Pagina 4 di 4 PrimaPrima 1234
Risultati da 31 a 40 di 40
Discussione: RETROFIT - Installazione BOOSTER RADIO su AUDI A3/S3 8PA 2011
  1. #31
    Apr 2019
    Thanked: 3
    Imperia (IM)
    audi a3- alfa romeo 155 Q4
    altro aggiornamento,allora comando l'amplificatore piccolo sulla baya,numero 8P4035225B,montato senza fare le modifiche della guida di cavetti ,spinette,cavo antenna,sulla mia A3 8P1 non vi é bisogno ,mi resta sempre l'errore con vcds,
    Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
    Part No SW: 8P0 035 193 B HW: 8P0 035 193 B
    Component: RNS-E PU EU H03 0300
    Revision: 0000005S Serial number: AUZBZ7J6113509
    Coding: 0225717
    Shop #: WSC 06314 123 12345
    VCID: 2F6DCCF8BEFA3CEE6A-807A
    4 Faults Found:
    00856 - Radio Antenna
    007 - Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00100111
    Fault Priority: 5
    Fault Frequency: 24
    Reset counter: 95
    Mileage: 144634 km
    Time Indication: 0
    Date: 2024.10.30
    Time: 17:07:30
    Freeze Frame:
    Mileage: 144710 km
    Count: 511
    Clock: 14:33
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 95
    Mileage: 144634 km
    Time Indication: 0
    Date: 2024.10.30
    Time: 16:52:25
    Freeze Frame:
    Mileage: 144720 km
    Count: 511
    Clock: 17:58
    00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 95
    Mileage: 144594 km
    Time Indication: 0
    Date: 2024.10.30
    Time: 14:09:45
    Freeze Frame:
    Mileage: 144720 km
    Count: 611
    Clock: 14:21
    03157 - Functionality limited due to Communications Disruption
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 55
    Mileage: 144594 km
    Time Indication: 0
    Date: 2024.10.30
    Time: 15:06:02
    Freeze Frame:
    Bin. Bits: 00000100 00000000
    Bin. Bits: 00000000 00000000
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
    Part No: 8P0 959 801 H
    Component: Tuer-SG 020 0070
    Coding: 0000032
    Shop #: WSC 06314 000 00000
    VCID: 408F9F441364B39683-8014
    1 Fault Found:
    00943 - Heated Exterior Mirror; Driver Side (Z4)
    012 - Electrical Fault in Circuit
    ora ordino un adattatore da faratech per il diversity antenna e se va ok se mi da sempre errore me lo tengo tanto funziona tutto sia la radio che il navigatore.basta non spendo piu un € per ste cavolate
    Ultima modifica di misterdey; 11-11-2024 alle 14:42
    Apr 2019
    Thanked: 3
    Imperia (IM)
    aggiornamento,mi é arrivato il famoso cavo diversity antenna,montato faccio una scansione e mi da sempre lo stesso errore sulla radio,basta non ne posso piu.
    ddress 56: Radio Labels: 8E0-035-192-RNSE.clb
    Coding: 0225717
    1 Fault Found:
    000 - -
    Freeze Frame:
    Fault Status: 01110000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 55
    Mileage: 144745 km
    Time Indication: 0
    Date: 2024.11.06
    Time: 15:58:31
    Freeze Frame:
    me la tengo cosi e in k..o alla radio
  4. #33
    Jul 2009
    Pescara (PE)
    A6 2.7 TDI
    Buongiorno, ma nella guida non ci sono più le foto. Proprio adesso che ho ricevuto il tutto ed ero pronto a fare il lavoro.
    Qualcuno sa come posso recuperare la guida passo, passo, con le foto.
    Grazie mille a chi mi potra' aiutare.
