Buonasera a tutti,
poco fa ho effettuato quella che in assoluto e' la mia prima vaggata, fatta principalmente per capire per quale motivo lo specchietto di sinistra non si sbrini e perché entrambi non si chiudono, e vorrei un vostro aiuto per analizzare il log che ne e' uscito per capire se e' il caso di verificare anche altre segnalazioni:
Codice:
Sunday,05,May,2019,18:35:58:00007
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86(VirtualBox)
VCDS Version 18.9.0.2
Data version: 20180927 DS296.0
www.Ross-Tech.com
VIN: WAUZZZ License Plate:
Mileage: 165797km-103021mi Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 3B 42 44 46 52 53 55 5F 62
72 85 8E 8F 90
VIN: WAUZZZ Mileage: 165797km-103021miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
3B-Sensor Elect. -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
85-On Board Cam. -- Status: OK 0000
8E-Image Processing -- Status: OK 0000
8F-Pretens. Frt Left -- Status: Cannot be reached 0100
90-Pretens. Frt Right -- Status: Cannot be reached 0100
Address 01: Engine (J623-CGLC) Labels:. 03L-906-018-CGL.clb
Part No SW: 03L 906 018 LB HW: 03L 906 018 JL
Component: R4 2.0l TDI H25 9978
Revision: 45H25---
Coding: 12034012232401080000
Shop #: WSC 47328 002 1048576
ASAM Dataset: EV_ECM20TDI01103L906018LB 003012
ROD: EV_ECM20TDI01103L906018HA.rod
VCID: 75E157D5D4C131E2F6-8021
1 Fault Found:
5523 - Engine Start Blocked by Immobilizer
P1570 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J217) Labels:| 0AW-927-156.clb
Part No SW: 4G2 927 155 D HW: 0AW 927 156 K
Component: 0AW_20TDI_RdW H08 0002
Revision: --H08--- Serial number: 0000000153
Coding: 000001
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMVL381 A02433
ROD: EV_TCMVL381.rod
VCID: 2E53B8B97117423A77-807B
1 Fault Found:
2310 - Transmission Control Unit
P1701 00 [032] - Locked
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 H HW: 4G0 907 379 H
Component: ESP PREMIUM H09 0361
Revision: -------- Serial number: --------------
Coding: 06A187016085E180DB00
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremiAU57X 004028
ROD: EV_ESPPremiAU57X_004_AU57.rod
VCID: 366390D989477AFA3F-8063
No fault code found.
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 BN HW: 4H0 907 064 BN
Component: BCM2 2.0 H31 0333
Revision: 00002001
Coding: 01A93006000000000000
VCID: 76E350D9C1C73AFAFF-8023
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-2Z.clb
Part No SW: 4G0 820 043 G HW: 4G0 820 043 G
Component: KLIMA 2 ZONEN H10 0063
Serial number: 28111100041017
Coding: 34020008A4
ASAM Dataset: EV_AirCondiBasisUDS 002039
ROD: EV_AirCondiBasisUDS_002.rod
VCID: 2345598D2AD5FF52E8-8077
1 Fault Found:
0019 - Motor for Fresh Air / Recirculated Air Flap
B11AF 07 [008] - Mechanical Failure
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 209
Mileage: 165295 km
Date: 2019.04.18
Time: 18:09:38
Voltage terminal 30: 14.10 V
Outside air temperature: 21.5 ∞C
Interior temperature: 36.85 ∞C
Fresh air door motor-Act.val.: 11415
Fresh air door motor-Specified value: 9889
Fresh air door motor-Stop open: 11404
Fresh air door motor-Stop closed: 10000
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 BE HW: 4H0 907 063 E
Component: BCM1 2.0 H12 0100
Revision: 19012002 Serial number: 00000001142402
Coding: 2600201040349FE08181008000001D0CCF9CC70826090101000004602101
VCID: 6CD772B18F8BF02A19-8039
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 111026 H35 0051
Serial number: 111107140944
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 11800745
Coding: 02512B
Subsystem 3 - Part No SW: 4G0 941 531 E HW: 4G0 941 531 E
Component: E1 - LDS H07 0044
Serial number: 23 11 2011 00001195
Subsystem 4 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H02 0002
Serial number: CC384ED5000000000001
1 Fault Found:
03725 - Control Module for Seat Belt Tensioner; Left Front
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 241
Reset counter: 177
Mileage: 156884 km
Time Indication: 0
Date: 2018.10.27
Time: 17:19:00
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 L HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0043
Revision: 11001001 Serial number: 55901132800720
Coding: 082307
ASAM Dataset: EV_EPHVA18AU57X0000 002005
ROD: EV_EPHVA18AU57X0000_002_AU57.rod
