HuG0_B0Ss
Ciao a tutti,ieri ho fatto per la prima volta la diagnosi col vag-com per vedere se era tutto ok...e invece mi sono usciti 3 errori di cui non sò di cosa si tratta...voi potete aiutarmi? grazie....gli errori sono questi....
09-Cent. Elect. -- Status: Malfunction 0010
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 K HW: 8P0 907 279 K
Component: Bordnetz-SG H54 2501
Revision: 00H54000 Serial number: 00000007772335
Coding: 01880F01901410004F0000003200000000085E135C01000000 0000000000
Shop #: WSC 06314 000 08192
Part No: 8P1 955 119 E
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
1 Fault Found
01504 - Bulb for License-Plate Light (X)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 5
Reset counter: 140
Mileage: 23505 km
Time Indication: 0
Date: 2009.08.19
Time: 21:58:00
Freeze Frame:
ON
Voltage: 13.80 V
ON
ON
OFF
OFF
OFF
__________________________________________________ ________________
Segnale intermittente dalla luce targa (appunto l'hai messa a LED... rimetti le lampadine a siluro classiche e vedrai che l'errore scompare)
17-Instruments -- Status: Malfunction 0010
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.lbl
Part No SW: 8P0 920 931 E HW: 8P0 920 931 E
Component: KOMBIINSTR. VDO H20 0640
Revision: D0H20001 Serial number: 2249G001108020
Coding: 0004128
Shop #: WSC 30178 264 89186
1 Fault Found
01299 - Diagnostic Interface for Data Bus (J533)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 3
Reset counter: 115
Time Indication: 0
46-Central Conv. -- Status: Malfunction 0010
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 L
Component: KSG H11 0080
Coding: 1880202002186D0985054C8F0167
Shop #: WSC 06314 000 00000
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
1 Fault Found
00955 - Key 1
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Trattasi appunto della chiave e la chiave 1 nel particolare. Quando hai acquistato la macchina te ne hanno date 2. Per vedere quale tra le due stai usando vai nel CDB -> INFO-> Chiavi e ti dira 1/2 se usi la 1 e 2/2 se usi la 2
