Analisi dei risultati del VAG
VAG-COM Version: Release 311.2-N
Chassis Type: 4B - Audi A6 C5
Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56
Address 01 -------------------------------------------------------
Controller: 8E0 907 401 P
Component: 2.5l/4VTEDC G000AG D14
Coding: 01017
Shop #: WSC 02325
00006059 130 106JC150_1.V79972673381
2 Faults Found:
01441 - Low Fuel Level Sensor (G210)
30-10 - Open or Short to B+ - Intermittent
27-10 - Implausible Signal - Intermittent
Readiness: N/A
Address 02 -------------------------------------------------------
Controller: 4B1 910 156 D
Component: V30 01J 2.5lTDI RdW 3410
Coding: 00001
Shop #: WSC 04926
No fault code found.
Address 03 -------------------------------------------------------
Controller: 4B0 614 517 G
Component: ABS/ESP front 1728
Coding: 06399
Shop #: WSC 02325
Address 08 -------------------------------------------------------
Controller: 4B0 820 ö4B
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 4B0 920 933 M
Component: KOMBI+WEGFAHRS. VDO D12
Coding: 00560
Shop #: WSC 01992
WAUZZZ4B83N079533 AUZ7Z0B2295681
Address 35 -------------------------------------------------------
Controller: 4B0 962 258 N
Component: Zentralverrieg.,DWA D37
Coding: 06987
Shop #: WSC 02325
3 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01134 - Alarm Horn (H12)
49-10 - No Communications - Intermittent
Address 37 -------------------------------------------------------
Controller: 4B0 035 192 K
Component: RNS 4.2 H06 BNO 0105
Address 45 -------------------------------------------------------
Controller: 4B0 951 178 A
Component: Innenraumueberw. D04
Coding: 00101
Shop #: WSC 02325
Address 55 -------------------------------------------------------
Controller: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00040
Shop #: WSC 02325
Address 56 -------------------------------------------------------
Component: Radio BNO 0001
Coding: 00207
Shop #: WSC 00152
End -------------------------------------------------------
AUDI A6 2.5 TDI V6 Full Optional
Navigatore-Fari Xeno-Sedili Elettrici-Clima-Interni Pelle-Multitronic
