Risultati da 1 a 4 di 4
Discussione: problema apertura portiere
    Aug 2014
    Livorno (LI)
    audi a4 b7 avant 2007 170cv
    Predefinito problema apertura portiere
    Salve, oggi mio cugino mi ha chiesto di farli una vaggata alla sua A3 cabrio che ha dei problemi all'apertura delle portiere...
    allego la vaggata:)
    mi sapete dare delucidazioni?
    grazie
    Saturday,28,August,2021,12:15:31:39744
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
    VCDS Version: 17.1.3.0
    Data version: 20170203 DS267.2
    www.Ross-Tech.com
    VIN: TRUZZZ8P391015527 License Plate:
    Mileage: 153190km-95187mi Repair Order:
    Chassis Type: 8P (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 26 42 44 46 47 52 56 62 72
    VIN: TRUZZZ8P391015527 Mileage: 153190km-95187miles
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    26-Auto Roof -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
    Part No SW: 03L 906 022 LS HW: 03L 906 022 BQ
    Component: R4 2.0l TDI 0000SG 9978
    Revision: 13H01--- Serial number: AUX7Z0I3FNS0MO
    Coding: 0000072
    Shop #: WSC 01236 785 00200
    VCID: 010E5E4658924A49E6-8054
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes (-----) Labels: None
    Part No SW: 1K0 907 379 CD HW: 1K0 907 379 AD
    Component: ESP MK60EC1 H35 0120
    Revision: 00H35001
    Coding: 11424012492300FF881002E6922000423800
    Shop #: WSC 01027 002 1048576
    VCID: 76E43D9AC15C7DF1C3-8022
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 BC HW: 8P0 820 043 BC
    Component: KlimavollautomatH03 0110
    Revision: 292728 Serial number: 8P0820043BC
    Shop #: WSC 00000 000 00000
    VCID: 6ED415FA790C45310B-803A
    Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
    Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
    Component: Bordnetz-SG H54 2801
    Revision: 00H54000 Serial number: 00000009588168
    Coding: 11202F0190141080EF00001C0000000000094E016401000300 A000000000
    VCID: 489883623B28BB0161-801C
    Subsystem 1 - Part No: 8P1 955 119 F Labels: 1KX-955-119.CLB
    Component: Wischer AU350 H10 0040
    Coding: 00056595
    Shop #: WSC 01236
    1 Fault Found:
    01504 - Bulb for License-Plate Light (X)
    012 - Electrical Fault in Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00111100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 128
    Mileage: 152363 km
    Time Indication: 0
    Date: 2021.08.13
    Time: 02:34:00
    Freeze Frame:
    ON
    Voltage: 14.05 V
    OFF
    ON
    OFF
    OFF
    OFF
    Address 15: Airbags Labels: 8P7-959-655.clb
    Part No SW: 8P7 959 655 HW: 8P7 959 655
    Component: SL Airbag 9.43 H01 0020
    Revision: 93H01002 Serial number: 003BS000PGDA
    Coding: 0021324
    VCID: 06044D5A71BC6D71D3-8052
    Subsystem 1 - Serial number: 6332DRB408B4D426V
    Subsystem 2 - Serial number: 6342DRB408B64D2C/
    Subsystem 3 - Serial number: 63747RB404D64D46X
    Subsystem 4 - Serial number: 63847RB404D64C76-
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
    Component: J0527 036 0070
    Coding: 0000011
    VCID: 78F833A20B480B81D1-802C
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
    Part No SW: 8P0 920 931 S HW: 8P0 920 931 S
    Component: KOMBIINSTR. VDO H20 0860
    Revision: D0H20008 Serial number: 2243I008092144
    Coding: 0004128
    Shop #: WSC 00001 001 00001
    VCID: 4382944E020E9859B4-8016
    Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
    Part No SW: 1K0 907 530 S HW: 1K0 907 951
    Component: J533__Gateway H16 0210
    Revision: H16 Serial number: 3400K0940705B7
    Coding: E9807F26100202009100
    VCID: 377AF09E46D6C4F918-8062
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D0H20008 Serial number: AUX7Z0I3FNS0MO
    Address 26: Auto Roof Labels: Redir Fail!
