Ho vaggato la 8P Sline del ragazzo di mia sorella...
VAG-COM Version: Release 704.1
Data version: 20070422
Thursday,01,May,2008,13:42:09:55371
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 7D
VIN: WAUZZZ8P54A065927 Mileage: 122880km/76354miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: None
Part No SW: 03G 906 016 G HW: 028 101 136 4
Component: R4 2,0L EDC 0000SG 5705
Coding: 0000072
Shop #: WSC 06435
3 Faults Found:
17075 - Fan 1 Control Circuit: Short to GND
P0691 - 000 - -
Freeze Frame:
RPM: 1890 /min
Torque: 150.0 Nm
Speed: 98.0 km/h
Load: 32.9 %
Voltage: 14.21 V
Bin. Bits: 11000000
Temperature: 87.3°C
Duty Cycle: 9.6 %
19558 - Motor for Intake Manifold Flap (V157): No Signal
P3102 - 000 - - - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.31 V
Bin. Bits: 00000100
Torque: 0.0 Nm
Torque: 354.0 Nm
18051 - Please check DTC Memory of Electric Load Controller
P1643 - 000 - - - Intermittent
Freeze Frame:
RPM: 1008 /min
Torque: 36.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.14 V
Bin. Bits: 11000000
Load: 44.3 %
(no units): 1.0
Readiness: 1 1 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.LBL
Part No: 1K0 907 379 D
Component: ESP FRONT MK60 0102
Coding: 0055942
Shop #: WSC 06435
No fault code found.
Address 08: Auto HVAC Labels: 8P0-820-043.LBL
Part No SW: 8P0 820 043 C HW: 8P0 820 043 C
Component: KlimavollautomatH11 0130
Address 09: Cent. Elect. Labels: 8P0-907-279.LBL
Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
Component: Bordnetz-SG 1.0 H29 0501
Coding: A588DF0082141000000000000000000000
Shop #: WSC 00000
Part No: 8P1 955 119
Component: Wischer WWS Audi350 0130
Coding: 16711696
Shop #: WSC 00000
Address 15: Airbags Labels: 8P0-959-655-84.LBL
Part No SW: 8P0 959 655 D HW: 8P0 959 655 D
Component: Airbag 8.4ED H00 0140
Coding: 0010602
Shop #: WSC 00841
Address 16: Steering wheel Labels: 1K0-953-549.LBL
Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
Component: Lenksäulenmodul 009 0030
Coding: 0000012
Shop #: WSC 06435
Address 17: Instruments Labels: 8P0-920-xxx-17.LBL
Part No SW: 8P0 920 930 F HW: 8P0 920 930 F
Component: KOMBIINSTR. VDO H25 0080
Coding: 0004103
Shop #: WSC 00001
Address 19: CAN Gateway Labels: 1K0-907-530.LBL
Part No SW: 1K0 907 530 B HW: 1K0 907 951
Component: Gateway H08 0090
Coding: 3D0F0B42070100
Shop #: WSC 06435
1 Fault Found:
01304 - Radio
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 254
Reset counter: 117
Mileage: 108617 km
Time Indication: 0
Date: 2007.11.09
Time: 19:56:57
Address 25: Immobilizer Labels: 1K0-920-xxx-25.LBL
Address 42: Door Elect, Driver Labels: None
Part No: 8P0 959 801
Component: Tuersteuerger. H10 0010
Coding: 0000120
Shop #: WSC 06435
1 Fault Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
008 - Implausible Signal - Intermittent
Address 44: Steering Assist Labels: 1Kx-909-14x.LBL
Part No: 1K1 909 144 D
Component: EPS_ZFLS Kl.10 1201
Address 46: Central Conv. Labels: 8P0-959-433.LBL
Part No: 8P0 959 433
Component: KSG H02 0040
Coding: 008800186D288505484AC67000
Shop #: WSC 06435
Part No: 1K0 951 605 A
Component: LIN BACKUP HORN H01 1201
Part No: 1K0 907 719
Component: Neigungssensor 002 0002
Part No: 8P0 951 177
Component: Innenraumueberw.H02 0010
1 Fault Found:
01565 - Luggage Compartment Light (W3)
007 - Short to Ground
Address 47: Sound System Labels: 8Px-035-382.LBL
Part No SW: 8P3 035 382 HW: 8P3 035 382
Component: AB2 SUBWOOFERBOXH23 0100
1 Fault Found:
02247 - Subwoofer (R148)
011 - Open Circuit
Freeze Frame:
Fault Status: 01111011
Fault Priority: 5
Fault Frequency: 35
Reset counter: 14
Mileage: 93677 km
Time Indication: 0
Date: 2007.04.06
Time: 19:15:04
Freeze Frame:
Temperature: 26.0°C
Raw, Form. N/A: 000 000 000
Address 52: Door Elect, Pass. Labels: None
Part No: 8P0 959 802
Coding: 0000120
Shop #: WSC 06435
Address 56: Radio
Cannot be reached
Address 7D: Aux. Heat Labels: 1K0-963-235.LBL
Part No SW: 1K0 963 235 C HW: 1K0 963 235 C
Component: PTC-Element 0404
End --------------------------------------------------------------------------------------------------
sapete dirmi gli errori a cosa si riferiscono (premetto che gli resta accesa la spia della centralina anche...)
