Risultati da 1 a 10 di 11
Discussione: Errori riscontranti con il VAG
    Jun 2013
    Perugia (PG)
    audi a3
    Predefinito Errori riscontranti con il VAG
    Buongiorno a tutti facendo una scansione con il VAG ho riscontrato diversi problemi.
    Qualcuno potrebbe indicarmi cosa si può risolvere con poca spesa e tanta resa?
    Grazie a tutti qui sotto la vaggata:
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 1010
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    57-TV Tuner -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    77-Telephone -- Status: Malfunction 1010
    7D-Aux. Heat -- Status: Malfunction 0010
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 016 FF HW: 028 101 190 5
    Component: R4 2,0L EDC G000SG 6337
    Revision: 12345678 Serial number: AUX7Z0D5FNB035
    Coding: 0000072
    Shop #: WSC 06435 000 00000
    VCID: 6CDC73DA4F5CE17E43D
    3 Faults Found
    17075 - Fan 1 Control Circuit
    P0691 - 000 - Short to GND
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.16 V
    Bin. Bits: 00101100
    Temperature: 74.7∞C
    Duty Cycle: 9.6 %
    19558 - Motor for Intake Manifold Flap (V157)
    P3102 - 000 - No Signal
    Freeze Frame:
    RPM: 0 /min
    Torque: 108.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 11.93 V
    Bin. Bits: 00101100
    Torque: 0.0 Nm
    Torque: 354.0 Nm
    16785 - EGR System
    P0401 - 000 - Insufficient Flow
    Freeze Frame:
    RPM: 1890 /min
    Torque: 40.0 Nm
    Speed: 30.0 km/h
    Load: 20.0 %
    Duty Cycle: 14.7 %
    Bin. Bits: 00101000
    Mass Air / Rev.: 325.0 mg/str
    Mass Air / Rev.: 565.0 mg/str
    Readiness: 1 2 0 0 0
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No: 1K0 907 379 K
    Component: ESP FRONT MK60 0103
    Coding: 0023174
    VCID: 3A70858275888FCE811
    Subsystem 1 - Part No: 1K0 907 379 K
    No Faults Found
    or DTCs not supported by controller
    or a communication error occurred
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 F HW: 8P0 820 043 F
    Component: KlimavollautomatH12 0150
    Revision: 007849 Serial number: 8P0820043F
    Shop #: WSC 00000 000 00000
    VCID: 2F66A4D6BECA5A6626F
    3 Faults Found
    00483 - Control Module for Auxiliary Air Heater
    013 - Check DTC Memory
    Freeze Frame:
    Fault Status: 01101101
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 219
    Mileage: 434031 km
    Time Indication: 0
    Freeze Frame:
    ON
    01273 - Fresh Air Blower (V2)
    010 - Open or Short to Plus
    Freeze Frame:
    Fault Status: 01101010
    Fault Priority: 3
    Fault Frequency: 22
    Reset counter: 211
    Mileage: 429466 km
    Time Indication: 0
    Date: 2020.01.11
    Time: 13:26:56
    Freeze Frame:
    Temperature: 17.0∞C
    Speed: 0.0 km/h
    (no units): 44.0
    (no units): 172.0
    014 - Defective - Intermittent
    Freeze Frame:
    Fault Status: 00101110
    Fault Priority: 3
    Fault Frequency: 5
    Reset counter: 246
    Mileage: 432493 km
    Time Indication: 0
    Date: 2020.01.27
    Time: 19:15:00
    Freeze Frame:
    Temperature: 12.0∞C
    Speed: 98.8 km/h
    (no units): 44.0
    (no units): 165.0
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 C HW: 8P0 907 279 C
    Component: Bordnetz-SG H31 0202
    Revision: 00H31000 Serial number: 00000000828796
    Coding: E7885F068214100000000000000000000002FE0F5C
    Shop #: WSC 01913 264 93080
    VCID: 3D7A8E9E64A6B8F6A43
    Subsystem 1 - Part No: 8P1 955 119 B
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 01913
    Subsystem 2 - Part No: 4E0 910 557
    Component: REGENLICHTSENSORH10 0040
    Coding: 00150573
    Shop #: WSC 01913
    8 Faults Found
    00978 - Lamp for Low Beam; Left (M29)
    010 - Open or Short to Plus - Intermittent
    00979 - Lamp for Low Beam; Right (M31)
    01497 - Bulb for Blinkers; Front Right (M7)
    012 - Electrical Fault in Circuit - Intermittent
    02395 - Parking Light Front Right (M3)
    01504 - Bulb for License-Plate Light (X)
    01520 - Rain and Light Recognition Sensor (G397)
    004 - No Signal/Communication - Intermittent
    02071 - Local Databus
    01320 - Control Module for Climatronic (J255)
    Address 15: Airbags Labels: 8P0-959-655-84.lbl
    Part No SW: 8P0 959 655 D HW: 8P0 959 655 D
    Component: Airbag 8.4ED H00 0140
    Coding: 0010602
    VCID: 438EF8660242CE06D27
    Subsystem 1 - Part No: 8P0 959 655 D
    No Faults Found
    Address 16: Steering wheel Labels: 8P0-953-549.lbl
    Part No SW: 8P0 953 549 HW: 8P0 953 549
    Component: Lenks‰ulenmodul H11 0020
    Coding: 0000042
    VCID: FBFEC086BA32F6C65A7
    No fault code found.