VCID: 3B7581EDB265A792C0-806F
Address 15: Airbags (J234) Labels:* 4H0-959-655.clb
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H40 0040
Revision: -------- Serial number: 003JG005TDLK
Coding: 30323436313230303031554A304C34473053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_VW51.rod
Crash sensor for side airbag: driver side:
Serial number: 3575HRB405R0U2UQ2ODN
Crash sensor for side airbag: front passenger side:
Serial number: 3585HRB405R1082G614L
Crash sensor for side airbag: rear: driver side:
Serial number: 3515JRB40530TQMEBH5Z
Crash sensor for side airbag: rear: passenger side:
Serial number: 3525JRB405J0TGJMO1C8
Crash sensor for front airbag: driver side:
Serial number: 3554VRB405D0PF6Q91O%
Crash sensor for front airbag: front passenger side:
Serial number: 3564VRB405N0PF6QC8EA
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4H0 953 568 G HW: 4H0 953 568 G
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90372KKJ000EN
Coding: 0000F5
VCID: 377D9DDD864D83F224-8063
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Component: E221 - MFL H08 0009
Serial number: 24 10 2011 B0079280
Address 17: Instruments (J285) Labels:. 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 900 H HW: 4G8 920 900 H
Component: MDieRdw H34 0209
Revision: 25450207 Serial number: 658221111593042
Coding: 13A610000B110008040000
ASAM Dataset: EV_RBC7KMID 004045
ROD: EV_RBC7KMID.rod
VCID: 2F6DA5BD761D4B327C-807B
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4G0 907 468 G HW: 4G0 907 468 A
Component: J533--Gateway H08 0214
Revision: -------- Serial number: 00000000327228
Coding: 00CD074400
ASAM Dataset: EV_GatewUDS 001025
ROD: EV_GatewUDS_AU57.rod
VCID: 3467AAD19F3B68EA01-8061
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790284082
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Serial number: 11325000122011200181
2 Faults Found:
5080 - Front Left belt tensioner control module
U107C 00 [009] - No communication
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 254
Reset counter: 190
Mileage: 156358 km
Date: 2018.10.20
Time: 11:55:30
Voltage terminal 30: 11.5 V
Voltage terminal 15: 11.5 V
Control Module temperature: 24 ∞C
System status: Terminal 15 on
IN ESP_standstill flag: standstill detected
Engine running: OFF
IN ZAS_Te_X: On
Terminal 15 status via CAN: On
Terminal 15 status: On
Datenfeld: 0
5081 - Front Right belt tensioner control module
U107D 00 [009] - No communication
Freeze Frame:
Fault Priority: 2
Reset counter: 190
Mileage: 156358 km
Date: 2018.10.20
Time: 11:55:30
Engine running: OFF
IN ZAS_Te_X: On
Datenfeld: 0
Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
Part No SW: 4G0 907 637 B HW: 4G0 907 637 B
Component: SARA 6D H02 0004
Revision: -------- Serial number: EJ1BPA4202YCNS0
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA_006.rod
VCID: 2D51BFB57C1139224E-8079
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4G8 959 793 E HW: 4G8 959 793 A
Component: TSG FA H05 0212
Coding: 011F16205000628002080002
Shop #: WSC 02312 785 00200
VCID: 428BFC09DD8FD65A83-8017
8 Faults Found:
01482 - Motors for Central Locking
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 3
Fault Frequency: 97
Reset counter: 190
Mileage: 164073 km
Time Indication: 0
Date: 2019.03.31
Time: 16:45:14
02116 - Mirror Adjusting Motor
006 - Short to Plus
Freeze Frame:
Fault Status: 01100110
Fault Priority: 3
Fault Frequency: 213
Reset counter: 190
Mileage: 164073 km
Time Indication: 0
Date: 2019.03.31
Time: 16:45:14
02117 - Motor for Mirror Folding
006 - Short to Plus
Freeze Frame:
Fault Priority: 3
Reset counter: 190
Mileage: 159994 km
Time Indication: 0
Date: 2018.12.20
Time: 23:58:42
Freeze Frame:
Fault Priority: 3
Fault Frequency: 157
Reset counter: 190
Mileage: 159994 km
Time Indication: 0
Date: 2018.12.20
Time: 23:58:42
006 - Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 72
Reset counter: 190
Mileage: 159994 km
Time Indication: 0
Date: 2018.12.20
Time: 23:58:47
Freeze Frame:
Fault Priority: 3
Fault Frequency: 150
Reset counter: 190
Mileage: 159994 km
Time Indication: 0
Date: 2018.12.20
Time: 23:58:47
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 12
Reset counter: 185
Mileage: 152430 km
Time Indication: 0
Date: 2018.09.07
Time: 08:03:59
Freeze Frame:
