Risultati da 1 a 8 di 8
Discussione: Problemi VW Polo Aiuto lettura vag...
    May 2014
    Audi a3 2.0 TDI 8p Ambition
    Predefinito Problemi VW Polo Aiuto lettura vag...
    Qualcuno puo aiutarmi nella lettura, la piccola polo ha problemi di motore, non tiene il minimo e tossisce.... Grazie in anticipo.
    Friday,23,August,2019,21:39:07:62939
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: Release 12.12.0 (x64)
    Data version: 20130910
    License Plate:
    Chassis Type: 6R (6N0)
    Scan: 01 03 08 09 15 17 19 25 44 56
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    56-Radio -- Status: Not registered 0011
    Address 01: Engine (J623-CGPB) Labels: 03E-906-019-CGP.clb
    Part No SW: 03E 906 019 M HW: 03E 906 019 B
    Component: SIMOS11.1 H03 8319
    Revision: -------- Serial number:
    Coding: 00110016000400080000
    Shop #: WSC 00788 648 00255
    ASAM Dataset: EV_ECM12MPI02103E 001005
    ROD: N/A
    VCID: 2E53E83371E29E6E36F-807B
    No ASAM data for: "EV_ECM12MPI02103E" (VW25)
    1 Fault Found:
    10964 - ROD - Unknown Error Code
    - 00 [237]
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 88469 km
    Date: 2099.14.04
    Time: 21:58:28
    Readiness: 0110 0101
    Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
    Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
    Component: ESP8.2i front H05 0001
    Revision: --------
    Coding: 210224E3217400B9842E24EB84D900401100
    VCID: 871DFD9732D86F26559-80D2
    1 Fault Found:
    01314 - Engine Control Module
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 0
    Fault Frequency: 20
    Reset counter: 128
    Mileage: 88399 km
    Time Indication: 0
    Date: 2035.14.00
    Time: 13:09:49
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x8000
    Hex Value: 0x1207
    Hex Value: 0x13AE
    Hex Value: 0x207E
    Hex Value: 0x7D7F
    Hex Value: 0x7DF8
    Address 08: Auto HVAC (J301) Labels: 6R0-820-045.clb
    Part No SW: 6R0 820 045 F HW: 6R0 820 045 F
    Component: Man AC 02 0101
    Revision: 0002S 02
    VCID: 3169F34F68DC81962BD-8064
    1 Fault Found:
    00819 - High Pressure Sensor (G65)
    002 - Lower Limit Exceeded
    Freeze Frame:
    Fault Status: 01100010
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 88
    Mileage: 88469 km
    Time Indication: 0
    Date: 2003.14.04
    Time: 21:46:01
    Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
    Part No SW: 6R0 937 087 H HW: 6R0 937 087
    Component: BCM PQ25 H+4 H46 0230
    Revision: BF046001 Serial number: 0394 333100421
    Coding: 64B02BBF08A10048002008007D2B0C900040410F6086000020 0000000000
    VCID: 428BAC83DD7A0A0EC27-8017
    Subsystem 1 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
    Component: J386__TSG_FT 007 1611
    Coding: 18BC30
    Subsystem 2 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
    Component: J387__TSG_BT 007 1611
    Coding: 08BC30
    No fault code found.
    Address 15: Airbags (J234) Labels: 5K0-959-655.clb
    Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
    Component: VW10Airbag022 H09 0020
    Revision: -------- Serial number: 003GX00BVLL7
    Coding: 003232
    ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
    ROD: EV_AirbaVW10BPAVW250_VW24.rod
    VCID: 4A9B84A3ED4AD24E0A7-801F
    Crash sensor for side airbag; driver side:
    Serial number: 3575HRB404V085G271H+
    Crash sensor for side airbag; passenger side:
    Serial number: 3585HRB4051085G230VM
    Crash sensor for side airbag; rear driver side:
    Serial number: 3515RRB405N05BDS4134
    Crash sensor for side airbag; rear passenger side:
    Serial number: 3525RRB405L05BDSI98U
    Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    Part No SW: 6R0 920 860 E HW: 6R0 920 860 E
    Component: KOMBI H04 0304
    Serial number: 00000000000000
    Coding: 140200
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
    ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
    VCID: 3663C05389B2A6AE7EF-8063
    Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
    Part No SW: 6N0 909 901 HW: 6R0 937 087
    Component: GW-K-CAN TP20 0230
    Coding: 002200
    VCID: F0EFB64B2356489EE43-80A5
    1 Fault Found:
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 88469 km
    Time Indication: 0
    Date: 2035.14.04
    Time: 21:46:03
    Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H04 0304
    Serial number:
    Coding: 000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
    ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
    VCID: EADBA4230D8AB24EAA7-80BF
    Address 44: Steering Assist Labels: 6Q0-423-156.clb
    Part No: 6R0 423 156 B
    Component: LenkhilfeTRW V277
    Coding: 11250
    Shop #: WSC 00788
    VCID: 2F6DF537EAE897663D9-807A
    Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
    Part No SW: 1K0 035 186 AA HW: 1K0 035 186 AA
    Component: Radio RCD310 013 0036
