Risultati da 1 a 2 di 2
Discussione: Vcds condifica apertura macchina con suono
    New Entry L'avatar di robotic74
    Dec 2015
    Massa-Carrara (MS)
    AUDI A3 8V 1.4 TFSI
    Predefinito Vcds condifica apertura macchina con suono
    Raga avete una guida con vcds per la mia 8V A3 del 2014
    vorrei abilitare la funzione del suono in apertura con telecomando,
    ma non trovo nulla.
    thx
    Audi lover L'avatar di speedmaster
    Dec 2012
    Thanked: 13
    Savona (SV)
    AUDI A3 SB Sline TDI 150 Cv
    Citazione Originariamente Scritto da robotic74 Visualizza Messaggio
    ma non trovo nulla.
    thx
    [09] CENTRAL ELECTRONICS
    Acoustic (Alarm Beep) on Lock - TESTED AUDI A3 1.2T ‘13
    NOTE: Car makes one chirping sound, does not use the horn.
    [09] Central Electronics -> Adaptation ->
    Acknowledgement Signals - Akustische Rueckmeldung verriegeln (Lock acoustic feedback)
    CHANGE: Set each or one of them to Yes
    Acoustic (Alarm Beep) on Unlock - TESTED AUDI A3 1.2T ‘13
    NOTE: Car makes two chirping sounds, does not use the horn.
    Acknowledgement Signals - Akustische Rueckmeldung entriegen (Un-lock acoustic feedback)
    Acoustic Lock Menu (only for lock, enable/disable using DIS) - TESTED AUDI A3 1.2T ‘13
    NOTE: From factory there was no option to enable/disable using DIS.
    Acknowledgement Signals -Menuesteuerung akustische Rueckmeldung
    CHANGE: Set Yes
