gian8p
io ho qusto schema per la centralina 09 (che alimenta la plafoniera e il coming home).
fai qualche prova col tester, fino a trovare i pin "giusti" per collegare le tue luci di cortesia specchi. in toeira potrebbe essere il pin 11 sul connettore B.
(dovrai tradurre con google dall'inglese le parole che non capisci, lo schema e' in inglese).
MORSETTIERA centralina 09 – Centr. Elect. - Bordnetz (su Audi A3 8P fino 2009 e TT 8J).
Pin assignment, onboard power supply control unit - J519
Connector A (11-pin)
Pin 1: Terminal 30 right
Pin 2: Dipped beam right
Pin 3: Main beam right
Pin 4: Fog light right
Pin 5: Vacant
Pin 6: Flasher front right
Pin 7: Side light front left
Pin 8: Flasher side left
Pin 9: Terminal 31 left
Pin 10: Electric fuel pump relay
Pin 11: Terminal 50 relay
Connector B (12-pin)
Pin 1: Reversing light right
Pin 2: Vacant
Pin 3: Light sensor supply
Pin 4: Fog tail light, left
Pin 5: Brake light right
Pin 6: Vacant
Pin 7: Footwell light luce vano piedi
Pin 8: Vacant
Pin 9: Side light rear right
Pin 10: Rear right turn signal
Pin 11: Interior lighting = plafoniera interna
Pin 12: Terminal 58s
Connector C (12-pin)
Pin 1: Seat heating shut-off
Pin 2: Brake light left
Pin 3: Vacant
Pin 4: Coming Home LED (cioè la spia dentro il tastino)
Pin 5: Vacant
Pin 6: Vacant
Pin 7: Vacant
Pin 8: Number plate light
Pin 9: Brake light centre
Pin 10: Side light rear left
Pin 11: Rear left turn signal
Pin 12: Vacant
Connector D (11-pin)
Pin 1: Terminal 30 left
Pin 2: Fog light left
Pin 3: Main beam left
Pin 4: Dipped beam left
Pin 5: Terminal 31 right
Pin 6: Vacant
Pin 7: Terminal 15 engine relay
Pin 8: Headlight washer relay
Pin 9: Flasher side right
Pin 10: Side light front right
Pin 11: Flasher front left
Connector E (16-pin)
Pin 1: Side lights switch
Pin 2: Brake light switch
Pin 3: Vacant
Pin 4: Vacant
Pin 5: Garage door opener input
Pin 6: Fog tail light switch
Pin 7: P/N without interlock switch
Pin 8: Dipped beam switch
Pin 9: Vacant
Pin 10: Vacant
Pin 11: Light sensor input input sens. luce
Pin 12: Coming Home potentiometer tap filo a massa
Pin 13: Fog tail light switch
Pin 14: Assistance driving lights switch
Pin 15: EC mirror non-dipping
Pin 16: Light switch 0 setting
Connector F (8-pin)
Pin 1: Terminal 50 diagnosis
Pin 2: Terminal 15 engine diagnosis
Pin 3: LIN bus
Pin 4: Terminal L-alternator
Pin 5: Bonnet contact
Pin 6: Reversing light switch
Pin 7: Terminal 30 reference
Pin 8: Terminal 31 reference
Connector G (12-pin)
Pin 1: Terminal 50 switch
Pin 2: Hazard warning lights LED
Pin 3: Rear window defroster
Pin 4: Terminal 58s potentiometer ground
Pin 5: Vacant
Pin 6: Rear window heater button
Pin 7: Convenience CAN Low
Pin 8: Convenience CAN High
Pin 9: Hazard warning lights button
Pin 10: Terminal 58s potentiometer supply
Pin 11: Terminal 15 switch
Pin 12: Terminal 58s potentiometer tap
