Salve, questa la vaggata degli errori indicati:
Chassis Type: 4L0
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 55
56 61 62 6C 72 76 77
VIN: WAUZZZ4F18N181735 Mileage: 102990km/63995miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F9 910 401 B HW: 4F0 907 401 C
Component: 3.0L V6TDI G000AG 0030
Revision: --H05--- Serial number:
Coding: 0011372
Shop #: WSC 02145 785 00200
VCID: 244C5BFAE70CE93ECBD
2 Faults Found
005663 - Glowplug for Cylinder 6 (Q15)
P161F - 001 - Open Circuit
Freeze Frame:
Fault Status: 01110001
Fault Priority: 0
Fault Frequency: 1
Mileage: 88023 km
Time Indication: 0
Date: 2013.02.23
Time: 19:52:49
Freeze Frame:
RPM: 882 /min
Torque: 144.3 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.60 V
Duty Cycle: 22.9 %
Temperature: 16.2°C
004120 - Intake Manifold Runner (Bank 2)
P1018 - 001 - Lower limit not reached - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 254
Mileage: 91815 km
Time Indication: 0
Date: 2013.05.06
Time: 17:59:33
Freeze Frame:
RPM: 882 /min
Torque: 144.3 Nm
Speed: 0.0 km/h
Voltage: 13.45 V
Duty Cycle: 80.9 %
Duty Cycle: 88.8 %
Duty Cycle: 80.9 %
Readiness: 0 1 0 0 0
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F2 910 156 T HW: 09L 927 156 C
Component: AG6 09L 3,0 TDI RdW 0020
Revision: --H04--- Serial number: 4478956
Coding: 0000001
Shop #: WSC 02325 785 00200
VCID: 366891B241906BAE659
No fault code found.
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 AD HW: 4F0 614 517 AA
Component: ESP8 quattro H01 0070
Revision: 00000000 Serial number: 00000000000000
Coding: 0020876
VCID: 66C801F251B0DB2E159
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 D
Component: FBSAUDIC6 ELV H05 0100
Revision: 00H05000 Serial number: 10602601170336
Coding: 0000135
Shop #: WSC 02324 785 00200
VCID: 254A46FEEC361036DC3
Subsystem 1 - Part No: 4F0 910 132 G
Component: FBSAUDIC6 EZS H03 0020
Subsystem 2 - Part No: 4F0 910 335 B
Component: FBSAUDIC6 KSG H02 0020
Subsystem 3 - Part No: 4F0 910 220 K
Component: FBSAUDIC6 IDG H01 0040
1 Fault Found
00955 - Key 1
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00110010
Fault Priority: 3
Fault Frequency: 6
Reset counter: 40
Mileage: 81772 km
Time Indication: 0
Date: 2012.11.22
Time: 12:35:57
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F0 910 732 K HW: 4E0 035 729 A
Component: Interfacebox H43 5140
Revision: 00000000 Serial number: 351IX087568423
Coding: 0001005
Shop #: WSC 02335 785 00200
VCID: 2B5EB0C68AD226460A7
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H01 0060
Subsystem 2 - Serial number: 00000001160603
Subsystem 3 - Serial number: 0101.09.080000000100010604ÿ
Subsystem 4 - Serial number: 010604ÿ
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 A HW: 4F1 820 043 AF
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000054 Serial number: 00000000563582
Coding: 0000278
VCID: 1C3C631ADF7CD1FE73D
2 Faults Found
00797 - Sunlight Photo Sensor (G107)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Reset counter: 60
Mileage: 79500 km
Time Indication: 0
Date: 2012.10.09
Time: 10:28:10
01858 - Air Outlet Sensor; Right Center (G348)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 87
Reset counter: 51
Mileage: 97166 km
Time Indication: 0
Date: 2013.08.04
Time: 19:05:15
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 N HW: 4F0 907 279
Component: ILM Fahrer H21 0310
Revision: 00000000 Serial number: 4F0907279
Coding: 0012121
VCID: 346CABBA57EC79BE5BD
Subsystem 1 - Part No: 4F1 910 113 C Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H06 0210
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00146221
Shop #: WSC 02335
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
Component: MP3-Changer H47 0390
Revision: 00047003 Serial number: AUZ5ZBH8565924
Shop #: WSC 00000 000 00000
VCID: 1A306502D548AFCE611
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 42 AIRBAG AUDI8RH30 0280
Revision: 09H30000 Serial number: 0037LD0ZE1T.