    Part No: 8P7 959 255
    Component: VSG AUDI A3 H15 0110
    VCID: 020C514A5D945151FF-8056
    Address 42: Door Elect, Driver Labels: None
    Part No SW: 8P7 959 801 B HW: 8P7 959 801 B
    Component: Tuer-SG H03 0080
    Coding: 0004276
    VCID: 418E9E4618128A49A6-8014
    4 Faults Found:
    01552 - Motor for Central Locking; Drivers Door (V56); Lock
    00096 - Drivers Door Central Locking (Safe) Motor (V161)
    00928 - Locking Module for Central Locking; Front Driver Side (F220)
    008 - Implausible Signal
    01706 - Switch for Mirror-Adjust (E43)
    008 - Implausible Signal - Intermittent
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K0 909 144 E
    Component: EPS_ZFLS Kl. 233 2501
    Revision: 00H15000
    VCID: 2C50DFF28F90772165-8078
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 L
    Component: KSG H11 0080
    Coding: 1880200002186D088505488AC637
    Shop #: WSC 19156 000 1048576
    VCID: 45868A560C3AA6699A-8010
    Subsystem 1 - Component: Sounder No Answer
    Subsystem 2 - Component: NGS No Answer
    Subsystem 3 - Component: IRUE No Answer
    3 Faults Found:
    01333 - Door Control Module; Rear Left (J388)
    004 - No Signal/Communication
    01334 - Door Control Module; Rear Right (J389)
    01403 - Glass-Break Sensors; Rear
    011 - Open Circuit
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P7 035 382 HW: 8P7 035 382
    Component: AB2 SUBWOOFERBOXH06 0160
    Revision: 00005 Serial number: 30703841067515
    VCID: 74E0079217206FE1FD-8020
    Address 52: Door Elect, Pass. Labels: None
    Part No SW: 8P7 959 802 B HW: 8P7 959 802 B
    Coding: 0004276
    VCID: 428C914A1D149151BF-8016
    2 Faults Found:
    01553 - Motor for Central Locking; Passenger Door (V57); Lock
    00929 - Locking Module for Central Locking; Front Passenger Side (F221)
    Address 56: Radio Labels: 8J0-035-1xx-56.clb
    Part No SW: 8P0 035 186 P HW: 8P0 035 186 P
    Component: R Concert2+ H04 0270
    Revision: 00H04000 Serial number: AUZ1Z3I9750448
    Coding: 0110211
    VCID: 3F8A98BE6EE6FCB9D0-806A
    1 Fault Found:
    00003 - Control Module
    014 - Defective
    Freeze Frame:
    Fault Status: 01101110
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 140424 km
    Time Indication: 0
    Date: 2019.11.14
    Time: 23:50:34
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
    Part No SW: 8P7 959 811 A HW: 8P7 959 811 A
    Component: Tuer-SG H01 0030
    Coding: 0000144
    Shop #: WSC 01236 785 1012552
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
    Part No SW: 8P7 959 812 A HW: 8P7 959 812 A
    Coding: 0000144
    End-------------------------(Elapsed Time: 02:15)--------------------------
    Address 17,8P0 920 931 S,recoded (Short coding),from,0004128,to,0004108,(00001/001/00001),
    Saturday,28,August,2021,12:32:48:39744
    www.Ross-Tech.com
    09-Cent. Elect. -- Status: OK 0000
    56-Radio -- Status: OK 0000
    Coding: 0000072
    Revision: 00H35001
    Coding: 00056595
    Shop #: WSC 01236
    Coding: 0021324
    Coding: 0000011
    Coding: 0004108
    Coding: 0004276
    2 Faults Found:
    Revision: 00H15000
    3 Faults Found:
    011 - Open Circuit
    Coding: 0004276
    1 Fault Found:
    Coding: 0110211
    Coding: 0000144
    Coding: 0000144
    End-------------------------(Elapsed Time: 02:14)--------------------------
    di che anno e' la A3 di tuo cugino?