    Revision: 01000000 Serial number: VWZ1Z2I6753558
    Coding: 0500040004
    Shop #: WSC 01357 011 00200
    VCID: 65C1571F6C941D36075-8030
    10 Faults Found:
    00870 - Bass Speaker Front Left (R21)
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 128
    Mileage: 88469 km
    Time Indication: 0
    Date: 2035.14.04
    Time: 21:46:05
    00871 - Bass Speaker Front Right (R23)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 128
    Mileage: 88469 km
    Time Indication: 0
    Date: 2035.14.04
    Time: 21:46:05
    00872 - Bass Speaker Rear Left (R15)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 128
    Mileage: 88469 km
    Time Indication: 0
    Date: 2035.14.04
    Time: 21:46:05
    00873 - Bass Speaker Rear Right (R17)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 128
    Mileage: 88469 km
    Time Indication: 0
    Date: 2035.14.04
    Time: 21:46:05
    00874 - Treble Speaker Front Left (R20)
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 88
    Mileage: 88469 km
    Time Indication: 0
    Date: 2035.14.04
    Time: 21:46:02
    00875 - Treble Speaker Front Right (R22)
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 88
    Mileage: 88469 km
    Time Indication: 0
    Date: 2035.14.04
    Time: 21:46:02
    00876 - Treble Speaker Rear Left (R14)
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 88
    Mileage: 88469 km
    Time Indication: 0
    Date: 2035.14.04
    Time: 21:46:02
    00877 - Treble Speaker Rear Right (R16)
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 88
    Mileage: 88469 km
    Time Indication: 0
    Date: 2035.14.04
    Time: 21:46:02
    00856 - Radio Antenna
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 88
    Mileage: 88469 km
    Time Indication: 0
    Date: 2035.14.04
    Time: 21:46:12
    03138 - Input AUX IN
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 88
    Mileage: 88469 km
    Time Indication: 0
    Date: 2035.14.04
    Time: 21:46:08
    End ---------------------------------------------------------------------
    Thanked: 371
    il vag che stai usando è toppo vecchio rispetto alla macchina, comunque pare essere un problema al sensore giri/fasatura dell’albero a cammes
  4. Il seguente utente ringrazia lucaropa per questo messaggio
    max3 (24-08-2019)
  5. #3
    May 2014
    Bhe effettivamente ce l'ho da qualche anno... dovrò aggiornarmi! Cmq grazie mille per l'aiuto!
  6. #4
    May 2014
    Aggiornamento situazione:
    in questi giorni, dopo l'aiuto nella lettura degli errori, ho iniziato a cercare il sensore giri/fasatura dell’albero a cammes, intendo cercarlo fisicamente nel motore, e credetemi se vi dico che è veramente nascosto, si trova nella parte posteriore del motore, il lato che da verso l'abitacolo ed è molto difficile raggiungerlo, comunque una volta individuato, lo ho smontato e sono andato ad ordinarne uno nuovo in autoricambi, costo 30 euro, ma purtroppo una volta rimontato l'esito è stato negativo, nel senso che il difetto non è scomparso. Cosi non volendo arrendermi ho fatto un'altro tentativo, ed ho sostituito un'altro sensore ovvero il sensore dell'albero motore,che si trova nella parte superiore del motore vicino le bobine, questo decisamente comodo da smontare, prezzo 20 euro, ma purtroppo il problema non era neanche questo... ora ho deciso di portare la macchina dal meccanico in quanto credo potrebbe essere qualcosa di piu serio, avendo gia fatto il tagliando e sostituito tutti i filtri (olio-aria-benzina) oltre che le candele e l'olio motore...
    Vi farò sapere ulteriore sviluppi.
    Ultima modifica di max3; 31-08-2019 alle 13:59
  7. #5
    Thanked: 371
    si è una roba strana, a me capitava una roba simile ma sulla 9n di mia moglie dopo mesi di tentativi ho scoperto che la egr non chiudeva bene e al minimo borbottava, ho prima tappato il lato gas di scarico con un lamierino fatto con una lattina e una volta visto che il problema era risolto, l’ho cambiata
  8. #6
    May 2014
    Grazie per questa ulteriore informazione, in questi casi tutte le esperienze ed i consigli sono preziosi!
  9. #7
    May 2014
    Buongiorno a tutti, da qualche giorno ho ripreso la macchina dal meccanico, in sostanza il problema era la catena di distribuzione, o meglio si era rotto il tendicatena, e logicamente la macchina andava fuori fase.Sostituito tutto il kit catena di distribuzione, ora la macchina è tornata a girare come un orologio, ma il vero problema è che ho scoperto che questo è un difetto di cui la polo ''ci soffre'', nel senso che non sono il primo, a detta del meccanico, a cui capita e che quindi in un futuro più lontano possibile, si presuppone potrebbe ricapitare...
    Speriamo almeno tra altri 90.000 km!
  10. Il seguente utente ringrazia max3 per questo messaggio
    gian8p (15-09-2019)
  11. #8
    Thanked: 371
    grazie per averci raccontato la fine della storia, non tutti lo fanno...
