N179073 Mileage: 165850km-103054miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    07-Control Head -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    0E-Media Player 1 -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    37-Navigation -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: Malfunction 0010
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    62-Door, Rear Left -- Status: Malfunction 0010
    6C-Back-up Cam. -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    VCDS
    Self-Diagnosis Log
    Saturday,27,January,2018,13:12:01:39744
    Page 2
    VIN: WAUZZZ4F48N179073 License Plate:
    Address 01: Engine Labels: 059-907-401-ASB.clb
    Part No SW: 4F9 910 401 B HW: 4F0 907 401 C
    Component: 3.0L V6TDI G000AG 0030
    Revision: --H05--- Serial number:
    Coding: 0011372
    Shop #: WSC 00011 888 81093
    VCID: 244037D2E740BF61AD-8070
    2 Faults Found:
    005658 - Glowplug for Cylinder 1 (Q10)
    P161A - 001 - Open Circuit
    Freeze Frame:
    Fault Status: 01100001
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 165602 km
    Time Indication: 0
    Date: 2018.01.20
    Time: 10:41:47
    Freeze Frame:
    RPM: 924 /min
    Torque: 156.0 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 13.76 V
    Duty Cycle: 23.3 %
    Temperature: 5.4°C
    005662 - Glowplug for Cylinder 5 (Q15)
    P161E - 001 - Open Circuit
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 165602 km
    Time Indication: 0
    Date: 2018.01.20
    Time: 10:41:47
    Readiness: 0 0 0 0 0
    VCDS
    Self-Diagnosis Log
    Page 3
    Address 02: Auto Trans Labels: 09L-927-760.lbl
    Part No SW: 4F2 910 156 T HW: 09L 927 156 C
    Component: AG6 09L 3,0 TDI RdW 0020
    Revision: --H04--- Serial number: 4477177
    Coding: 0000001
    Shop #: WSC 02325 785 00200
    VCID: 3664FD9A41DC3DF103-8062
    No fault code found.
    Address 03: ABS Brakes Labels: 4F0-910-517.lbl
    Part No SW: 4F0 910 517 AD HW: 4F0 614 517 AA
    Component: ESP8 quattro H01 0070
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0020876
    VCID: 66C46DDA51FC8D7173-8032
    Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
    Part No SW: 4F0 910 852 B HW: 4F0 905 852 D
    Component: FBSAUDIC6 ELV H05 0100
    Revision: 00H05000 Serial number: 10602601162234
    Coding: 0000135
    Shop #: WSC 02324 785 00200
    VCID: 25462AD6EC7A4669BA-8070
    Subsystem 1 - Part No: 4F0 910 132 G
    Component: FBSAUDIC6 EZS H03 0020
    Subsystem 2 - Part No: 4F0 910 335 B
    Component: FBSAUDIC6 KSG H02 0020
    Subsystem 3 - Part No: 4F0 910 220 K
    Component: FBSAUDIC6 IDG H01 0040
    VCDS
    Self-Diagnosis Log
    Page 4
    Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
    Part No SW: 4F1 910 732 E HW: 4E0 035 729 A
    Component: Interfacebox H43 5570
    Revision: 00000000 Serial number: 351HU087568133
    Coding: 0031005
    Shop #: WSC 00000 000 08192
    VCID: 26442DDA917C4D71B3-8072
    Subsystem 1 - Part No: 4F0 910 609 E
    Component: Bedienteil MMIC6H01 0060
    Subsystem 2 - Serial number: 00000001154389
    Subsystem 3 - Serial number: 0121.08.080000000100010814˙
    Subsystem 4 - Serial number: 010814˙
    Address 08: Auto HVAC Labels: 4F0-910-043.clb
    Part No SW: 4F0 910 043 A HW: 4F1 820 043 AF
    Component: KLIMABETAETIGUNGH30 0020
    Revision: 00000053 Serial number: 00000030374667
    Coding: 0000278
    VCID: 1C300F32DF3087A115-8048
    VCDS
    Self-Diagnosis Log
    Page 5
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 N HW: 4F0 907 279
    Component: ILM Fahrer H21 0310
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0012121
    Shop #: WSC 02335 785 00200
    VCID: 3460C79257A02FE13D-8060
    Subsystem 1 - Part No: 4F1 910 113 C Labels: 1KX-955-119.CLB
