Ciao ragga...chi sa, che c"e sul Adaptation canale 13 della centralina motore del Audi A3 1.6 AKL benzina del *99, e che cosa modifica. Grazie 1000.
spostato in sezione corretta
io nel mio vag (che non e' aggiornatissimo, modello 2011 credo) ho trovato questo file "label" per il motore AKL, in produzione negli anni 1999 e 2000.
faccio copia e incolla, io ci capisco poco di label e adaptation. ciao!
; VAG-COM label file
; Seat Ibiza/Cordoba (6K) / Seat Leon/Toledo (1M) / Skoda Octavia (1U) / VW Golf/Jetta (1J)
; component: Engine (#01) - AEH/AKL
; p/n: 06A 906 019 ???
; includes measuring blocks and coding
; This file is part of a redirection package,
; make sure you have all of the following files.
; 06-01.LBL
; 6K-01.LBL
; 06A-906-019-AEH.LBL (1.6l E @ 100 HP - AEH/AKL)
; created on 09/Oct/2003 by Kim Andersen ([email protected])
; updated/enhanced on 19/Apr/2005 by Sebastian Stange ([email protected])
; ready for VAG-COM 405.0 and above
; coding information
C0,Engine Control Unit Coding
C1,AEH/AKL (< MY 1999)
C2,04000 - Manual Transmission
C3,04030 - Automatic Transmission
C4,
C5,AEH/AKL (MY 2000 >)
C6,000?x - CAN-Databus
C7,0 - without data bus
C8,1 - ABS with data bus
C9,2 - Airbag with data bus
C10,3 - ABS and Airbag with data bus
C11,
C12,000x? - Transmission
C13,1 - 5-Speed Manual Transmission
C14,3 - Automatic Transmission
; measuring block information
000,0,Basic Functions (Decimal Values)
000,1,Intake Air Temperature,Specification: 84...158 (15...71 °C)
000,2,Supply Voltage,Specification: 98...147 (10...15 V)
000,3,Coolant Temperature,Specification: 170...211 (80...110 °C)
000,4,Injected Quantity,Specification: 14...30 (76...164 mg/lift)
000,5,Lambda Voltage,Specification: 0...50 (0.0...1.0 V)
000,6,Lambda Learning Value,Specification: 0...100 (-0.8...+0.8 ms)
000,7,Operation Condition,see measuring block 99
000,8,Throttle Valve Angle,Specification: 4...12 (1.9...5.7 °<)
000,9,Injection Period,Specification: 2...4 (2.0...4.1 ms)
000,10,Engine Speed,Specification: 23...27 (760...880 RPM)
001,0,Basic Functions
001,1,Engine Speed,,Specification: 760...880 RPM
001,2,Coolant,Temperature,Specification: 80.0...110.0 °C
001,3,Lambda,Voltage,Specification: 0.00...1.00 V
001,4,Basic Setting,Requirements,Specification: 00000010
; xxxxxxx1 - Coolant temperature below 80 °C
; xxxxxx1x - Engine speed below 2000 RPM
; xxxxx1xx - Throttle valve closed
; xxxx1xxx - Lambda regulation correct
; xxx1xxxx - State of idle
; xx1xxxxx - A/C system compressor deactivated
; x1xxxxxx - Signal from automatic transmission
; 1xxxxxxx - Fault identified by self-diagnosis
002,0,Basic Functions
002,1,Engine Speed,,Specification: 760...880 RPM
002,2,Injected,Quantity,Specification: 76...164 mg/H
002,3,Vehicle Speed,,Specification: 0 km/h
002,4,Operating,Condition,Specification: 0100
; 1xxx - Overrun
; x1xx - Idling
; xx1x - Part throttle
; xxx1 - Full throttle
003,0,Basic Functions
003,1,Engine Speed,,Specification: 760...880 RPM
003,2,Injected,Quantity,Specification: 76...164 mg/H
003,3,Throttle Valve,Angle,Specification: 1.9...5.7 °
003,4,Throttle Valve,Positon Duty Cycle,Specification: -100...+100 %
004,0,Basic Functions
004,1,Engine Speed,,Specification: 760...880 RPM
004,2,Injected,Quantity,Specification: 76...164 mg/H
004,3,Injection,Period,Specification: 2.0...4.10 ms
004,4,Intake Air Mass,,Specification: 1.8...3.2 g/s
005,0,Basic Functions
005,1,Engine Speed,,Specification: 760...880 RPM
005,2,Voltage Supply,,Specification: 10...15 V
005,3,Coolant,Temperature,Specification: 80.0...110.0 °C
005,4,Intake Air,Temperature,Specification: 15...71 °C
006,0,Altitude Adaptation
006,1,Engine Speed,,Specification: 760...880 RPM
