ciao, possibile che sia così complicato??
[Select]
[17 - Instruments]
[Recode - 07]
Write down the existing coding for future reference.
Enter 5-digit code from below
[Do It!]
Look at the first two digits in the coding. Add the values for the options together to get the correct coding.
00 - No available equipment
+01 - Brakepad wear sensor warning active
+02 - Seatbelt warning active
+04 - Washer fluid level warning active (may only work with pre-2000 models)
+16 - Navigation System (non-USA models)
Look at the third digit in the coding (Market version):
0 - "Germany" 24 hour clock
1 - "Rest of World" 24 hour clock
2 - "USA" 12 hour clock
3 - "Canada" 12 hour clock
Look at the fourth digit in the coding (Cylinders):
4 - 4-cylinder
6 - 6-cylinder
Look at the fifth digit in the coding (Distance impulse multiplier):
0 - TDI Engine (non-USA models)
2 - Non-turbo Gasoline engine
4 - Turbocharged engine
Example: If existing 5-digit code is 07164
07 - 02 = 05
New 5-digit code: 05164