    Component: Wischer AudiC6 H06 0210
    Coding: 00064784
    Shop #: WSC 02335
    Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH04 0003
    Coding: 00146221
    Shop #: WSC 02335
    2 Faults Found:
    02745 - Bulb for Daytime Running Light; Left
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 149
    Mileage: 165816 km
    Time Indication: 0
    Date: 2018.01.26
    Time: 08:16:00
    02746 - Bulb for Daytime Running Light; Right
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 149
    Mileage: 165816 km
    Time Indication: 0
    Date: 2018.01.26
    Time: 08:16:00
    VCDS
    Self-Diagnosis Log
    Page 6
    Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
    Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
    Component: MP3-Changer H47 0390
    Revision: 00047003 Serial number: AUZ5ZBH8551627
    Shop #: WSC 00000 000 00000
    VCID: 1A3C092AD504F99107-804E
    Address 15: Airbags Labels: 4F0-910-655-8R.clb
    Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
    Component: 42 AIRBAG AUDI8RH30 0280
    Revision: 09H30000 Serial number: 0037LD0ZCMG0
    Coding: 0013362
    VCID: 295E26E6806262099E-807C
    Subsystem 1 - Serial number: 6332CSME3F552C418
    Subsystem 2 - Serial number: 6342CSME3F555268B
    Subsystem 3 - Serial number: 6352QSME67031D3EO
    Subsystem 4 - Serial number: 6362QSME62030204
    Subsystem 5 - Serial number: 63734SME7E0C3A77I
    Subsystem 6 - Serial number: 63834SME6E6C3C1BO
    Address 16: Steering wheel Labels: 4F0-910-549.lbl
    Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
    Component: J0527 0410
    Revision: 00H03000 Serial number: 90025082190266
    Coding: 0002142
    VCID: 275A20DE9676547988-8072
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: E0221 H02 0030
    VCDS
    Self-Diagnosis Log
    Page 7
    Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
    Part No SW: 4F0 910 930 C HW: 4F0 920 933 J
    Component: KOMBIINSTR. M73 H23 0240
    Revision: 00000000 Serial number: 72U39LJ78
    Coding: 3073558
    Shop #: WSC 00001 001 00001
    VCID: 234234CEE24EB859D4-8076
    Address 19: CAN Gateway Labels: 4L0-910-468.clb
    Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
    Component: J533__Gateway H06 0060
    Revision: 00H06000 Serial number: 1100B08815824C
    Coding: F551DE7730320600
    Shop #: WSC 02145 785 00200
    VCID: 2D56D2F6B48A7E2972-8078
    1 Fault Found:
    00470 - Company Comfort Databus in Single Wire
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 112
    Mileage: 165851 km
    Time Indication: 0
    Date: 2018.01.27
    Time: 12:59:42
    Address 37: Navigation Labels: 4E0-910-88x-37.lbl
    Part No SW: 4E0 910 888 P HW: 4E0 919 887 M
    Component: MNS ECE H52 1060
    Revision: 00000000 Serial number: 364HS087810137
    Shop #: WSC 00898 264 66716
    VCID: 3B72ECAE7AFEE099FC-806E
    VCDS
    Self-Diagnosis Log
    Page 8
    Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
    Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
    Component: TSG FA H12 0210
    Coding: 0018026
    Shop #: WSC 02327 785 00200
    VCID: 2C50DFF28F90772165-8078
    Address 46: Central Conv. Labels: 4F0-910-289.lbl
    Part No SW: 4F0 910 289 J HW: 4F0 907 289 J
    Component: Komfortgeraet H27 0220
    Revision: 02200027 Serial number: 01131769560000
    Coding: 0140017
    VCID: 316ECE86A8B21AC956-8064
    Subsystem 1 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Subsystem 2 - Part No: 4F0 910 177
    Component: Innenraumueberw.H01 0020
    1 Fault Found:
    01699 - Motor for Central Locking; Hatch/Trunk (V53)
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 111
    Mileage: 0 km
    Time Indication: 0
    Address 47: Sound System (J525) Labels: Redir Fail!
