Wednesday,27,August,2014,15:04:47:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: ____________________ License Plate:
Mileage: 224120km-139261mi Repair Order: 1
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 55
56 61 62 72 76 77
VIN: ___________________ Mileage: 224120km/139261miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: Cannot be reached 1100
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
37-Navigation -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Cannot be reached 1100
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Cannot be reached 1100
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F9 910 401 B HW: 4F0 907 401 C
Component: 3.0L V6TDI G000AG 0020
Revision: --H05--- Serial number:
Coding: 0011372
Shop #: WSC 02334 758 00200
VCID: 24470A1BE72E243ED0B-8071
1 Fault Found:
005661 - Glowplug for Cylinder 4 (Q13)
P161D - 001 - Open Circuit
Freeze Frame:
Fault Status: 01110001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 224111 km
Time Indication: 0
Date: 2014.08.27
Time: 07:24:17
Freeze Frame:
RPM: 882 /min
Torque: 81.9 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 12.62 V
Duty Cycle: 25.3 %
Temperature: 33.3°C
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F2 910 156 T HW: 09L 927 156 C
Component: AG6 09L 3,0 TDI RdW 0020
Revision: --H04--- Serial number: 4394107
Coding: 0000001
Shop #: WSC 02325 758 00200
VCID: 3663C05341B2A6AE7EF-8063
No fault code found.
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 AD HW: 4F0 614 517 AA
Component: ESP8 quattro H01 0070
Revision: 00000000 Serial number: 00000000000000
Coding: 0020876
VCID: 66C350135192162E0EF-8033
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 E
Component: FBSAUDIC6 ELV H08 0200
Revision: 00H08000 Serial number: 10603802126373
Coding: 0000131
Shop #: WSC 50974 001 1048576
VCID: 2541171FEC14DD36C75-8070
Subsystem 1 - Part No: 4F0 910 131 E
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H01 0040
Address 07: Control Head
Cannot be reached
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 A HW: 4F1 820 043 AF
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000053 Serial number: 00000030301426
Coding: 0000278
VCID: 1C3732FBDF5E1CFE68B-8049
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H18 0250
Revision: 00000000 Serial number: 4F0907279
Coding: 0012121
Shop #: WSC 02335 785 00200
VCID: 3169F34FA8DC81962BD-8064
Subsystem 1 - Part No: 4F1 910 113 C Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0210
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 B Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0100
Coding: 00146221
Shop #: WSC 02335
Address 0E: Media Player 1
Cannot be reached
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 42 AIRBAG AUDI8RH30 0280
Revision: 09H30000 Serial number: 0037LD0V333+
Coding: 0013362
VCID: 29591B2F800CF956E3D-807C
Subsystem 1 - Serial number: 6332CSME29253908%
Subsystem 2 - Serial number: 6342CSME28022B08
Subsystem 3 - Serial number: 6352QSME472C2E41N
Subsystem 4 - Serial number: 6362QSME46014A7BL
Subsystem 5 - Serial number: 63734SME3A0D0E053
Subsystem 6 - Serial number: 63834SME4471044B.
Address 16: Steering wheel
Cannot be reached
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4F0 920 933 J
Component: KOMBIINSTR. M73 H21 0240
Revision: 00700000 Serial number: 6XX15R6C7
Coding: 3073558
Shop #: WSC 00011 888 96745
VCID: 23450907E2202306A91-8076
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1100B07B09814A
Coding: F5519E7730320600
VCID: 2D51EF3FB4E4E5760F5-8078
Address 37: Navigation
Cannot be reached
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0210
Revision: 00000000 Serial number: 8%
Coding: 0001642
Shop #: WSC 02327 758 00200
VCID: 2C57E23B8FFEEC7E18B-8079
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 J HW: 4F0 907 289 J
Component: Komfortgeraet H26 0210
Revision: 02100026 Serial number: 01078802720000
Coding: 0140017
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
Address 47: Sound System
Cannot be reached
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000493553
Coding: 0001103
Shop #: WSC 02323 758 00200
VCID: DEB3F8F309C2CEEE46F-808B
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0210
Revision: 00-00000
Coding: 0001642
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04---
Coding: 0000321
Shop #: WSC 02324 758 00200
VCID: 204F060BF336381EB43-8075
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 H
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000003
VCID: 3F8DA5776E8867E6AD9-806A
Address 56: Radio
Cannot be reached
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 F HW: 4F0 915 181 B
Component: J0644 BEM H12 0760
Revision: 00000000 Serial number: 00000000036592
Shop #: WSC 00901 264 66769
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 2711101223
Coding: 344630393135313035442056413032373131313031323233
Shop #: WSC 00000 512 00290
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0210
Coding: 0001066
VCID: 2E53E833B9E29E6E36F-807B
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0210
Coding: 0001066
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 H HW: 4F0 919 283 H
Component: Parkhilfe 8-Kan H12 0080
Revision: 00H12000 Serial number: 06320731202589
Coding: 0201116
Shop #: WSC 131071 1023 2097151
Address 77: Telephone
Cannot be reached
End ---------------------------------------------------------------------