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 930 K HW: 8P0 920 930 K
    Component: KOMBIINSTR. VDO H71 0200
    Revision: D01 Serial number: 2245DD01002845
    Coding: 0004108
    Shop #: WSC 00258 652 311681
    Subsystem 1 - Part No: 8P0 920 930 K
    No Faults Found
    Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
    Part No SW: 1K0 907 530 D HW: 1K0 907 951
    Component: Gateway H08 0100
    Revision: 08 Serial number: 2500104521058E
    Coding: 3D0F0FD8073100
    Shop #: WSC 01913 264 63888
    VCID: 28544FCA9B240D5EE75
    2 Faults Found
    01303 - Telephone Transceiver (R36)
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 254
    Reset counter: 3
    Mileage: 419496 km
    Time Indication: 0
    Date: 2019.10.04
    Time: 19:17:19
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 3
    Mileage: 434031 km
    Time Indication: 0
    Date: 2020.02.07
    Time: 18:02:15
    Address 25: Immobilizer
    Cannot be reached
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8P0 035 192 HW: 8P0 035 192
    Component: RNS-E HIGH EU H44 0650
    Revision: 03S Serial number: AUZBZ7D0003387
    Coding: 0209212
    VCID: ECDCF3DACF5C617EC3D
    2 Faults Found
    02261 - Data Medium
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 1
    Mileage: 433515 km
    Time Indication: 0
    Date: 2020.02.05
    Time: 16:48:51
    Freeze Frame:
    Mileage: 433510 km
    Count: 502
    Clock: 16:49
    02444 - Disk Drive Load / Eject Malfunction
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 252
    Mileage: 433314 km
    Time Indication: 0
    Date: 2020.02.04
    Time: 17:41:48
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX1.lbl
    Part No: 8P0 959 801 D
    Component: Tuersteuerger. H10 0030
    Coding: 0000120
    VCID: 3C7C839A7FBCB1FE93D
    1 Fault Found
    00105 - Signal Central Locking SAVE/LOCK Drivers Side
    008 - Implausible Signal
    Address 44: Steering Assist Labels: Redir Fail!
    Part No: 1K1 909 144 G
    Component: EPS_ZFLS Kl.10 1401
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 B
    Component: KSG H02 0040
    Coding: 008000186D288505488A016000
    VCID: 3B7E80867AB2B6C69A7
    Subsystem 1 - Component: Sounder n.mounted
    Subsystem 2 - Component: NGS n.mounted
    Subsystem 3 - Component: IRUE n.mounted
    2 Faults Found
    01565 - Luggage Compartment Light (W3)
    007 - Short to Ground
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MAX1.lbl
    Part No: 8P0 959 802 D
    Coding: 0000120
    Subsystem 1 - Part No: 8P0 959 802 D
    No Faults Found
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0209212
    2 Faults Found
    02261 - Data Medium
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 1
    Mileage: 433515 km
    Time Indication: 0
    Date: 2020.02.05
    Time: 16:48:51
    Freeze Frame:
    Mileage: 433510 km
    Count: 502
    Clock: 16:49
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 252
    Mileage: 433314 km
    Time Indication: 0
    Date: 2020.02.04
    Time: 17:41:48
    Address 57: TV Tuner Labels: None
    Part No SW: 8J0 919 148 C HW: 8J0 919 148
    Component: R78 TVHybridDVB 0370
    Revision: R0H11000 Serial number: 03000100029402
    Coding: 0001201
    Shop #: WSC 01236 785 00200
    VCID: 356A96BE5C9660B66C3
    Subsystem 1 - Part No: 8J0 919 148 C
    No Faults Found
    Address 76: Park Assist Labels: 8P0-919-283.lbl
    Part No SW: 8P0 919 283 HW: 8P0 919 283
    Component: Parkhilfe 4-Kan H06 0030
    Coding: 0000003
    VCID: F8F4DF8A8B04DDDE375
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8P0 862 335 F HW: 8P0 862 335 F
    Component: FSE_255x BT H21 0190
    Revision: 00000001 Serial number: 00000000350219
    Coding: 0010304
    VCID: 39729A8E708E84D688B
    2 Faults Found
    01523 - Microphone for Telephone (R38)
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 206
    Mileage: 421408 km
    Time Indication: 0
    Date: 2019.10.25
    Time: 11:50:05
    01304 - Radio
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 5
    Mileage: 428985 km
    Time Indication: 0
    Date: 2020.01.07
    Time: 18:11:53
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 D HW: 1K0 963 235 D
    Component: PTC-Element 0404
    Revision: 00700000 Serial number:
    VCID: 2C5CB3DA8FDC217E03D
    1 Fault Found
    00361 - Heater Element for Auxiliary Heater (Z35)
    014 - Defective
    hai una quantità di errori tale che dire poca spesa tanta resa...vabbè,
    Per iniziare resettali tutti e rifai una scansione dopo aver fatto un giro con la macchina probabilmente alcuni spariranno, quelli che tornano o rimangono sono quelli realmente da gestire.
