Risultati da 1 a 10 di 24
Discussione: Tergicristalli anteriori morti
    Jul 2014
    Rieti (RI)
    Audi A5 2.0 TDI SB
    Predefinito Tergicristalli anteriori morti
    Qualche giorno fa provo ad accendere i tergicristalli anteriori e... niente... solo il getto del liquido ma le spazzole non si muovono in nessuna posizione... qualcuno di voi sa indicarmi se dipende dalla centralina del motore tergicristallo o da qualche altro componente? Grazie a tutti!!
    Segue vaggata:
    Monday,01,March,2021,18:31:58:62939
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 12.12.0.0
    Data version: 20130910
    VIN: WAUZZZ8T6BA095318 License Plate:
    Mileage: 229080km-142343mi Repair Order:
    Chassis Type: 8T (8T0)
    Scan: 01 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 62 72 77
    VIN: WAUZZZ8T6BA095318 Mileage: 229080km/142343miles
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: Sporadic communication error 1000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: Sporadic communication error 1000
    Address 01: Engine (J623-CAHA) Labels: 03L-906-019-CAG.clb
    Part No SW: 03L 906 022 NP HW: 03L 906 019 AL
    Component: R4 2,0L EDC H35 9098
    Revision: 25H35---
    Coding: 1A194012230403080000
    Shop #: WSC 06324 000 00000
    ASAM Dataset: EV_ECM20TDI03L906022NP A02009
    ROD: EV_ECM20TDI03L906022NP.rod
    VCID: 800FE68B1BF6581E143-80D5
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes
    Cannot be reached
    Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
    Part No SW: 8K0 907 064 CP HW: 8K0 907 064 CP
    Component: BCM2 2.0 H05 0435
    Revision: 00002001
    Coding: 032400
    Shop #: WSC 06325 000 00000
    VCID: 800FE68B13F6581E143-80D5
    Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
    Component: FBSAUDIB8 IDG H60 0072
    Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
    Component: J764 ELV MLB H37 0042
    1 Fault Found:
    01330 - Central Control Module for Central Convenience (J393)
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 38
    Mileage: 229054 km
    Time Indication: 0
    Date: 2021.03.01
    Time: 10:05:54
    Address 08: Auto HVAC (J255) Labels: Redir Fail!
    Part No SW: 8T1 820 043 AG HW: 8T1 820 043 AG
    Component: KLIMA 1 ZONE H08 0182
    Revision: A0000000 Serial number: 01250620111776
    Coding: 34200000
    Shop #: WSC 47122 002 1048576
    VCID: 76E30053C132E6AEBEF-8023
    1 Fault Found:
    01087 - Basic Setting Not Performed
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 251
    Mileage: 228005 km
    Time Indication: 0
    Date: 2021.01.28
    Time: 18:09:16
    Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
    Part No SW: 8K0 907 063 N HW: 8K0 907 063 N
    Component: BCM1 1.0 H30 0392
    Revision: 09030001 Serial number: 00000001118087
    Coding: 26005091403400010009000000005D5D001C03080601000100 0000
    VCID: 3A7BD463B5AA42CE9A7-806F
    Subsystem 1 - Part No SW: 8T1 955 119 D HW: 8J1 955 119 Labels: 1KX-955-119.CLB
    Component: WWS 180611 H15 0070
    Coding: 00FD11
    Subsystem 2 - Part No SW: 8K0 941 531 AR HW: 8K0 941 531 AR
    Component: E1 - LDS H03 0031
    2 Faults Found:
    00908 - Control Module for Wiper Motor
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 39
    Mileage: 229054 km
    Time Indication: 0
    Date: 2021.03.01
    Time: 10:05:00
    003 - Mechanical Failure
    Freeze Frame:
    Fault Status: 01100011
    Fault Priority: 3
    Fault Frequency: 8
    Reset counter: 254
    Mileage: 229031 km
    Time Indication: 0
    Date: 2021.03.01
    Time: 08:05:00
    Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
    Part No SW: 8K0 919 475 T HW: 8P0 919 475 M
    Component: PARKHILFE 4K H01 0081
    Revision: 11001001 Serial number: 36891118573891
    Coding: 000007
    VCID: 4A9B84A3E54AD24E0A7-801F
    Address 15: Airbags (J234) Labels: 8K0-959-655.clb
    Part No SW: 8K0 959 655 L HW: 8K0 959 655 L
    Component: AirbagVW-AU10 H44 0610
    Serial number: 003JMD0D09A3
    Coding: 30513438363030303030554A304C38543053
    ASAM Dataset: EV_AirbaECUVWAUDI010 003010
    ROD: EV_AirbaECUVWAUDI010_AU48.rod
    VCID: 4683B093F952362EEEF-8013
    Crash sensor for side airbag; driver side:
    Serial number: 6334MSME5F66134CP
    Crash sensor for side airbag; passenger side:
    Serial number: 6344MSME61016056%
    Crash sensor for side airbag; rear driver side:
    Serial number: 6352QSME445C2F58W
    Crash sensor for side airbag; rear passenger side:
    Serial number: 6362QSME055C4562H
    Crash sensor for front airbag; driver side:
    Serial number: 63732SME731D2D724