  5. #34
    Audi lover L'avatar di SM4rk
    Jun 2008
    Antartide
    A34 (INTEGRALISTA x passione)
    Citazione Originariamente Scritto da ErgoIta Visualizza Messaggio
    Sono in contatto con @lucamitch , il creatore della guida, e sta verificando se riesce a ripristinare la guida.
    nel frattempo noto nel tuo profilo che hai una A6... occhio che qui si parla di A3 8p... non so se è la stessa guida
    SE TI SONO STATO UTILE O TI HA FATTO PIACERE IL MIO MESSAGGIO, PREMI IL TASTO THANKS
    ...La potenza è nulla senza il controllo...
    1a Cena Marchigiana.. Io c'ero!!
  6. #35
    New Entry L'avatar di lucamitch
    Aug 2014
    Thanked: 4
    Treviso (TV)
    Audi A4 Avant 3.0
    Ciao a tutti, allora, non sono riuscito a inserire nuovamente le foto visibile della discussione, ma ho messo il link " FOTO " alle foto nel mio drive.
    Spero di esservi di aiuto.
    La distanza più breve tra due punti non è necessariamente la più divertente. Audi. Nata per le curve.
  7. #36
    Jun 2008
    Antartide
    Citazione Originariamente Scritto da lucamitch Visualizza Messaggio
    Grazie mille Luca, ho seguito alla lettera le tue indicazioni...
    non so perche, nonostante prima di montare RNS-E 193C, avessi prima la concert II con navigatore nel FIS, ho già i booster corretti e il cavo aggiuntivo che dici di costruire manualmente per collegare i due booster.
    ho anche la terza spina grigia di cui dici sia presente su alcuni modelli in base alle dotazioni di serie.
    nonostante tutto corretto la qualità di ricezione FM rimane scarsa.
    Se per scrupolo riattacco volante la CONCERT si sente a meraviglia...
    MISTERO... penso di rassegnarmi per la seconda volta come mi ero rassegnnato all'epoca...
    Peccato... perchè sicuramente sarà una banalità
  8. #37
    Apr 2019
    Thanked: 3
    Imperia (IM)
    SM4rk occhio a non buttare i soldi come ho fatto io,comprato 4 cavi riparazione in audi € 86,00,comprato sulla baya i 2 amplificatori antenna,comprato il cavo fakra doppio, montato il tutto e non é servito a nulla ,ho sempre lo stesso errore in diagnosi sulla radio,non tutte le auto hanno gli stessi impianti antenna,quindi ora mi ritrovo con dei cavi riparazione originali audi mai usati perche la modifica famosa non lo fatta non essendoci piu le foto della guidadegli amplificatori etc...e ho buttato via soldi per nulla
  9. #38
    Jun 2008
    Antartide
    misterdey le foto sono state ripristinate... basta cliccare sui link foto...
    la guida è molto chiara e dettagliata...
    per mia fortuna/sfortuna non ho dovuto acquistare niente perche verificando i codici con quelli della guida, non so come ma avevo gia tutto di serie...
    per di piu, avendo esattamente gli stessi codici delle guida ti posso assicurare che non ho nessun errore in diagnosi...
    il mio "problema" se si puo definire tale, è la pessima ricezione che ho con l'rns-e nonostante tutto corretto, rispetto alla ricezione che ho se monto al volo la vecchio concertII
    per tanto se a te restituisce errore dopo aver sostituito con i codici giusti, il problema credo sia da amputare ai 2 amplificatori presi sulla baya, che probabilmente o non sono originali o sono originali cinesati...
  10. #39
    Apr 2019
    Thanked: 3
    Imperia (IM)
    Citazione Originariamente Scritto da SM4rk Visualizza Messaggio
    cioe secondo te vado a comprare in audi i cavi riparazione a 86€ e poi compro degli amplificatori cinesi???il prodotto é originale audi prese sulla baya da un sito di demolitori,cerca ovoko e vedi cosa esce
    Audi lover L'avatar di thank71
    May 2015
    Thanked: 8
    Genova (GE)
    A3 SportBack 8P
    grazie...
    ma non ho capito una cosa.. cosa hanno questi componenti in piu' rispetto a quelli originali??
    N° 1 Amplificatore antenna 8P4035225B 40 €
    N° 1 Amplificatore antenna 8P4 035 225 130 €
    Graziano
