Ciao a tutti
Dopo aver acquistato qui sul forum il cavo VAG, ho fatto la mia prima scansione per vedere se c'erano errori o problemi, e mi è saltato fuori questo errore... Qualcuno saprebbe gentilmente dirmi di cosa si tratta?
Allego la scansione del Vag:
Chassis Type: 8K (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 42 44 46 52 53 56 5F 62 72
VIN: WAUZZZ8K0EA021548 Mileage: 28300km/17584miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CJCD) Labels: None
Part No SW: 03L 906 018 SK HW: 03L 906 018 JL
Component: R4 2,0L EDC H25 5229
Revision: 45H25---
Coding: 12034012232401080000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM20TDI01103L906018SK 003002
ROD: EV_ECM20TDI01103L906018JJ.rod
VCID: 8501F79F04D47D36275-80D0
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J217) Labels: 0AW-927-156.clb
Part No SW: 8K5 927 155 K HW: 0AW 927 156 K
Component: 0AW 20TDI RdW H05 0001
Revision: --H05--- Serial number: 0000000882
Coding: 000002
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMVL381 A02433
ROD: EV_TCMVL381.rod
VCID: 408FA68BDB76181ED43-8015
Address 03: ABS Brakes
Cannot be reached
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 GD HW: 8K0 907 064 FD
Component: BCM2 2.0 H12 0633
Revision: 00002001
Coding: 01A24000000000000000
VCID: 78FF0E6BCB2690DEAC3-802D
Subsystem 1 - Part No SW: 8K0 959 754 H HW: 8K0 959 754 H
Component: FBSAUDIB8 IDG H71 0083
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 8K1 820 043 AJ HW: 8K1 820 043 AJ
Component: KLIMA 3 ZONEN H04 0121
Revision: C1000000 Serial number: 01210620131794
Coding: 342002E000
VCID: 70EF364BA356C89E643-8025
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00000633547301
Coding: 260000108034AFC00081400300001D0D0F1C47082609020100 0008004401020100000024000000
Subsystem 1 - Part No SW: 8K1 955 119 B HW: 8K1 955 119 B
Component: MITSUBA130613 H18 0461
Coding: 004577
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B
Component: G397_RLFS H06 0002
Coding: 02005D
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
Component: AirbagVW-AU10 H47 0610
Serial number: 003KFDB0FLHT
Coding: 30524235363030303030554A304C384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 489FBEABF346205E1C3-801D
Crash sensor for side airbag; driver side:
Serial number: 6334MSME7C244627H
Crash sensor for side airbag; passenger side:
Serial number: 6344MSME79562948O
Crash sensor for side airbag; rear driver side:
Serial number: 6352QSME44484558J
Crash sensor for side airbag; rear passenger side:
Serial number: 6362QSME74332744C
Crash sensor for front airbag; driver side:
Serial number: 63732SME173A0E6EB
Crash sensor for front airbag; passenger side:
Serial number: 63832SME173A374E6
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8R0 953 568 Q HW: 8R0 953 568 Q
Component: Lenks.Modul H02 0171
Revision: 00000000 Serial number: 20130626000290
Coding: 000017
VCID: 4FAD95B71E28F7665D9-801A
Component: E221 - MFL H03 0004
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 932 HW: 8K0 920 932
Component: KOMBIINSTR. H35 0563
Revision: 00500000 Serial number: WWD677F6E
Coding: 13AF10000301000C000000
Shop #: WSC 06325 123 12345
VCID: ECD7A23B0F7EAC7ED8B-80B9
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8R0 907 468 N HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H11 0056
Revision: 1Y070028 Serial number: 2841Y13614009B
Coding: 80CF07FF00
VCID: 4A9B84A3E54AD24E0A7-801F
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 R HW: 8K0 959 793 P
Component: TSG FA H02 0508
Revision: Serial number: 0000064598249
Coding: 011C02204000410001
Address 44: Steering Assist (J500) Labels: 8K0-909-144.clb
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H37 0507
Revision: 00001000 Serial number: 0016590294
Coding: 100000000001
Shop #: WSC 06324 000 00000
ASAM Dataset: EV_RCEPSAU48X 008014
ROD: EV_RCEPSAU48X.rod
VCID: 3467FA5B9FCEB4BE40B-8061
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0310292249
Coding: 0100062820B900008320023680000047
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 R HW: 8K0 959 792 P
Component: TSG BF H02 0508
Revision: Serial number: 0000065396668
Coding: 011C02204C00410001
VCID: 4E9388B31922FE6E56F-801B
Address 53: Parking Brake (----) Labels: None
Part No SW: 8K0 907 801 M HW: 8K0 907 801 J
Component: EPB-4 H01 0004
Revision: -------- Serial number: 00000001327682
ASAM Dataset: EV_ParkiBrake 001028
ROD: EV_ParkiBrake_AU48.rod
VCID: 3979CB6FB8AC49D693D-806C
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G0 035 056 J HW: 4G0 035 056
Component: Radio U STD H60 0133
Revision: AB001007 Serial number: 230FN0D2819021
Coding: 010003020100000001
VCID: 285F1E2B5B06C05EFC3-807D
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8R1 035 670 F HW: 8R1 035 670 C
Component: H-BNT-EU H46 0739
Revision: -------- Serial number: 207F+0D7553296
Coding: 0F0100010006A1ED01808B5E00000403040000000000000000
VCID: 3663C05381B2A6AE7EF-8063
Subsystem 1 - Part No: 8R0 060 884 BC
Component: EUR 2013/2014 1603
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Subsystem 3 - Part No SW: 8T0 919 611 K HW: 8T0 919 611 B
Component: E0380 Bedient H02 0030
Subsystem 4 - Part No: 8R0 060 961 F
Component: CD-Database 5298
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0506
Revision: Serial number: 0000065924896
Coding: 010C02204000210001
VCID: 4683B093F152362EEEF-8013
Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
Component: TSG HR H01 0506
Revision: Serial number: 0000065924898
End ---------------------------------------------------------------------
Grazie a tutti!