    su vetture Audi vecchiotte, diciamo nell'intorno dei 10 anni di vita, succede spesso che le serrature si guastino.
    i motorini elettrici della serratura perdono forza, perche' si accumula un po' di sporco dei carboncini, oppure si mangiano un po' i dentini degli ingranaggi, ecc.
    purtroppo e' un guasto noto, gia' capitato a molti utenti: cerca in rete che ci sono mille discussioni in merito, e ne capirai di piu'.
    la soluzione e' cambiare le serrature, ma le originali costano care.
    Esistono sul mercato varie serrature "aftermarket", di marchi sconosciuti, e costano 1/4 rispetto ai ricambi originali.
    -leggendo i forum- pare che le serrature NON originali, siano costruite in modo "un po' troppo economico", cioe' appaiono piuttosto fragili, e molto spesso cedono nuovamente (qualche utente le ha dovute cambiare ancora nel giro di 1 anno... uno sbattimento, e alla fine non hai mica rispamiato!).
    alcuni utenti del forum hanno fatto un tentativo di pulizia e lubrificazione sulle vecchie serrature, ma e' un lavoro che in genere non ha dato grandi risultati: funzionano per qualche tempo, ma il problema ritorna, molto presto.
    Bisogna aprire il guscio della serratura, per fare pulizia, ed risulta poi difficile richiuderlo, perche' ci sono mille mollette e meccanismi da riposizionare in modo preciso (e questo ha messo in crisi alcuni utenti, che non sono più riusciti a richiudere la serratura).
    Cerca info in rete, e trovi di sicuro i tutorial x smontaggio, sistemazione molle al rimontaggio, ecc. E ti fai una idea precisa dei problemi.
    prima di cambiare pezzi, forse vale la pena provare la pulizia/lubrificazione. (se te la senti come manualità, se hai qualche attezzo in garage, ecc. Provare non ti costa niente).
    soprattutto prova a verificare anche il fascio di cavi tra telaio e portiera. (dentro il "soffietto" di gomma).
    Col tempo i cavi si rinsecchiscono, e si spezzano.
    (nello snodo della porta, i cavi sono sottoposti a sollecitazioni e trazioni ogni volta che apri e chiudi lo sportello: ci sta che dopo 10 anni abbiano ceduto...).
    siccome vedo numerosi errori in diagnosi, ripetuti in entrambe le porte anteriori, magari si è proprio interrotto un filo, un "comune", un "segnale", che comanda tutte le serrature. boh.
    se fosse solamente un filo rotto, lo risolvi "in 10 minuti", con un paio di saldature a stagno, da proteggere poi con la guaina termorestringente.
    Ragionaci con calma, ti ho dato alcuni suggerimenti molto generici.
    Considera che a distanza nel forum, senza poter fare prove col tester sulla macchina, ecc, si puo' solo fare qualche ipotesi, e' sempre un "tirare a indovinare", purtroppo.
    Ultima modifica di gian8p; 28-08-2021 alle 17:22
    marco7576 (28-08-2021)
  5. #3
    Aug 2014
    Livorno (LI)
    Come sempre gentilissimo
    Comunque dovrebbe essere un 2007 credo...
  6. #4
    2007 come la mia.
    e' un'eta' assolutametne "papabile" per ritrovarsi le serrature rotte, o cavi rotti.
    come ti ho scritto, e' gia' successo a tanti altri audisti, con vetture stagionate; io "mi gratto" intanto che lo scrivo, perche' potrei essere il prossimo a subire il medesimo danno!!
    Ultima modifica di gian8p; 28-08-2021 alle 17:36
  7. Il seguente utente ringrazia gian8p per questo messaggio
