Fault code di oggi
Ecco i fc's dopo una lieve tirata.
Friday,31,October,2008,19:21:24:55700
VCDS Version: Release 805.1
Address 01: Engine
Control Module Part Number: 8E1 910 560
Component and/or Version: 4.2L V8/4V FSI ª0080
Software Coding: 01040003180F0160
Work Shop Code: WSC 00155
11 Faults Found:
012312 - Valve for Exhaust Flap 1 (N321): Short to Ground
P3018 - 002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 4
Mileage: 40199 km
Time Indication: 0
Freeze Frame:
RPM: 300 /min
Load: 74.1 %
Speed: 0.0 km/h
Temperature: 101.0°C
Temperature: 68.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 10.795 V
001112 - Evap System Purge Control Valve (N80): Short to Ground
P0458 - 002 - Lower Limit Exceeded
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 40199 km
Time Indication: 0
Freeze Frame:
RPM: 300 /min
Load: 74.1 %
Speed: 0.0 km/h
Temperature: 68.0°C
Voltage: 10.795 V
008201 - Intake Manifold Flap; Bank 1: Short to Ground
P2009 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 4
Mileage: 40199 km
Time Indication: 0
Freeze Frame:
RPM: 300 /min
Load: 74.1 %
Speed: 0.0 km/h
Temperature: 68.0°C
Voltage: 10.795 V
004199 - Intake Air Switch-Over Valve (N335): Short to Ground
P1067 - 002 - Lower Limit Exceeded
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 40199 km
Time Indication: 0
Freeze Frame:
RPM: 300 /min
Load: 74.1 %
Speed: 0.0 km/h
Temperature: 68.0°C
Voltage: 11.684 V
005173 - Secondary Air Pump Relay (J299): Short to Ground
P1435 - 002 - Lower Limit Exceeded
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 40199 km
Time Indication: 0
Freeze Frame:
RPM: 300 /min
Load: 74.1 %
Speed: 0.0 km/h
Temperature: 68.0°C
Voltage: 11.684 V
005153 - Secondary Air Injection Solenoid Valve (N112): Short to Ground
P1421 - 002 - Lower Limit Exceeded
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 40199 km
Time Indication: 0
Freeze Frame:
RPM: 300 /min
Load: 74.1 %
Speed: 0.0 km/h
Temperature: 68.0°C
Voltage: 11.684 V
005494 - Right Engine Mount Solenoid Valve (N145): Short to Ground
P1576 - 002 - Lower Limit Exceeded
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 40199 km
Time Indication: 0
Freeze Frame:
RPM: 300 /min
Load: 74.1 %
Speed: 0.0 km/h
Temperature: 68.0°C
Voltage: 11.684 V
000135 - Fuel Rail/System Pressure: Too Low
P0087 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 40253 km
Time Indication: 0
Freeze Frame:
RPM: 867 /min
Load: 25.9 %
Speed: 0.0 km/h
Temperature: 44.0°C
Temperature: 32.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.970 V
000049 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit: Short to Ground
P0031 - 002 - Lower Limit Exceeded
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Mileage: 40253 km
Time Indication: 0
Freeze Frame:
RPM: 737 /min
Load: 34.9 %
Speed: 0.0 km/h
Temperature: 60.0°C
Voltage: 13.716 V
000055 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit: Short to Ground
P0037 - 002 - Lower Limit Exceeded
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Mileage: 40254 km
Time Indication: 0
Freeze Frame:
RPM: 737 /min
Load: 34.9 %
Speed: 0.0 km/h
Temperature: 60.0°C
Voltage: 13.716 V
008853 - Fuel Pressure Regulator Valve (N276): Short to Ground
P2295 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 40278 km
Time Indication: 0
Freeze Frame:
RPM: 1500 /min
Load: 24.7 %
Speed: 0.0 km/h
Temperature: 68.0°C
Voltage: 11.938 V
Readiness: 0000 0000
Idee? Sono errori frequenti.
Inoltre ho notato la spia epc rimanere accesa per qualche minuto dopo un riavvio a motore caldo e poi scomparire.
Con la spie epc accesa l'auto sopra i 4k giri strappa.
Ultima modifica di Daniele; 31-10-2008 alle 19:27
Motivo: Unione automatica messaggi multipli
Utente
![Wub](images/smilies/sm/wub1.gif)
i miei cagnoni..
