Risultati da 1 a 6 di 6
Discussione: Spia candelette e avaria motore
    New Entry L'avatar di Giorgio160586
    Dec 2014
    Reggio Emilia (RE)
    AUDI A5 coupè
    Predefinito Spia candelette e avaria motore
    Buongiorno a tutti, mentre viaggiavo in autostrada si è accesa la spia candelette e avaria motore, spegnendo la macchina le spie si sono spente vorrei però capire cosa è successo, qualcuno riesce ad aiutarmi?
    grazie in anticipo
    VCDS Version: 17.8.0.1
    Mileage: 158620km-98561mi
    Chassis Type: 8T-AU48 (8R0)
    Scan: 01 02 03 05 08 09 15 16 17 19 42 44 46 52 53 56 5F
    Mileage: 158620km-98561miles
    01-Engine -- Status: Malfunction 0010
    17-Instruments -- Status: Malfunction 0010
    Address 01: Engine (J623-CGLC) Labels:. 03L-906-018-CGL.clb
    Part No SW: 03L 906 018 JJ HW: 03L 906 018 JL
    Component: R4 2.0l TDI H25 9978
    Revision: 45H25---
    Coding: 0A034012232401080000
    Shop #: WSC 20481 002 1048576
    ASAM Dataset: EV_CEM20TDI01103L906018JJ 003010
    ROD: N/A
    VCID: 7BF4CF70F2E5619EDF-802E
    No ASAM data for: "EV_CEM20TDI01103L906018JJ" (AU48)
    2 Faults Found:
    4891 - ROD - Unknown Error Code
    - 00 [104]
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 6
    Mileage: 158212 km
    Date: 2018.06.08
    Time: 17:30:41
    4892 - ROD - Unknown Error Code
    - 00 [096]
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Mileage: 158255 km
    Date: 2018.06.08
    Time: 19:16:19
    Readiness: 0 1 0 0 0
    Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
    Part No SW: 8T0 920 930 D HW: 8T0 920 930 D
    Component: KOMBIINSTR. H35 0540
    Revision: 00000000 Serial number: NSU31PZ1D
    Coding: 0307000002010008040000
    Shop #: WSC 06325 123 12345
    VCID: 377C1340864D85FE7B-8062
    1 Fault Found:
    00003 - Control Module
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 232
    Mileage: 157903 km
    Time Indication: 0
    Date: 2018.06.05
    Time: 12:02:23
    End-------------------------(Elapsed Time: 03:00)--------------------------
    Ultima modifica di Giorgio160586; 11-06-2018 alle 12:05
    dovrai probabilmente pulire o sostituire la egr
    Aug 2015
    Thanked: 6
    Audi A5 Sline
    A me è successo questo inverno, alla fine ho risolto sostituendo 2 bulbi.
    Ciao
    Consigliere Direttivo
    Mar 2009
    Thanked: 43
    Novara (NO)
    Audi A5 2000 tdi
    È successo anche a me andando al Raduno Audi di Roma a circa metà strada sotto la pioggia e in coda rientro gli autocarri; dopo averla fatta spegnere al ritorno si è riaccesa e ho rimediato smontando e pulendo il sensore ossigeno. Se non dovesse funzionare il pezzo a seconda del modello varia tra le 150 e i 200 euro
    Dec 2014
    Reggio Emilia (RE)
    AUDI A5 coupè
    Ciao, ho portato la macchina in una officina autorizzata Audi, mi hanno sostituito il radiatore gas scarico A010 03L 131 512 DT.
    Dopo intervento ho fatto 1200km circa e il problema non si è più ripresentato.
    si lo scambiatore sotto la egr che raffredda i gas di scarico prima di rimetterli camera di scoppio.