Fault Priority: 6
Reset counter: 190
Mileage: 156358 km
Time Indication: 0
Date: 2018.10.20
Time: 11:55:36
Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H35 0010
Revision: 00001000 Serial number: 0003219156
Coding: 101001010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 326BACC9652F66DA13-8067
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0164257275
Coding: 0100062020B9048083200904080104000000000000000000000000000000
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Reset counter: 190
Mileage: 156358 km
Time Indication: 0
Date: 2018.10.20
Time: 11:55:33
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4G8 959 792 E HW: 4G8 959 792 A
Component: TSG BF H05 0212
VCID: 4189F305D889CD429A-8015
7 Faults Found:
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 3
Fault Frequency: 43
Reset counter: 223
Mileage: 164073 km
Time Indication: 0
Date: 2019.03.31
Time: 16:45:14
006 - Short to Plus
Freeze Frame:
Fault Priority: 3
Reset counter: 190
Mileage: 159994 km
Time Indication: 0
Date: 2018.12.20
Time: 23:58:42
006 - Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 140
Reset counter: 190
Mileage: 159994 km
Time Indication: 0
Date: 2018.12.20
Time: 23:58:47
Freeze Frame:
Fault Priority: 3
Fault Frequency: 147
Reset counter: 190
Mileage: 159994 km
Time Indication: 0
Date: 2018.12.20
Time: 23:58:47
Freeze Frame:
Fault Priority: 6
Reset counter: 190
Mileage: 156358 km
Time Indication: 0
Date: 2018.10.20
Time: 11:55:36
Freeze Frame:
Fault Priority: 3
Fault Frequency: 151
Reset counter: 190
Mileage: 159994 km
Time Indication: 0
Date: 2018.12.20
Time: 23:58:47
006 - Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 211
Reset counter: 190
Mileage: 164073 km
Time Indication: 0
Date: 2019.03.31
Time: 16:45:14
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000200276
ASAM Dataset: EV_ParkiBrake 001022
ROD: EV_ParkiBrake_VW51.rod
VCID: 2A5BB4A94DFF2E1AAB-807F
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 A HW: 4H0 907 357 A
Component: ....LWR12.... H02 0013
Serial number: 111125-0004-109
Coding: 112296101002A300
ASAM Dataset: EV_HeadlRegulBasic 005001
ROD: EV_HeadlRegulBasic.rod
VCID: 2C57B2B1470B302A59-8079
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 4G0 035 193 D HW: 4G0 035 193 D
Component: RMC Cnct Nav H52 0761
Coding: 0100010001C15B47412B060301010000000000
VCID: 24475A9127DBF86A91-8071
Subsystem 1 - Part No: 8X0 919 884 D
Component: P13-50-11.06 0002
Subsystem 2 - Part No SW: 4G0 919 603 HW: 4G0 919 603
Component: DU6 Basic H42 0084
Serial number: 9464J 0B0073198
Subsystem 3 - Part No SW: 4G1 919 610 B HW: 4G1 919 610 B
Component: E380 BDT C7 H11 0204
Serial number: 90349KKO000IL
1 Fault Found:
03157 - Functionality limited due to Communications Disruption
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Reset counter: 177
Mileage: 165487 km
Time Indication: 0
Date: 2019.04.26
Time: 14:24:38
Freeze Frame:
Bin. Bits: 00000000 00000000
Bin. Bits: 10000000 00000000
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4G8 959 795 E HW: 4G8 959 795 A
Component: TSG HL H04 0212
Coding: 010F14204000628002080002
VCID: 4487FA11C79BD86AB1-8011
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H04 0212
Address 85: On Board Cam. (J852) Labels:| 7P6-907-217.clb
Part No SW: 4G0 907 217 HW: 4H0 907 217 A
Component: DPC-SG H25 0036
Revision: -------- Serial number: 262130025421000
Coding: 62040000
ASAM Dataset: EV_OnBoardCamerDPC 001007
ROD: EV_OnBoardCamerDPC.rod
VCID: 65C107956461C16246-8031
Address 8E: Image Processing (J851) Labels:| 4H0-907-107-V2.clb
Part No SW: 4G0 907 107 D HW: 4H0 907 107
Component: BV-SG H30 0038
Serial number: 005000051911117
Coding: 044088181211
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
VCID: 275D4D9D5EED1372B4-8073
Address 8F: Pretens. Frt Left
Cannot be reached
Address 90: Pretens. Frt Right
Cannot be reached
End-------------------------(Elapsed Time: 04:35)--------------------------
L'analisi e' stata fatta a motore acceso.
Il risultato l'ho postato come CODE per avere, credo, una migliore leggibilita', ma se era meglio allegare il log o incollare il contenuto in un altro formato vi prego di dirmelo in modo da non commettere un altro errore la prossima volta.
Grazie in anticipo!
Ciao
Angelo
