VCDS Version: Release 11.11.0 (x64)
Data version: 20111111
Friday,10,May,2013,19:18:46:37412
Chassis Type: 1K0
Scan: 01 03 08 09 10 14 15 16 17 19 25 37 42 44 46 47 52 55 56
VIN: WAUZZZ8P09A001429 Mileage: 106420km/66126miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 BQ HW: 03L 906 022 BQ
Component: R4 2,0L EDC G000SG 3066
Revision: --H01--- Serial number: AUX7Z0H4FNJ0K3
Coding: 0000072
Shop #: WSC 83712 792 673350
VCID: 75EB90701CDA296
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0104
Revision: 00H35001
Coding: 11424012092200FB880F02E6902200423900
Shop #: WSC 06314 000 00000
VCID: 75EB9070DCDA296
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BG HW: 8P0 820 043 BG
Component: KlimavollautomatH08 0100
Revision: 000010 Serial number: 8P0820043BG
Shop #: WSC 00000 000 00000
VCID: 72E1AB6C6DB43EE
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000008438978
Coding: F58A1F0780141380EF00000A4F00000000094E056406000300 A000000000
Shop #: WSC 06314 000 08192
VCID: 489529843BA8E4E
Subsystem 1 - Part No: 8P1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00056595
Shop #: WSC 06314
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00150573
Shop #: WSC 06314
4 Faults Found:
01496 - Bulb for Fog-Lamps; Left (L22)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 186
Mileage: 106023 km
Time Indication: 0
Date: 2013.04.30
Time: 20:32:00
Freeze Frame:
ON
Voltage: 11.95 V
OFF
ON
OFF
OFF
OFF
00978 - Lamp for Low Beam; Left (M29)
Freeze Frame:
Fault Status: 01111010
Fault Priority: 1
Fault Frequency: 2
Reset counter: 169
Mileage: 106180 km
Time Indication: 0
Date: 2013.05.04
Time: 12:35:00
Freeze Frame:
ON
Voltage: 14.05 V
OFF
ON
OFF
OFF
OFF
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00111100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 194
Mileage: 106189 km
Time Indication: 0
Date: 2013.05.04
Time: 15:15:00
Freeze Frame:
ON
Voltage: 12.10 V
OFF
ON
OFF
OFF
ON
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 186
Mileage: 106023 km
Time Indication: 0
Date: 2013.04.30
Time: 21:05:00
Freeze Frame:
ON
Voltage: 12.10 V
OFF
ON
OFF
OFF
OFF
Address 10: Park/Steer Assist (J791) Labels: Redir Fail!
Part No SW: 8P0 919 475 E HW: 8P0 919 475 B
Component: PARKHILFE PLA H07 0102
Revision: 11001001 Serial number: 84530810900431
Coding: 000002
VCID: 408531A4D398DCE
Address 14: Susp. Elect. Labels: 8P0-907-376.lbl
Part No SW: 8P0 907 376 HW: 8P0 907 376
Component: J250 Raddaempfung 0030
Revision: --H03--- Serial number: 190DPH 8114199
Coding: 0000141
VCID: F8F519448BC8D4E
Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003000000000
Coding: 303142413039303030344A55304C38503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 49932C80E8A21D6
Crash sensor for side airbag; driver side:
Serial number: 34928RB400003CA4956V
Crash sensor for side airbag; passenger side:
Serial number: 35028RB400003CD6C53S
Crash sensor for side airbag; rear driver side:
Serial number: 35128RB400003CA49B6U
Crash sensor for side airbag; rear passenger side:
Serial number: 35228RB400003CD61A8T
Crash sensor for front airbag; driver side:
Serial number: 35547RB400003BEF7F79
Crash sensor for front airbag; passenger side:
Serial number: 35647RB400003BEF7CAA
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0002042
VCID: 418334A01892D56
Part No: XXXXXXXXXXX
Component: E0221 H02 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 931 S HW: 8P0 920 931 S
Component: KOMBIINSTR. VDO H15 0820
Revision: D0H15004 Serial number: 2244H004003436
Coding: 0196128
Shop #: WSC 30430 264 187583
VCID: 438F3EA8028EC76
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K0853102BA
Coding: E9A91F065002020100
VCID: 356B50705C5A696
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H15004 Serial number: AUX7Z0H4FNJ0K3
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 192 S HW: 8P0 035 192 S
Component: RNS-E HIGH EU H76 0650
Revision: 03S Serial number: AUZBZ7H4103936
Coding: 0205157
VCID: 3F8732586E66A36
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 7
Fault Frequency: 1
Reset counter: 209
Mileage: 101910 km
Time Indication: 0
Date: 2012.10.01
Time: 10:42:58
Freeze Frame:
Voltage: 12.70 V
Mileage: 655350 km
Count: 1005
Clock: 19:10
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
Part No SW: 8P0 959 801 J HW: 8P0 959 801 J
Component: Tuer-SG H03 0060
Coding: 0004220
VCID: 42813BAC1D94CEE
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.078 H08 1901
Shop #: WSC 02069 000 90108
1 Fault Found:
03075 - Parallel Parking Assistance Control Module (J791)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Mileage: 59980 km
Temperature: 16.0°C
Voltage: 13.70 V
Voltage: 13.50 V
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 L
Component: KSG H11 0080
Coding: 189030403F5E24258C0CC01AD677
Shop #: WSC 06314 123 12345
VCID: 458B20B00CBAF96
Component: Sounder No Answer
Component: DWA-Sens. No Answer
1 Fault Found:
01403 - Glass-Break Sensors; Rear
011 - Open Circuit
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P3 035 382 D HW: 8P3 035 382 D
Component: AB2 SUBWOOFERBOXH30 0160
Revision: 00006 Serial number: 30659850159010
VCID: 346D6D74572070E
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 8P0 959 802 J HW: 8P0 959 802 J
Coding: 0004220
1 Fault Found:
00944 - Heated Exterior Mirror; Passenger Side (Z5)
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 J
Component: Dynamische LWR H01 0020
Revision: 00000001 Serial number:
Coding: 0000014
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0205157
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 209
Mileage: 101910 km
Time Indication: 0
Date: 2012.10.01
Time: 10:42:58
Freeze Frame:
Voltage: 12.70 V
Mileage: 655350 km
Count: 1005
Clock: 19:10
End ---------------------------------------------------------------------
