Risultati da 1 a 3 di 3
Discussione: Fault code di oggi
    Regno Unito
    Audi RS6
    Predefinito Fault code di oggi
    Ecco i fc's dopo una lieve tirata.
    Friday,31,October,2008,19:21:24:55700
    VCDS Version: Release 805.1
    Address 01: Engine
    Control Module Part Number: 8E1 910 560
    Component and/or Version: 4.2L V8/4V FSI ª0080
    Software Coding: 01040003180F0160
    Work Shop Code: WSC 00155
    11 Faults Found:
    012312 - Valve for Exhaust Flap 1 (N321): Short to Ground
    P3018 - 002 - Lower Limit Exceeded
    Freeze Frame:
    Fault Status: 01100010
    Fault Priority: 0
    Fault Frequency: 4
    Mileage: 40199 km
    Time Indication: 0
    Freeze Frame:
    RPM: 300 /min
    Load: 74.1 %
    Speed: 0.0 km/h
    Temperature: 101.0°C
    Temperature: 68.0°C
    Absolute Pres.: 1010.0 mbar
    Voltage: 10.795 V
    001112 - Evap System Purge Control Valve (N80): Short to Ground
    P0458 - 002 - Lower Limit Exceeded
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 4
    Mileage: 40199 km
    Time Indication: 0
    Freeze Frame:
    RPM: 300 /min
    Load: 74.1 %
    Speed: 0.0 km/h
    Temperature: 68.0°C
    Voltage: 10.795 V
    008201 - Intake Manifold Flap; Bank 1: Short to Ground
    P2009 - 002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 0
    Fault Frequency: 4
    Mileage: 40199 km
    Time Indication: 0
    Freeze Frame:
    RPM: 300 /min
    Load: 74.1 %
    Speed: 0.0 km/h
    Temperature: 68.0°C
    Voltage: 10.795 V
    004199 - Intake Air Switch-Over Valve (N335): Short to Ground
    P1067 - 002 - Lower Limit Exceeded
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 4
    Mileage: 40199 km
    Time Indication: 0
    Freeze Frame:
    RPM: 300 /min
    Load: 74.1 %
    Speed: 0.0 km/h
    Temperature: 68.0°C
    Voltage: 11.684 V
    005173 - Secondary Air Pump Relay (J299): Short to Ground
    P1435 - 002 - Lower Limit Exceeded
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 4
    Mileage: 40199 km
    Time Indication: 0
    Freeze Frame:
    RPM: 300 /min
    Load: 74.1 %
    Speed: 0.0 km/h
    Temperature: 68.0°C
    Voltage: 11.684 V
    005153 - Secondary Air Injection Solenoid Valve (N112): Short to Ground
    P1421 - 002 - Lower Limit Exceeded
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 4
    Mileage: 40199 km
    Time Indication: 0
    Freeze Frame:
    RPM: 300 /min
    Load: 74.1 %
    Speed: 0.0 km/h
    Temperature: 68.0°C
    Voltage: 11.684 V
    005494 - Right Engine Mount Solenoid Valve (N145): Short to Ground
    P1576 - 002 - Lower Limit Exceeded
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 4
    Mileage: 40199 km
    Time Indication: 0
    Freeze Frame:
    RPM: 300 /min
    Load: 74.1 %
    Speed: 0.0 km/h
    Temperature: 68.0°C
    Voltage: 11.684 V
    000135 - Fuel Rail/System Pressure: Too Low
    P0087 - 002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 4
    Mileage: 40253 km
    Time Indication: 0
    Freeze Frame:
    RPM: 867 /min
    Load: 25.9 %
    Speed: 0.0 km/h
    Temperature: 44.0°C
    Temperature: 32.0°C
    Absolute Pres.: 1000.0 mbar
    Voltage: 13.970 V
    000049 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit: Short to Ground
    P0031 - 002 - Lower Limit Exceeded
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 3
    Mileage: 40253 km
    Time Indication: 0
    Freeze Frame:
    RPM: 737 /min
    Load: 34.9 %
    Speed: 0.0 km/h
    Temperature: 60.0°C
    Voltage: 13.716 V
    000055 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit: Short to Ground
    P0037 - 002 - Lower Limit Exceeded
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 3
    Mileage: 40254 km
    Time Indication: 0
    Freeze Frame:
    RPM: 737 /min
    Load: 34.9 %
    Speed: 0.0 km/h
    Temperature: 60.0°C
    Voltage: 13.716 V
    008853 - Fuel Pressure Regulator Valve (N276): Short to Ground
    P2295 - 002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 2
    Mileage: 40278 km
    Time Indication: 0
    Freeze Frame:
    RPM: 1500 /min
    Load: 24.7 %
    Speed: 0.0 km/h
    Temperature: 68.0°C
    Voltage: 11.938 V
    Readiness: 0000 0000
    Idee? Sono errori frequenti.
    Inoltre ho notato la spia epc rimanere accesa per qualche minuto dopo un riavvio a motore caldo e poi scomparire.
    Con la spie epc accesa l'auto sopra i 4k giri strappa.
    Ultima modifica di Daniele; 31-10-2008 alle 19:27 Motivo: Unione automatica messaggi multipli
    Utente L'avatar di pissy-possy
    Aug 2008
    rs4
    dani,dai i numeri?????
    Audi lover L'avatar di kri power
    Apr 2005
    Parma (PR)
    i love safety car !!
    mi sa di si
    i miei cagnoni..