    Crash sensor for front airbag; passenger side:
    Serial number: 63832SME3F5C017CC
    Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
    Part No SW: 8R0 953 568 K HW: 8R0 953 568 K
    Component: Lenks.Modul H07 0156
    Revision: 00000000 Serial number: 20110704001118
    Coding: 000012
    VCID: 4999BBAFE04CD95603D-801C
    Component: E221 - MFL H02 0010
    Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
    Part No SW: 8T0 920 901 F HW: 8T0 920 901 F
    Component: KOMBIINSTR. H33 0258
    Revision: 00300000 Serial number: EHP22RG6C
    Coding: 0F05300002000008040000
    VCID: 377DCD5786B85FA6659-8062
    1 Fault Found:
    00771 - Fuel Level Sensor (G)
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 7
    Fault Frequency: 254
    Reset counter: 254
    Mileage: 217734 km
    Time Indication: 0
    Date: 2020.03.30
    Time: 10:50:39
    Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
    Part No SW: 8T0 907 468 AB HW: 8T0 907 468 H
    Component: GW-BEM 5CAN H06 0117
    Revision: GB800053 Serial number: 5300G11614811B
    Coding: 00CF07
    VCID: 8109E38F18FC51161BD-80D4
    Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
    Component: J367-BDM H07 0140
    Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
    Component: J532_DCDCStab H05 0006
    2 Faults Found:
    01303 - Telephone Transceiver (R36)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 57
    Reset counter: 39
    Mileage: 228034 km
    Time Indication: 0
    Date: 2021.01.29
    Time: 10:02:39
    Freeze Frame:
    Bin. Bits: 10000
    Voltage: 12.50 V
    Count: 8
    Bin. Bits: 10000
    01316 - ABS Control Module
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 39
    Mileage: 229054 km
    Time Indication: 0
    Date: 2021.03.01
    Time: 10:05:55
    Freeze Frame:
    Bin. Bits: 10000
    Voltage: 12.10 V
    Count: 12
    Bin. Bits: 10000
    Time: 25.40 s
    Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
    Part No SW: 8T0 959 793 M HW: 8T0 959 793 D
    Component: TSG FA H08 1501
    Revision: -------- Serial number: --------------
    Coding: 011002625000450005
    VCID: 53A599C732009386791-8006
    Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
    Revision: 00002001 Serial number: 0152830207
    Coding: 0100062020B904C08120043680000000
    3 Faults Found:
    02615 - Fuel Tank Cap; Lock
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 251
    Mileage: 228005 km
    Time Indication: 0
    Date: 2021.01.28
    Time: 18:18:48
    02616 - Fuel Tank Cap; Unlock
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 251
    Mileage: 228005 km
    Time Indication: 0
    Date: 2021.01.28
    Time: 18:19:20
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 38
    Mileage: 229054 km
    Time Indication: 0
    Date: 2021.03.01
    Time: 10:05:54
    Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
    Part No SW: 8T0 959 792 M HW: 8T0 959 792 D
    Component: TSG BF H08 1501
    Coding: 011002225000450005
    VCID: 52AB9CC30D1A9A8E727-8007
    Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
    Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
    Component: EPB Audi B8 H09 0100
    Revision: 00000003 Serial number: 00000000964502
    Shop #: WSC 00000 000 00000
    VCID: 3467FA5B97CEB4BE40B-8061
    Address 55: Xenon Range Labels: 8K0-907-357.clb
    Part No: 8K5 907 357 B
    Component: Dynamische LWR H02 0010
    Revision: 00000001 Serial number:
    Coding: 0000001
    VCID: 3979CB6F70AC49D693D-806C
    Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
    Part No SW: 8T1 035 186 P HW: 8T1 035 186 P
    Component: Concert3 H07 0350
    Revision: 00000012 Serial number: AUZ5Z6K1607976
    Coding: 0500048204040500015B070000
    Shop #: WSC 06325 123 12345
    VCID: 4487AA9BC76E043EF0B-8011
    Subsystem 1 - Part No SW: 8T0 919 603 F HW: 8T0 919 603 F
    Component: Display
    Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
    Part No SW: 8T0 959 795 N HW: 8T0 959 795 B
    Component: TSG HL H06 1501
    Coding: 010002224000450005
    VCID: 56A360D321F286AE9EF-8003
    Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
    Component: TSG HR H06 1501
    Address 77: Telephone Labels: RETROFIT77.lbl
    Part No SW: KTC 364 31P HW: KTC 364 31P
    Component: SWP:3.31.6 H24 0220
    Revision: 00000000 Serial number: 00000000000000
    Shop #: WSC 21977 142 74100
    VCID: 3365F94752C0B386591-8066
    End ---------------------------------------------------------------------
    Thanked: 566
    Considera che prima di smontare e brigare è bene controllare il fusibile del tergicristallo.