006,2,Injected,Quantity,Specification: 76...164 mg/H
006,3,Throttle Valve,Angle,Specification: 1.9...5.7 °
006,4,Altitude,Correction Factor,Specification: 0.9...1.1
007,0,Idling Adjustment
007,1,Throttle Valve,Angle,Specification: 1.9...5.7 °
007,2,Idling control,learnt value,manual gearbox in neutral/automatic gearbox selector lever in P or N (Specification: 0.95...1.05)
007,3,Idling control,learnt value,automatic gearbox with gear selected (Specification: 0.95...1.05)
007,4,Operating,Condition,Specification: 0100
; 1xxx - Overrun
; x1xx - Idling
008,0,Idling Stabilitation
008,1,Engine Speed,(actual),Specification: 760...880 RPM
008,2,Engine Speed,(specified),Specificatoin: 800...840 RPM
008,3,Idling Control,,Specification: -10...+15 %
008,4,Intake Air Mass,,Specification: 1.8...3.2 g/s
009,0,Idling Air Requirements
009,1,Idling,Control,Specification: -10...+15 %
009,2,Throttle Valve,Status,Specification: 00000000
; ----1xxx - Malfunction recorded during TBA
; ----x1xx - No current supply to throttle valve control part
; ----xx1x - Adaptation interrupted due to battery voltage beeing to low (below 8V)
; ----xxx1 - Idle switch open
009,3,Coolant,Temperature,Specification: 80.0...110.0 °C
009,4,Engine Speed,,Specification: 760...880 RPM
010,0,Lambda Control and activated Charcoal Filter System
010,1,Lambda,Regulation,Specification: -25.0...+25.0 %
010,2,Lambda Probe,Voltage,Specification: 0.00...1.00 V
010,3,Activated Charcoal,Valve 1 Duty Cycle,Specification: 0.0...20.0 %
010,4,Lambda Correction,Tank Venting active,Specification: -20.0...+2.0 %
011,0,Lambda Learning Values
011,1,Injection,Period,Specification: 2.00...4.10 ms
011,2,Lambda learnt,Value (idling),Specification: -0.1...+1.0 ms
011,3,Lambda learnt,Value (part load),Specification: 0.9...1.15 ms
011,4,Cond.tank, breather valve,see label file
; -1xxxxxx - Transition to vapour content check via fuel tank breather valve
; -x1xxxxx - Transition to fuel tank breather valve minimum operating level
; -xx1xxxx - Transition to fuel tank breather valve closure
; -xxx1xxx - Vapour content check via fuel tank breather valve
; -xxxx1xx - Fuel tank breather valve operating normally
; -xxxxx1x - Fuel tank breather valve minimum operating level
; -xxxxxx1 - Fuel tank breather valve closed
012,0,Lambda Control
012,1,Engine Speed,,Specification: 760...880 RPM
012,2,Injected,Quantity,Specification: 76...164 mg/H
012,3,Lambda,Regulation,Specification: -25...+25 %
012,4,Lambda Probe,Voltage,Specification: 0.00...1.00 V
013,0,Fuel Consumption
013,1,Engine Speed,,Specification: 760...880 RPM
013,2,Injected,Quantity,Specification: 76...164 mg/H
013,3,Vehicle Speed,,Specification: 0 km/h
013,4,Fuel Consumption,,Specification: 0.50...2.00 l/h
014,0,Ignition (Knock Control - Cyl 1 - 4)
014,1,Cylinder 1 Ignition,Angle Delay,Specification: 0.0 °CA
014,2,Cylinder 2 Ignition,Angle Delay,Specification: 0.0 °CA
014,3,Cylinder 3 Ignition,Angle Delay,Specification: 0.0 °CA
014,4,Cylinder 4 Ignition,Angle Delay,Specification: 0.0 °CA
015,0,Ignition (Knock Control - Cyl 1 && 2)
015,1,Engine Speed,,Specification: 760...880 RPM
015,2,Injected,Quantity,Specification: 76...164 mg/H
015,3,Cylinder 1 Ignition,Angle Delay,Specification: 0.0 °CA
015,4,Cylinder 2 Ignition,Angle Delay,Specification: 0.0 °CA
016,0,Ignition (Knock Control - Cyl 3 && 4)
016,1,Engine Speed,,Specification: 760...880 RPM
016,2,Injected,Quantity,Specification: 76...164 mg/H
016,3,Cylinder 3 Ignition,Angle Delay,Specification: 0.0 °CA
016,4,Cylinder 4 Ignition,Angle Delay,Specification: 0.0 °CA
017,0,Ignition (Knock Control - Knock Sensor Voltages)
017,1,Cylinder 1,Knock Sensor,Specification: 0.400...1.300 Vpt
017,2,Cylinder 2,Knock Sensor,Specification: 0.400...1.300 Vpt
