Buona domenica a tutti! Come da titolo ho eseguito la mia prima autodiagnosi e come si può leggere tutto è risultato regolare, tranne che per il modulo 5F-Information Electr. -- Status: Malfunction 0010, nel dettaglio mi dice Fault Found: 03276 - Please Check Software Version Management. Ora apparentemente non mi risulta e ne mi viene segnalata alcuna anomalia o malfunzionamento, da cosa può dipendere??? Mi devo preoccupare?
Sunday,08,May,2011,11:45:45:60804
VCDS Version: Release 10.6.0
Data version: 20100630
Chassis Type: 8T0
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 47 52 53 55 56 5F 62
72
VIN: WAUZZZ8K7AA070983 Mileage: 34000km/21126miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CCWA) Labels: 059-907-401-CAP.clb
Part No SW: 8R0 907 401 J HW: 8K1 907 401 A
Component: 3.0TDI EDC17 H02 0008
Revision: 15H02---
Coding: 0124002C240F0020
Shop #: WSC 00558 264 80683
ASAM Dataset: EV_ECM30TDI0118R0907401J 001008
ROD: EV_ECM30TDI0118R0907401J.rod
VCID: 3972A8120931
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J217) Labels: 0B5-927-156.clb
Part No SW: 8K0 927 156 J HW: 0B5 927 156 E
Component: 0B5 30 TDIRdW H03 0009
Revision: --H03--- Serial number: 0000000799
Coding: 000001
Shop #: WSC 06335 000 00000
ASAM Dataset: EV_TCMDL501 A02044
ROD: EV_TCMDL501.rod
VCID: 3B7EB21A030D
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 8K9 907 379 F HW: 8K9 907 379 F
Component: ESP8 quattro H06 0010
Revision: -------- Serial number: --------------
Coding: 084508
VCID: 458AD4E275C9
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP
Component: BCM2 1.1 H02 0326
Revision: 00002001
Coding: 010200
VCID: 810280F2A161
Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 AP HW: 8T1 820 043 AP
Component: KLIMA 3 ZONEN H08 0171
Revision: C0000000 Serial number: 01101020090757
Coding: 36100000
VCID: 7F06860A5795
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 N HW: 8K0 907 063 N
Component: BCM1 1.0 H25 0380
Revision: 09025001 Serial number: 00000000359894
Coding: 260050914134AF010001000000001D0D0F1C47080001014100 0000
Shop #: WSC 30486 264 82831
VCID: 3A70B71E0C37
Part No SW: 8K1 955 119 A HW: 8T1 955 119
Component: WWS 071009 H06 0070
Coding: 00FD11
Part No SW: 8K0 955 559 HW: 8K0 955 559
Component: RLS H04 0003
Coding: 025028
Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 J HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0050
Revision: 11001001 Serial number: 39830928502845
Coding: 100104
VCID: 4084C5F66AEB
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 G HW: 8K0 959 655 G
Component: AirbagVW-AU10 H39 0560
Serial number: 003EFD069V9E
Coding: 30343435363030303030554A304C384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 4182C0F261E1
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90304IJ6000KA
Coding: 000033
VCID: 3D7ABC021D19
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 930 D HW: 8K0 920 930 D
Component: KOMBIINSTR. H20 0255
Revision: 00000000 Serial number: CIY26A4A9
Coding: 0F0E290202000008040000
VCID: 2E588B4EC07F
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 T HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0105
Revision: EB800053 Serial number: 5300E09A050099
Coding: 00C303
VCID: 52A0FFBEB487
Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H06 0170
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
Component: TSG FA H11 0306
Revision: Serial number: 0000009436984
Coding: 011C02205000410001
VCID: 458AD4E275C9
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0121949710
Coding: 01000620203904800120020000000000
VCID: 810280F2A161
Address 47: Sound System (J525) Labels: 8T0-035-223-BOM.clb
Part No SW: 8T0 035 223 AK HW: 8T0 035 223 AK
Component: DSP Prem H08 0170
Revision: 00008001 Serial number: 34881005633803
VCID: 77F66E2A7FA5
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
Component: TSG BF H11 0306
Revision: Serial number: 0000009452245
VCID: 448CC9E67EF3
Address 53: Parking Brake (J540) Labels: 8K0-907-801.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000000468167
Shop #: WSC 00000 000 00000
VCID: 346C99262E53
Address 55: Xenon Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000004
Shop #: WSC 06334 000 00000
VCID: F7F6EE2AFFA5
Address 56: Radio (R) Labels: None
Part No SW: 4F0 035 053 B HW: 4F0 035 053
Component: Radio U Basic H45 0020
Revision: AB001007 Serial number: 341JV097651424
Coding: 010003010000000001
VCID: 1C3C5186A6C3
Address 5F: Information Electr. (J794) Labels: Redir Fail!
Part No SW: 8T1 035 666 D HW: 8T1 035 666 D
Component: H-BN-EU H47 0047
Revision: -------- Serial number: 483L$09B001529
Coding: 01010001000681ED01000F1E000000010000
VCID: 3B7EB21A030D
Part No: 8R0 060 884 E
Component: EUR 2009/2010 5805
Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Part No SW: 8T0 919 609 F HW: 8T0 919 609 F
Component: E0380 Bedient H08 0100
1 Fault Found:
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 37
Mileage: 34004 km
Time Indication: 0
Date: 2011.05.08
Time: 11:39:11
Freeze Frame:
Voltage: 12.30 V
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
Component: TSG HL H10 0306
Revision: Serial number: 0000102061929
Coding: 010C02204000210001
VCID: 4280CFFE64E7
Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
Component: TSG HR H10 0306
Revision: Serial number: 0000102061930
VCID: 4280CFFE64E7
End ---------------------------------------------------------------------