    Thanked: 764
    quoto luca.
    tanti errori tutti insieme si puo' pensare che siano nati con il distacco di connettori elettrici ecc, durante lavori di manutenzione o installazione gadget/retrofit.
    prova a cancellare tutto (comando "clear all DTC" col vag), e vedi se gli errori si ripresentano. (ne troverai magari solo 1 o 2, e allora vai ad approfondire quelli. Se sei fortunato, dopo ilreset troverai zero errori, a conferma della mia ipotesi del distacco dei connettori).
    Jun 2013
    Perugia (PG)
    audi a3
    grazie per le risposte ma questo è quello che è uscito fuori dopo il reset....
    Thanked: 764
    azz....
    guardando gli errori della centralina 09, hai praticamente tutti i fari non funzionanti.
    hai controllato le lampadine? tutte fulminate nello stesso momento? poco credibile.
    secondo me c'e' un qualche connettore staccato, su qualche centralina.
    tra l'altro, vedo in diagnosi che la centr. 03 e la centr. 17 non comunicano...
    idem con la radio (37 e 56), non funziona il cd e la sezione media (SD? usb?).
    poi non funziona il telefono, non funziona il riscaldamento supplementare e la ventola del clima, non funziona la luce dentro il bagagliaio, e mille altre cose. (e i guasti sono nati tutti nella stessa data, intorno al 4 e 5 febbraio).
    Hai montato lampadine a led in quei giorni? Forse quei led NON sono canbus...
    hai smontato-rimontato qualche pezzo dentro l'abitacolo? (per riparazioni, per retrofit di nuovi accessori, ecc). ha codificato qualcosa col vag? (pasticciando su qualche byte, senza accorgerti).
    boh. una fila di 40 o 50 errori, nati lo stesso giorno, e' veramente strano. Per deduzione logica, e' poco redibile che possano essere tutti guasti fisici.
    c'e' quasi sicuramente qualcosa che non quadra nei cablaggi (insisto con la mia "teoria" di qualche spinotto elettrico scollegato, ecc).
    oppure c'e' qualche fusibile bruciato (forse quello che controlla il canbus. a memoria NON SO DIRE quale sia, ma lo puoi cercare nel manuale di uso e manutenzione).
    controlla anche la scatola fusibili nel vano motore, oltre alla scatola fusibili classica che si trova a sinistra del volante
    per aiutarti, puoi controllare il significato preciso dei tuoi odici errore nel sito ross-tech.com, swzine wiki, sotto-menu "fault codes".
    Ci sono varie pagine, che per ogni codice di errore spiegano sintomi, possibili cause, possibili soluzioni.
    in bocca al lupo.
    Jun 2013
    Perugia (PG)
    audi a3
    grazie per la risposta,la radio e le luci funzionano tutte perfettamente, tempo fa provai a montare nelle luci di posizione delle lampadine led, che non risultavano collegate quindi ho rimantato le alogene.
    l'unica cosa che la radio rns-e ha come difetto è l'espulsione del cd che va tipo in loop.
    la mancanza di comunicazione tra le due centraline 03 -17 cosa potrebbe essere?
    Thanked: 764
    Citazione Originariamente Scritto da icecom Visualizza Messaggio
    ...la mancanza di comunicazione tra le due centraline 03 -17 cosa potrebbe essere?
    non ne ho idea. potrebbe anche essere difettoso il tuo vag (i vag comprati in rete, al prezzo di 20-30-50 euro, sono tutti cloni cinesi=copie pirata, e purtroppo a volte presentano bug, e si piantano).
    prova chiedere a un amico se ti fa la scansione e la cancellazione errori, usando il suo vag (che in teoria sara' un' altra edizione ecc. Magari quella copia funziona bene e dialoga anche con centr. 03 e 17).
    nel forum trovi la discussione "censimento umbria", e qualche utente di perugia risultera' registrato, di sicuro.
    prova contattarlo in privato, chiedi se ha il vag e se ha pazienza di aiutarti.
    vi incontrate di persona a perugia, si beve una birra e si prova a collegare quell' altro vag. (e' solo un tentativo, forrse molto fantasioso, ma non costa niente=1 birra e 2 chiacchere.
    Non si sa mai, magari risolvi, perche' i vag difettosi sono tanti, in giro.
    Jun 2013
    Perugia (PG)
    audi a3
    Grazie per il suggerimento, ho altri due VAG un HEX2 ed un altro classico vediamo se anche con questi mi escono gli stessi errori ed eventualmente resetto...
    Thanked: 764
    se hai altri vag, e' ancora piu facile. (anche un vag molto vecchio va bene per la tua macchina, nella scansione vedo motore bkd, quindi ha circa 13-14 anni - come la mia).
    fai la prova con un altro vag, e tieni aggiornata la discussione, che son curioso di capire cosa e' successo nella tua macchina.
    Jun 2013
    Perugia (PG)
    audi a3
    la mia ha 16 anni con 435 mila km