Coding: 0013362
VCID: 29524ACE802E3456F8B
Subsystem 1 - Serial number: 6332CSME3F00681B5
Subsystem 2 - Serial number: 6342CSME3F01101A-
Subsystem 3 - Serial number: 6352QSME510352160
Subsystem 4 - Serial number: 6362QSME79075726L
Subsystem 5 - Serial number: 63734SME69061226X
Subsystem 6 - Serial number: 63834SME2C063F142
Address 16: Steering wheel
Cannot be reached
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4F0 920 933 J
Component: KOMBIINSTR. M73 H23 0240
Revision: 00000000 Serial number: 72U54U398
Coding: 3073158
Shop #: WSC 00961 264 181766
VCID: 234E58E6E202EE06B27
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1100B08823819D
Coding: F551DE7730320600
VCID: 2D5ABEDEB4C62876143
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 M
Component: MNS ECE H52 1060
Revision: 00000000 Serial number: 364H$087812479
Shop #: WSC 00020 264 87705
VCID: 3B7E80867AB2B6C69A7
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0210
Revision: 00000000 Serial number: †Xƒ
Coding: 0018026
Shop #: WSC 02327 785 00200
VCID: 2C5CB3DA8FDC217E03D
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 J HW: 4F0 907 289 J
Component: Komfortgeraet H27 0220
Revision: 02200027 Serial number: 01120014080000
Coding: 0140017
VCID: 3162A2AEA8FE4C9630B
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
Address 47: Sound System (J525) Labels: Redir Fail!
Part No SW: 4F0 910 223 M HW: 4F0 035 223 N
Component: Amp.-ASK-RD H07 0270
Revision: S1400000
Coding: 020001
Shop #: WSC 02399 823 56573
VCID: 28544FCA5B240D5EE75
1 Fault Found
02095 - Component Protection Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 50
Mileage: 93388 km
Time Indication: 0
Date: 2013.05.30
Time: 19:47:42
Freeze Frame:
Voltage: 13.60 V
Temperature: 41.0°C
Bin. Bits: 00000011
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000578431
Coding: 0001103
VCID: DEB8A91209E003EE5D9
Address 52: Door Elect, Pass. Labels: None
VCID: 55AA363EBCD640B68C3
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04---
Coding: 0000321
VCID: 204457EAF314F51EAF5
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 H
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000003
VCID: 3F86F4966EAAAAE6B6F
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 394H5087927838
Coding: 0000001
VCID: 2E58B9D2B9C0536E2D9
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 F HW: 4F0 915 181 B
Component: J0644 BEM H12 0760
Revision: 00000000 Serial number: 00000000139085
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 2809022880
Coding: 344630393135313035442056413032383039303232383830
Shop #: WSC 00000 512 00290
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0210
Coding: 0017450
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4F0 910 441 A HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J8730OO
Coding: 1020205
VCID: 1E386912C960C3EE9D9
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0210
Coding: 0017450
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 H HW: 4F0 919 283 H
Component: Parkhilfe 8-Kan H12 0080
Revision: 00H12000 Serial number: 06340820405386
Coding: 0221116
Shop #: WSC 131071 1023 2097151
Address 77: Telephone
Cannot be reached
End ---------------------------------------------------------------------
Qualcuno mi sa dare qualche dritta???
Grazie in anticipo