    Part No SW: 4F0 910 223 M HW: 4F0 035 223 N
    Component: Amp.-ASK-RD H07 0270
    Revision: S1400000
    Coding: 020001
    Shop #: WSC 02399 823 56573
    VCID: 285823E25B685B0181-807C
    VCDS
    Self-Diagnosis Log
    Page 9
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280 A
    Component: ILM Beifahrer H12 0100
    Revision: Serial number: 00000000576645
    Coding: 0001103
    VCID: 5EB4453A89ACD5B1BB-800A
    Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
    Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
    Component: TSG BF H12 0210
    Coding: 0018026
    Address 53: Parking Brake Labels: 4F0-910-801.clb
    Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
    Component: EPB CDEC0080 H04 0080
    Revision: --H04---
    Coding: 0000321
    VCID: 20483BC2F358A341C9-8074
    1 Fault Found:
    02440 - Function Display in Instrument Cluster (P)
    009 - Open or Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00101001
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 141
    Mileage: 165600 km
    Time Indication: 0
    Date: 2018.01.19
    Time: 18:43:00
    Freeze Frame:
    Voltage: 10.77 V
    Count: 62
    VCDS
    Self-Diagnosis Log
    Page 10
    Address 55: Headlight Range Labels: 8P0-907-357.lbl
    Part No: 8P0 907 357 H
    Component: Dynamische LWR H02 0010
    Revision: 00000001 Serial number:
    Coding: 0000003
    VCID: 3F8A98BE6EE6FCB9D0-806A
    Address 56: Radio Labels: 4E0-910-541.lbl
    Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
    Component: TUNER EU/US/RDW H42 0620
    Revision: 00000000 Serial number: 394H1087925359
    Coding: 0000001
    VCID: 2E54D5FAB98C05314B-807A
    Address 61: Battery Regul. Labels: 4F0-910-181.lbl
    Part No SW: 4F0 910 181 F HW: 4F0 915 181 B
    Component: J0644 BEM H12 0760
    Revision: 00000000 Serial number: 00000000134372
    Subsystem 1 - Part No: 4F0 915 105 D
    Component: von VA0 2808251496
    Coding: 344630393135313035442056413032383038323531343936
    Shop #: WSC 00000 512 00290
    VCDS
    Self-Diagnosis Log
    Page 11
    Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
    Component: TSG HL H21 0210
    Coding: 0017450
    1 Fault Found:
    02115 - Locking Unit for Central Locking
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 3
    Fault Frequency: 5
    Reset counter: 151
    Mileage: 165602 km
    Time Indication: 0
    Date: 2018.01.19
    Time: 18:40:14
    Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
    Part No SW: 4F0 910 441 A HW: 4L0 907 441 A
    Component: J772__Rearview 0050
    Revision: --H12--- Serial number: 525PA8-J8730J9
    Coding: 1020205
    VCID: 1E34053AC92C95B1FB-804A
    Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
    Component: TSG HR H21 0210
    Coding: 0017450
    VCDS
    Self-Diagnosis Log
    Page 12
    Address 76: Park Assist Labels: 4Fx-910-283.lbl
    Part No SW: 4F0 910 283 H HW: 4F0 919 283 H
    Component: Parkhilfe 8-Kan H12 0080
    Revision: 00H12000 Serial number: 06340820405210
    Coding: 0221116
    Shop #: WSC 131071 1023 2097151
    Address 77: Telephone Labels: 4F1-910-336.lbl
    Part No SW: 4F1 910 336 C HW: 4F1 862 335
    Component: BTA H11 0960
    Revision: 00H11000 Serial number: 00000007588877
    Coding: 0050041
    End-------------------------(Elapsed Time: 02:33)--------------------------
    Amministratore & Socio L'avatar di Maggie180
    Sep 2014
    Thanked: 272
    Aosta (AO)
    Audi A3 1.9tdi
    Ciao Nico!
    Prima vaggata in assoluto?
    Perché se così fosse, ti consiglierei di resettare tutti gli errori e di vaggare nuovamente.
    http://www.audirsclub.it/iscrizioni
    http://forum.audirsclub.it/showthrea...Y-4-marzo-2018!
  4. Il seguente utente ringrazia Maggie180 per questo messaggio
    Nico 3.0TDI Quattro (27-01-2018)
  5. #3
    Thanked: 764
    nella scasnione vedo errori riferiti alla candelette di preriscaldo, poi 2 errori alla chiusura centralizzata (bagagliaio e portiera posteriroe sinistra), poi vedo errori ai led diurni, ecc.
    tutti erorri con frequency = 1, cioe si sono manifestati 1 unica volta.
    potrebbero tutti essere errori fittizi, causati da lavori di smontaggio in abitacolo o nel vano motore: magari hai scollegato alcune spinette elettriche ecc. (poi hai girato la chiave nel quadro con alcuni connettori elettrici staccati, ed ecco che scatta l'errore in diagnosi).
    hai fatto qualche retrofit dentro la tua macchina, in quest'ultima settimana? hai smontato o montato qualche nuovo accessorio?