017,3,Cylinder 3,Knock Sensor,Specification: 0.400...1.300 Vpt
017,4,Cylinder 4,Knock Sensor,Specification: 0.400...1.300 Vpt
018,0,Torque Reduction for Automatic Transmission
018,1,Engine Speed,,Specification: 760...880 RPM
018,2,Injected,Quantity,Specification: 76...164 mg/H
018,3,Ignition Timing,Retardation,Specification: 0.0 °CA
018,4,Ignition,Timing,Specification: -6...+14 °BTDC
019,0,Operation Condition
019,1,Engine Speed,,Specification: 760...880 RPM
019,2,Selector Lever,Position,Display Range: 0 = Neutral / 1 = Gear Selected | Specification: 0
019,3,Air Conditioner,,Display Range: 0 = Air conditioner off / 1 = Air conditioner on | Specification: 0
019,4,Operation,Condition,Specification: 00000000
; -----1xx - Clutch pedal switch operated
; -----x1x - Power steering pressure switch F88 activated
; -----xx1 - A/C compressor switched on
020,0,Lambda Control Operating Condition
020,1,Engine Speed,,Specification: 760...880 RPM
020,2,Injected,Quantity,Specification: 76...164 mg/H
020,3,Coolant,Temperature,Specification: 80...110 °C
020,4,Operation,Condition
; 1--xxxxx - Malfunction recorded during diagnoses
; x--1xxxx - Restricted operating mode
; x--x1xxx - Lambda control at stop limit
; x--xx1xx - Lambda control switched on
; x--xxx1x - Lambda probe functioning
; x--xxxx1 - Mixture status (1 = rich mixture/0 = lean mixture)
021,0,Throttle Valve Control Adaption
021,1,Throttle Valve,Control Adaption,Specification: 00000000
021,2,Throttle Valve,(min. position),Specification: 70...100 %
021,3,Throttle Valve,(emerg. run. pos.),Specification: 67...100 %
021,4,Throttle Valve,(max. position),Specification: 0...20 %
022,0,Ignition (Position of Camshaft vs. Crankshaft)
022,1,Engine Speed,,Specification: 760...880 RPM
022,2,Injected,Quantity,Specification: 76...164 mg/H
022,3,Crankshaft Tooth,(low > high),No. of crankshaft tooth at camshaft flank (Specification: 26...30)
022,4,Crankshaft Tooth,(high > low),No. of crankshaft tooth at camshaft flank (Specification: 86...90)
057,0,Idling Speed Stabilisation
057,1,Engine Speed,,Specification: 760...880 RPM
057,2,Engine Speed,(specified),Specification (A/C Low): 760...880 RPM | Specification (A/C High): 800...920 RPM
057,3,A/C Compressor,,Display Range: Compr. ON/Compr. OFF
057,4,Duty Cycle,Pressure Sensor,G65 | Specification (A/C Low): 1...5 % | Specification (A/C High): 10...70 %
066,0,Cruise Control System (CCS/GRA)
066,1,Actual,Vehicle Speed
066,2,Brake switch,clutch and CCS,Specification: 0000/0011
; 1xxx - Cruise control system active
; x1xx - Clutch depressed (always 1 in automatic transmission)
; xx1x - Brake depressed (brake pedal switch)
; xxx1 - Brake depressed (brake light switch)
066,3,Specified,Vehicle Speed
066,4,CCS Control,Positions,Specification: 0000/0011
; 1xxx - CCS slide handle on RES or RES button on multi-function steering wheel pressed
; x1xx - SET button pressed
; xx1x - CCS slide handle on OFF (not engaged or engaged)/OFF button on multi-function steering wheel pressed
; xxx1 - CCS slide handle on OFF
098,0,Speed Regulation (Basic Setting: Throttle Body Adaptation)
098,1,Throttle Drive,Angle Sensor 1,for EPC (G187) | Specification:
098,2,Throttle Drive,Angle Sensor 2,for EPC (G188) | Specification:
098,3,Operating,Condition,Specification: 00000000
098,4,Matching,Condition,Specification: 00
; 1x - Malfunction recorded during matching
; x1 - Throtte valve control is beeing matched
099,0,Lambda Regulation (Basic Setting)
099,1,Engine Speed,,Specification: 760...880 RPM
099,2,Coolant,Temperature,Specification: 80...110 °C
099,3,Lambda Regulator,,Specification: -25.0...+25.0 %
099,4,Lambda,Operating Condition,Specification: 0xxx011x