    Ciò premesso, sicuramente i due errori 00908 puntano sul motore tergi o relativi bracci. ma, purtroppo dicono solo che non va il motore o non va la centralina.
    Bisogna vedere se i bracci tergi sono bloccati meccanicamente (ossido, grippaggi che bloccano le articolazioni).
    Se i bracci alzati dal vetro e sconnessi dal motore sono liberi di muoversi, è il sistema motore tergi, che incorpora la centralina J400 ad aver problemi.
  4. Il seguente utente ringrazia dalcro per questo messaggio
    dgtiziano (06-03-2021)
  5. #3
    Jul 2014
    Thanked: 113
    In primis (come proposto da altro utente),verifica il fusibile che sia ok. Con verifica intendo estrarre il fusibile ed accertarsi con tester che sia ok,non solo a vista.
    Se ti può aiutare:
    Ultima modifica di Marcy_68; 06-03-2021 alle 16:57
  6. Il seguente utente ringrazia Marcy_68 per questo messaggio
  7. #4
    Jul 2014
    Rieti (RI)
    Audi A5 2.0 TDI SB
    Grazie a tutti per le risposte, comunque il fusibile è ok da tester e il braccio si muove liberamente. Ho anche applicato 12 v diretti al motore e quest'ultimo funziona. A questo punto credo che vada sostituita la centralina J400 in blocco con il motore.
  8. #5
    se il motorino funziona (con alimentazione diretta), e i bracci hanno un movimento libero, vuol dire che non ci sono guasti "fisici", di tipo meccanico. Bisogna concentrare la nostra attenzione su elettricita' e cablaggi.
    prima di pensare di cambiare pezzi/centraline: hai verificato se i 12 volt arrivano sul cavo che alimenta il motorino?
    ipotesi: quel cavo potrebbe essere interrotto? (es: e' stato dato qualche strattone ai cavi, durante altre manutenzioni, ecc).
    oppure potrebbe essere la leva tergi sul piantone che non da' il contatto elettrico?
    oppure potrebbe esserci qualche morsettiera ossidata, ecc? (sappiamo beneche la zona del motorino tergi e' sporca e soggetta ad allagamenti, se si tappano i fori di scarico della vasca dei pesci. In quel caso, l'acqua puo' ossidare i contatti nelle morsettiere).
  9. #6
    Jul 2014
    Thanked: 113
    Citazione Originariamente Scritto da dgtiziano Visualizza Messaggio
    Ok,queste sono le parti coinvolte:
    Bisogna andare per esclusione....
    Hai subito un incidente di recente? Da scansione postata si evince pure questo problema ABS:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 39
    Mileage: 229054 km
    Time Indication: 0
    Date: 2021.03.01
    Time: 10:05:55
    Freeze Frame:
    Bin. Bits: 10000
    Voltage: 12.10 V
    Count: 12
    Bin. Bits: 10000
    Time: 25.40 s
    Ti chiedo questa info. in quanto vi è una nota relativa al cofano:
  10. #7
    Jul 2014
    Rieti (RI)
    Audi A5 2.0 TDI SB
    No nessun incidente, comunque i tergicristalli non si muovono nemmeno dal menu service del MMI. Il problema ABS non l'avevo notato... di che si tratta?
  11. #8
    Thanked: 566
    La dritta veramente interessante è nell'ultime righe sottolineate di rosso.
    Sembrerebbe possibile un blocco del tergi se la macchina "vede" il cofano aperto (forse i tergi possono sbattere nel cofano su).
    Se è guasto o scollegato lo switch nelle serrature cofano si ferma il tergicristallo.
  12. Il seguente utente ringrazia dalcro per questo messaggio
  13. #9
    Jul 2014
    Rieti (RI)
    Audi A5 2.0 TDI SB
    Controllerò anche quello, grazie!
    Ma comunque se fosse un problema di cofano aperto, perché mi da errore con il VAG?
  14.
  15. #10
    ... Ma comunque se fosse un problema di cofano aperto, perché mi da errore con il VAG?
    bella domanda! (e non c'e risposta, mi sa...)
    fai tutte le prove che ti hanno suggerito i vari utenti intervenuti, e vai per esclusione, esaminando un pezzo alla volta.
  16. Il seguente utente ringrazia gian8p per questo messaggio