    (tutti gli errori riportano date molto ravvicinate, ecco perche ho pensato a errori fittizi, semplici spinette scollegate ecc).
    ovviamente poi hai ri-montato tutto, e ri-collegato le spine elettriche, quindi adesso tutti gli accessori funzionano correttamente.
    ma gli errori nella diagnosi non se ne vanno, fino a quando non vengono cancellati col comando vag "clear all dtc".
    segui il consiglio di maggie, fai un bel clear, e domani rifai la scansione.
    e' molto probabile che alcuni errori spariranno, non compaiono piu.
    e altri invece ritorneranno subito (ad esempio, le candelette bruciate. quelle e' difficile che le hai "toccate", durante i tuoi retrofit... ).
  6. Il seguente utente ringrazia gian8p per questo messaggio
  7. #4
    Apr 2015
    No nessun lavoro, gli errori anche se li cancello ricompaiono tutti alla scansione successiva... Non capisco però i vari significati se non che il canbus ha uno dei due cavi a massa (chissà dove ) e le candelette che hanno? Morte? Non collegate? Uffa
    Inviato dal mio WAS-LX1A utilizzando Tapatalk
  8. #5
    Thanked: 764
    Citazione Originariamente Scritto da Nico 3.0TDI Quattro Visualizza Messaggio
    2 Faults Found:
    2 Faults Found:
    1 Fault Found:
    1 Fault Found:
    1 Fault Found:
    1 Fault Found:
    azz.... se gli errori ritornano subito, anche se li cancelli, vuol dire che sono problemi aperti, guasti reali, da risolvere.
    ti scrivo le mie impressioni, a naso. Ragionaci con calma (non sono meccanico e potrei dire cose imprecise o sbagliate):
    le candelette di solito sono bruciate (open circuit= circuito interrotto). Tranquillo, le candelette costano poco, 25 euro circa cadauna. (ne ho cambiate un paio anche sul mio motore).
    le luci diurne "DRL" anteriori forse sono bruciate. Mi pare che la A6 ha dei led, una fila orizzontale, nel bordo inferiore del faro. Magari si e' fulminata la centralina che li alimenta (tu hai i led? hai notato se non si accendono?).
    questo guasto e' sicuramente piu rognoso da riparare, magari ti tocca cambiare in blocco led e alimentatore, potrebbe essere un "corpo unico", un guscio di plastica saldato, che non si apre. boh. non lo so che tipo di ricambio e' fornito da mamma Audi per le DRL della A6.
    le serrature bagagliaio e porta posteriore sinistra forse sono rotte. in alcune serie di Audi e' un difetto frequente: nel tempo, gli ingranaggi di plastica si "mangiano" e la serratura non scatta piu a dovere (succede di solito nelle A4. non so se la stessa serratura viene montata anche sulla tua A6).
    verifica se quelle serrature si chiudono con il telecomando, perche' c'e il rischio di lasciare aperta la macchina, al parcheggio del supermercato, o la notte in strada, o allo stadio... (e rischi che ci trovi dentro un intruso, quando torni a prendere l'auto...).
    il cavo canbus e il display del quadro strumenti a loro volta hanno qualche problema "short to ground", quindi si puo' pensare a un cavo a massa (forse un fascio di cavi si e' spellato per attrito in qualche punto della carrozzeria, ma chissa' dove).
    purtroppo io non ho esperienza per capirne di piu.
    vai a cercare i codici errore (presenti nella tua scansione e che ti ho messo in evidenza in neretto, per comodita'), nel sito ross-tech.com, sezione wiki, poi fault codes.
    oppure cerca con google "02115 vag error", poi "02440 vag error" e cosi via con tutti gli altri codice di errore (uno alla volta, con calma).
    vedi cosa esce.
    di logica qualche altro utente in giro per il mondo avra' gia' avuto gli stessi tuoi problemi, in qualche forum inglese o tedesco magari trovi qualche dritta.
    io consulto spesso il sito ross-tech, mi trovo bene. Di solito ci sono delle pagine molto chiare e precise, per ogni codice di errore, con le possiibili cause e le possibili soluzioni. purtroppo il sito ross tech e' in inglese, non so come sei messo tu con l'inglese.(c'e sempre il traduttore online, anche se spesso vengono fuori frasi senza senso).
    ross-tech e' la ditta che ha ha creato il software "vag", i loro consigli sono sicuramente affidabili.
