Pagina 2 di 2 PrimaPrima 12
Risultati da 11 a 13 di 13
Discussione: Car tablet android su Audi Q5 2013 8R - problema audio
    Nov 2015
    Q5
    Si anche il mio stessa cosa. Android auto solo con il cavo. Tornando al problema iniziale dell'audio,si parla di DAC usb per risolverlo,tipo questo:
    https://www.amazon.it/Sabrent-Estern...09581845&psc=1
    ma il mio dispositivo ha come uniche uscite usb le due prese (gialle e rosse) che ho fatto finire nel cassetto portaoggetti. Non ho ben capito , se per il collegamento , dovrei passare poi per la presa aux presente nel bracciolo centrale
    Nov 2015
    Q5
    ho trovato una guida :
    USB DAC / Sound Card Installation Guide
    What this does:
    - 1000x better sound compared to just using stock AUX out!
    - Absolutely no crackling anymore on high volumes and blowing the bass
    - Full unmuffled clarity in your Music
    You will need FIVE things:
    1. USB DAC/Sound Card, for more information, you can pick one here: https://f30.bimmerpost.com/forums/sh...&postcount=549
    (I am personally using the FIIO K3, but for a cheaper alternative you can pick a Sabrent card)
    2. A better set of 3.5mm cables compared to the original ones (e.g. https://www.amazon.ca/gp/product/B00...?ie=UTF8&psc=1) [I would highly recommend professional grade, braided cables with gold plating]
    3. A ground loop noise isolator (e.g. https://www.amazon.ca/gp/product/B01...?ie=UTF8&psc=1)
    4. A 3.5mm mic (e.g. https://www.amazon.ca/gp/product/B00...?ie=UTF8&psc=1)
    5. The screen must be on Android 10 for this to function seamlessly.
    Connect the wires up in this fashion:
    - From one of the USB ports on your harness, connect the USB Sound Card. Your USB Sound Card SHOULD have a Mic and an Audio OUT.
    - Connect the 3.5mm Mic into the Mic hole
    - Connect a 3.5mm cable to the USB Sound Card and the other end to the Ground Loop Noise Isolator
    - Connect the other end of the Ground Loop Noise Isolator to your original source back to NTG, in this case, connect it back to the USB AUX, or back to your harness' AUX cable depending on your car.
    - Done!
    Jun 2011
    a4 b8 avant sline
    Ho preso anche io un android auto, ancora lo devo montare, voi avete provato a mettere l'usb dac?
