Risultati da 1 a 9 di 9
Discussione: RISULTATI DIAGNOSI...chi mi da una mano?
    Audi lover L'avatar di CHECCOA3
    A3 1.8T
    Predefinito RISULTATI DIAGNOSI...chi mi da una mano?
    Ragazzi ho vaggato la mia A3ed ecco i risultati (nn so dove mettermi le mani):
    VAG-COM Version: Release 311.2-N
    Chassis Type: 8L - Audi A3/S3
    Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
    Address 01 -------------------------------------------------------
    Controller: 06A 906 018 CJ
    Component: 1.8L R4/5VT MOTR HS D01
    Coding: 04000
    Shop #: WSC 06435
    2 Faults Found:
    16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
    P0116 - 35-10 - - - Intermittent
    00561 - Mixture Adaptation
    14-10 - Adaptation Limit (Add) Exceeded - Intermittent
    Readiness: N/A
    Address 03 -------------------------------------------------------
    Controller: 1J0 907 379 Q
    Component: ABS/EDS 20 IE CAN 0001
    Coding: 13504
    Shop #: WSC 06435
    No fault code found.
    Address 08 -------------------------------------------------------
    Controller: 8L0 820 043 M
    Note: Excessive Comm Errors (nn so che si ma mi mette paura)
    Skipping Address 15-Airbags
    Address 17 -------------------------------------------------------
    Controller: 8L0 920 900 C
    Component: AB-KOMBIINSTR. VDO D11
    Coding: 00144
    Shop #: WSC 00000
    ˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙ AUZ7Z0X1280778
    Address 35 -------------------------------------------------------
    Controller: 8L0 862 257 G
    Component: ZV-Pumpe, DWA, Funk D11
    Coding: 13130
    Shop #: WSC 06435
    5 Faults Found:
    01374 - Alarm triggered by Terminal 15
    35-00 - -
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    01368 - Alarm triggered by Luggage Compartment Switch
    35-00 - -
    00991 - Interior Lights
    28-00 - Short to B+
    00956 - Key 2
    09-00 - Adaptation Limit Surpassed
    Address 45 -------------------------------------------------------
    Controller: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00001
    Shop #: WSC 00000
    End -------------------------------------------------------
    Sapete come si azzerano tutti gli errori?? Perkè stavo pensando che sicuramente da anni nn è stata fatta una diagnosi però vari pezzi sono stati sostituiti perciò vorrei praticamente iniziare da capo che ne dite?
    Audi lover L'avatar di M1rkoA3
    Audi A3 8L
    DEVI ENTARRE SU OGNI SINGOLO CANALE, QUANDO VEDI GLI ERRORI FAI CLEAR E SI AZZERANO....
    A3 8L 1.9 TDI 130 CV, Blu notte metallizzato, Cerchi "17 - Pinze rosse, Molle H&R - Antifurto GT, Particolari interni S3.
    A3 1.8T
    ciao mirko grazie mille ho provato e funziona, prima clikkavo il clear a fine diagnosi ma cancellava semplicemente i risultati dalla schermata ma nn dalla centralina...
    Audi A3 8L
    esatto...bene..
    ora dopo un pò di strada prova a rivaggare e posa i risultati, vediamo quali sono i "buoni"...
    Audi lover L'avatar di lyodf
    AUDI A4 b8 Avant 2.0 TDI 143 Multitronic Advanced
    Citazione Originariamente Scritto da M1rkoA3 Visualizza Messaggio
    esatto...bene..
    Mirko... mi stupisco sempre più di teeeeee.....
    Sei diventato uno dei massimi esperti in Italia di VAG oramai...
    Enrico
    A4 Avant 2.0 TDI 143 Multitronic Advanced 2008 quasi full
    Work in progress...
    Audi lover L'avatar di Maga84
    Sondrio (SO)
    Audi A3 8P 2.0 TDI 140@170cv
    Altrimenti per cancellarli tutti in una sola volta, basta andare in "applications" e cliccare su "erase all error" una cosa simile, adesso non avendolo sotto mano, non ricordo bene cosa ci sia scritto.
    Comunque è l'ultimo pulsante in alto a destra, lo cliccate e cancella tutto.
    Ciao
    Mastaro Fans Club Socio -84-
    Cristian - A3 8P 2.0 TDI 140cv 16V - Bose Sound System - Nero brillante - Assetto eibach B8 + Sportline -50mm
    A3 1.8T
    grazie mille a tutti.... ora sto facendo un po di km per poi rivaggarla... cmq mi sono andato a cercare i codici su **** e ciò che mi preoccupa è solo l'errore della centralina del motore, gli altri 2 sono della centralina delle chiusura centralizza e del climatizzatore... almeno suppongo... nn so se sono giusti
    Audi A3 8L
    quelli della chiusura centralizz su che modulo sono?
    Vediamo se è lo stesso per far la modifica della chiusura porte a 15km/h...
    P.S: Enrico grazie dei complimenti ma mi ritengo ancora un principiante.... Lo uso molto poco ma son stato felice di aver visto che funziona la chiura automatica delle porte...
    A3 1.8T
    dovrebbe essere il 35... io purtroppo nn la posso utilizzare quella funzione perkè nn ho il computer di bordo...
    mi pare che quello della chiusura automatica è il 42....