  9. Il seguente utente ringrazia gian8p per questo messaggio
  10. #6
    Apr 2015
    I led drl non sono ricomparsi e non hanno problemi. La portiera e il baule ho appena controllato e si chiudono e aprono perfettamente boh! Le candelette sono semplici da cambiare? Ho molta manualità e potrei farlo io.. Il quadro strumenti non ha nessun problema... Mistero
  11. #7
    Thanked: 764
    boh. sara' il tuo vag che fa le bizze e non cancella gli errori.
    succede, i vag comprati per pochi euri in rete, sono tutti cloni cinesi (copie pirata) e ogni tanto qualcuno si "pianta" (una copia venuta male, incompleta, ecc).
    se trovi un amico del forum che vive a milano (sicuramente ci sono decine di utenti), che ha un altro vag, si puo' provare a fare la scansione (e cancellare gli errori), col suo vag. giusto per capire se la colpa e' del tuo cavo. (bisogna provare tutte le ipotesi).
    come gia ' ho detto nel mess indietro, e' veramente strano che tutti gli errori in memoria hanno frequency = 1 (quindi si sono verificati una sola volta). questo fa pensare a errori fittizi, come avevo spiegato, ma allora devono andare via se li cancelli!!
    una curiosita': per quale motivo si erano bloccati i bi-xeno? (e hai dovuto resettare col vag).
    e i led diurni hanno sempre funzionato regolarmente? (hai scritto "I led drl non sono ricomparsi e non hanno problemi". la parte sottolineata mi manda un po' in confusione... cosa vuol dire?).
    cerchiamo di ricostruire i guasti della tua macchina, perche' adesso ci hai dato veramente pochi elementi su cui ragionare (e molto confusi).
  12. Il seguente utente ringrazia gian8p per questo messaggio
    Nico 3.0TDI Quattro (28-01-2018)
  13. #8
    Dec 2012
    Thanked: 111
    Se le candelette ti da OPEN CIRCUIT ,l"errore che viene fuori se cancella subito, dopo che metti in moto di nuovo l"errore viene di nuovo. Secondo me e il cavo vag che ti fa scherzi.
  14. Il seguente utente ringrazia auras80 per questo messaggio
  15. #9
    Apr 2015
    Gli errori li cancella, ma siccome sono presenti si ripresentano. i bixeno erano bloccati perche li avevo staccati in seguito ad un impatto (mi si è agganciato il paraurti ad un marciapiede molto alto e ha strappato paraurti e rotto altre parti)
    Il fatto del frequency = 1 in effetti non mi torna perchè se lo cancello e poi ritorna dovrebbe essere =2 o cmq uguale al numero dei reset+1
    boh
  16.
  17. #10
    Thanked: 764
    ahhhhh, allora qualche lavoro a bordo e ' stato fatto... (ma nel mess #4 tu dicevi di no...).
    adesso si riesce a capire un po' meglio molte cose...
    molto probabilmente i tuoi led DRL hanno subito qualche danno (al pari degli xenon) con l'urto al marciapiedi.
    ed ecco apparire l'errore in diagnosi, per entrambi i fari drl...
    Ma questi benedetti led DRL, sono accesi oppure no? funzionano o no? sinceramente non l'ho ancora capito.
    Tornando agli errori inella tua scansione, secondo me devi verificare i cablaggi, ecc, nella zona dei fari.
    la mia ipotesi del mess #5, cioe' che un cavo si sia spellato/pizzicato (e quindi adesso va a massa sul telaio, e quindi appare l'errore "short to ground" in diagnosi...), direi che prende piu consistenza e credibilita'.
    Tu dici che l'urto ha rotto vari pezzi, quindi ci sta che anche il cablaggio (che si sviluppa nel muso, per alimentare fari, per alimentare il sensore temperatura esterna= e tu hai un errore "databus" nel quadro strumenti..., per alimentare ventole radiatore, ecc ecc), puo' avere subito danni.
    magari c'e una spinetta elettrica schiacciata, un po' nascosta, e quindi non e' stata sostituita al momento delle riparazioni.
    O magari e' stato semplicemente il carrozziere: nello smontare/rimontare il paraurti o altri ricambi, ha dato uno strattone (es. per sganciare un pezzo di plastica deformato, che altrimenti non si smontava), e ha involontariamente pizzicato i cavi (senza nemmeno accorgersi. La sfiga ci vede benissimo, lo sappiamo...).
    io dico di controllare il muso, smontare quanti piu' pezzi e' possibile, e verificare con cura i cablaggi dei fari e degli altri componenti montati nel muso (considera che xeno e DRL led hanno cablaggi e centraline di alimentazione separati).
    Altro non mi viene in mente.
  18. Il seguente utente ringrazia gian8p per questo messaggio
